5w-20 PP Walmart & Amazon $12
by jayjr1105 - 04/03/20 02:28 PM
Chicken Marsala Recipe Help
by 97prizm - 04/03/20 02:02 PM
Oil Filter Removal
by Kansas_Ron - 04/03/20 01:24 PM
Pressure regulator made in USA
by rainman49 - 04/03/20 01:08 PM
mitsubishi outlander
by ernied - 04/03/20 12:43 PM
WM - Pennzoil Platinum $18.68
by The Critic - 04/03/20 12:13 PM
Going from a PAO to a Ester base MT oil
by Bill_W - 04/03/20 11:54 AM
Spring Cleaning
by Mad_Hatter - 04/03/20 11:40 AM
Starting Over - 2013 Prius
by Greg L - 04/03/20 11:15 AM
Glue for dovetail joints
by spasm3 - 04/03/20 11:08 AM
In my face "wake up" call
by Kira - 04/03/20 10:58 AM
repairing old stereo equipment
by Donald - 04/03/20 10:44 AM
Valvoline Syn. Grease 14oz tube
by zfasts03 - 04/03/20 10:39 AM
WIX XP oil filter leaking....
by dkryan - 04/03/20 10:36 AM
K&N PS 1017 VIRGIN FILTER CUT OPEN
by 53' Stude - 04/03/20 09:56 AM
Got bored so I fired up the smoker
by BeerCan - 04/03/20 09:43 AM
VIRGIN M1-209A CUT OPEN
by 53' Stude - 04/03/20 09:39 AM
Roasts: what kind do you folks buy?
by 53' Stude - 04/03/20 09:12 AM
TJim, Andreeas1978, lawmanracing14, ebarker, Knop
71082 Registered Users
117 registered members (53' Stude, alchargo, Alfred_B, 007, 97prizm, 10 invisible), 2,440 guests, and 19 spiders.
Topics303,526
Posts5,236,951
Members71,082
17 Dodge Ram 6.7, 5K #5329590 01/22/20 03:16 PM
M
merdog Offline OP
M
Hello,
Long time lurker time to post. This UOA has me a little worried, 6ppm every 1000 miles. The oil was Rotella T6 in 5W40. Oil was looking real watered down, 2k of the 5K was towing a 5th wheel from Texas up to Washington and in Oregon. Changed the Oil with T6 15W40. Hoping the iron rate drops with a little thicker oil! TIA.
2005 Honda CRV, Valvoline, Wix filters
2017 Dodge 2500, Valvoline, Donaldson filters.
Re: 17 Dodge Ram 6.7, 5K [Re: merdog] #5329613 01/22/20 03:45 PM
B
BrianF Online Content
Online Content
B
From what I gather, the ISB6.7 sheds a lot of iron. Although "A lot" is relative. Is your mileage correct at just over 32,000? My 6.7 was making just over 7ppm/1000 miles when I tested the oil at 30,000 miles and 5ppm/1000 miles when tested at 45,000 miles.
You have a low mile count on that oil. The viscosity really did not change so it looks still serviceable.
Just to reiterate, Cummins specs 3% max on soot (yours was 0.2%) and 5% fuel (yours was not an issue).
Your engine is still really fresh and one analysis is only a snap shot of what is going on at that exact time. You need a lot more to build some data and see where your wear metals are trending.
Run your oil to the full 15k index and carry on.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
Re: 17 Dodge Ram 6.7, 5K [Re: merdog] #5331572 01/25/20 07:40 AM
B
Bighorn2500 Offline
B
I think the UOA looks good, I run 5w40 T6 in my 6.7L Cummins for 10k mile intervals with a Donaldson DBL filter. I could probably go longer but I don’t.
Try running 10k and doing another UOA, then see how it looks and decide how far you want to go. What oil filter are you running?
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: 17 Dodge Ram 6.7, 5K [Re: Bighorn2500] #5332323 01/25/20 11:15 PM
M
merdog Offline OP
M
I’m running a Donaldson Blue.
Re: 17 Dodge Ram 6.7, 5K [Re: BrianF] #5338182 02/01/20 01:38 PM
B
Bighorn2500 Offline
B
Sounds pretty similar to mine I was at about 6ppm/1k miles @ 17.6k miles and then settled down to just over 4ppm/1k miles at just over 56k miles.
To the OP: Keep using the Donaldson DBL, they’re the most efficient full flow available.
Re: 17 Dodge Ram 6.7, 5K [Re: merdog] #5339986 02/03/20 01:22 PM
R
Renzo Offline
R
My 17 6.7 was drinking about 2 quarts of 5W40 Rotella every 12k miles, so I swapped it with Motul 15W40.
Re: 17 Dodge Ram 6.7, 5K [Re: merdog] #5341714 02/05/20 11:43 AM
O
ofelas Offline
O
I've seen excessive T6 5w40 consumption in various 3.9s, 5.9s & 6.7s.
Back to normal when switched to 15w40s and 10w30s in either dino, semi-syn or full syn flavors.
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: 17 Dodge Ram 6.7, 5K [Re: merdog] #5352172 02/16/20 09:29 PM
A
Audios Offline
A
Funny, my GL needed 3/4 of a quart after 1500 miles on my first T6 interval. Didnt burn any on M1 0/30 or Fuchs 5/40.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
