Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
107 registered members (53' Stude, 750IX, 94astro, ABomb369, 330indy, 1978elcamino, 12 invisible), 2,128 guests, and 17 spiders.
Topics301,695
Posts5,200,801
Members70,759
Mobile 1 in a Subaru Manual transaxle? #5329538 01/22/20 01:17 PM
someoldguy Offline OP
Well Bob: I have an odd question: I was told by the master mechanic that rebuilds trannies to use Mobil 1 0-50 synthetic motor oil in my Dodge Cummins NV4500 instead of gear lube: was told it runs cooler and lubes better. So I did it.. and the transmission ran quieter and has been problem free for about 25,000 miles.. The Question: does anyone know if this can be done with a Subaru manual transaxle?
Thanks
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329544 01/22/20 01:24 PM
Char Baby Offline
Welcome youoldguy! laugh
Hopefully someone or many will chime in and answer your question. But most likely the answer will be to use whatever Subaru recommends.
Another old guy,
CB
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329545 01/22/20 01:25 PM
SubieRubyRoo Offline
NO! Not if you want it to last. Subaru transaxles are shared-lube on manual trannies, meaning you've got the clutches, shift forks, and hypoid gears sharing the same lube. You need a gear lube as it is designed for; Amsoil, Motul, Redline, and even Mobil all make lubes that meet the specs; why take the chance... do you think your "master mechanic" knows better/has more experience than either the Dodge or Subaru engineers, or is it more likely he's recommending this because he knows it will generate him more business? Not attacking you, and welcome to the board... but if somebody told me this and claimed to be a "master" I'd be hauling donkey out of his shop. JMO.
De omnibus dubitandum.
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329562 01/22/20 01:47 PM
W
Wheel Offline
W
Subaru specs a 75w-90 GL-5 for the manual transmission. It does have a hypoid gear, I wouldn't use engine oil.
2009 Subaru Legacy (N/A)
Quaker State Ultimate Durability and NAPA filter
Re: Mobile 1 in a Subaru Manual transaxle? [Re: SubieRubyRoo] #5329578 01/22/20 02:05 PM
I know he is a GM Certified Master Mechanic.. and has rebuilt thousands of transmissions...
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329586 01/22/20 02:12 PM
B
Bottom_Feeder Offline
B
He didn't design them though, did he?
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329587 01/22/20 02:13 PM
K
kschachn Online Content
Online Content
K
Thousands? That's pretty amazing.
I too would use what the manufacturer specifies, rather than one person's opinion about a different transmission in a very different vehicle. In the end it is a GM mechanic giving out advice on a Dodge transmission which you wish to extrapolate for a Subaru. What could go wrong?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Mobile 1 in a Subaru Manual transaxle? [Re: Oily_Thing] #5329596 01/22/20 02:20 PM
M
Miller88 Offline
M
I would in the NV - they can't use any sort of gear lube but use some sort of prorpietary less viscous fluid. I'm sure it interchanged with engine oil though. It's also popular for some of the FWD manual transaxles.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329600 01/22/20 02:23 PM
Cujet Offline
In some cases, Mobil 1 ATF is a wonderful manual transmission fluid. However, those cases are generally conventional FWD transaxles or conventional manual transmissions. The M1 ATF can be used to replace a conventional 5W-30 motor oil transmission fluid and is generally superior.
In your case, the somewhat unusual configuration of ring and pinion gears in a FWD transaxle, require a specific type of lubricant to ensure adequate gear life.
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329607 01/22/20 02:33 PM
N
nthach Offline
N
XOM does make a dedicated MTF for HD trucks, Delvac SAE50, but in your case any GL-5 75W-90 is sufficient. Subaru manuals share oil with the front diff and transfer gear/center diff.
If you have a LSD center diff, some swear by OEM Extra-S, others will say Amsoil or RL is fine.
Re: Mobile 1 in a Subaru Manual transaxle? [Re: kschachn] #5329614 01/22/20 02:49 PM
thousands... 30+ years at GM shop and then doing side jobs on the weekends... I pulled a lot of cores from the junk for him
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329627 01/22/20 03:09 PM
L
LoneRanger Offline
L
If you use anything but a non-LSD GL5 gear oil in a Subaru manual transmission the syncros won't hook up right and shift quality is going to go downhill and get notchy. Non-LSD means it doesn't contain friction modifiers. Gear oils for limited slip differentials contain friction modifiers and you don't want that in a Subaru manual transmission due to the syncros.
I owned a manual transmission Subaru Forester for 10 years. I did oil changes, rear differential lube changes, and manual transmission oil change (which includes the front differential-- shared lube) myself and I abided by Subaru's recommendations religiously on fluid specs. The car never gave me any big problems and drove as well the day I traded it in as it did when new. But it only had 67,000 miles so there's that. Anyhow, use a GL5 75W90 gear lube containing no friction modifiers, in your Subaru's manual transmission that really is what needs to be put in it. I used a 75W90 non-synthetic GL5 gear oil by ENEOS which worked well. I see from checking their US web page that they no longer offer it in non-LSD though, only LSD friction modified form so it's a no-go now for Subaru manual transmissions. Subaru Extra S GL5 75W90 gear oil would be the best choice. Back in the day a Subaru dealership used to sell it online, I think it was Fred Bean (?) Subaru.... maybe. Been awhile.
'19 F-150 2.7 twin turbo DI V6 .....(Motorcraft synblend 5W30 SN+)
'19 GMC Terrain 1.5 turbo DI I4....(Warren 0W20 1DexosGen2)
'16 Moto Guzzi NTX 1151cc v-twin (Eni 10W60)
Re: Mobile 1 in a Subaru Manual transaxle? [Re: nthach] #5329630 01/22/20 03:12 PM
B
B
Diff type really has nothing to do with it, it's keeping the manual transmission's synchros happy is the problem. Subaru's own Extra-S was the best thing I ever put in mine but I don't believe they make it anymore. I think Subaru has a generic MT/center diff oil now and it's not Extra-S.
Problem is once you 'contaminate' the guts with a lube it doesn't like it never seems to be the same afterwards.
Re: Mobile 1 in a Subaru Manual transaxle? [Re: someoldguy] #5329632 01/22/20 03:15 PM
N
nthach Offline
N
The exceptions to the rule where GL-5 should not be run in a manual transmission besides the forementioned NV4500 or any transmission calling for a MTF are Toyota, Tremec, Honda and Mazda gearboxes. Toyota wants GL-4 fluid safe for yellow metals, as the organosulfur compounds in GL-5 fluids affect them. Tremec and Mazda call for ATF, and Honda wants their own fluid, in the past they said 10W-30 motor was fine until the API specs were updated to SM/SN.
Re: Mobile 1 in a Subaru Manual transaxle? [Re: Bottom_Feeder] #5329634 01/22/20 03:16 PM
L
LoneRanger Offline
L
Diff type really has nothing to do with it, it's keeping the manual transmission's synchros happy is the problem. Subaru's own Extra-S was the best thing I ever put in mine. Problem is once you 'contaminate' the guts with a lube it doesn't like it never seems to be the same afterwards.
The center differential in manual transmission Subaru is a viscous type, is a sealed unit, and does not share the gear oil that's shared between the manual transmission and the front differential. Confused yet? It's Subaru, they're weird. Cool as heck and great vehicles, but a little different from the norm !!
