Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
This is a good example of engineering today.
by Exhaustgases - 02/16/20 04:25 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
115 registered members (762fermeandyou, Aichiguy, 4WD, alchargo, AndyB, 53' Stude, 12 invisible), 2,674 guests, and 37 spiders.
Topics301,518
Posts5,197,175
Members70,712
AMSoil Signature / AMSoil European - 5-40 #5329488 01/22/20 12:06 PM
3
335xiE92FBO Offline OP
3
New to your forum. I spent an hour searching and didn't find much AMSoil Euro or Signature information. If there's and existing thread speaking to N54s, please send me a link.
2008 BMW 335xi E92 sport with FBO (full bolt-ons) minus turbo inlets. The car makes 420 last dyno 3 months ago. My local shops are all over the board on oil recommendations. I've been using Amsoil European 5.40 but see that Amsoil Signature appears to be a better choice. N54s run hot (240 is normal operating temperature, too f*cking hot), I run a CSF Street radiator, a low-temperature oil cooler thermostat and in the summer I set MHD to track cooling which runs the fan pretty much constantly and am known to use an oil cooler thermostat delete. As a result, I maintain oil temperatures less than 210F in >100F weather.
All that said, looking to make the best long term wear oil choice. I change it early and often (2-2,500 miles). Just a street racer, not tracking it.
Re: AMSoil Signature / AMSoil European - 5-40 [Re: 335xiE92FBO] #5329502 01/22/20 12:24 PM
K
kschachn Offline
K
First off, nice car. But you won't see a difference in wear using one oil over another unless it is entirely inappropriate for the engine in question, especially if you are trying to measure it via a UOA (even more so at your OCI). With an appropriate oil, wear is much more influenced by outside factors such as dirt intrusion via the intake system.
Since neither one of the oils you list have the required specification for your vehicle then I would suggest you use the one Amsoil recommends, which I'm guessing is the European Car Formula 5W-40. What would indicate that the Signature Series is better?
One of the reasons you may not see a lot of BMW users using Amsoil is that it does not carry any BMW approvals. But the EFM and AFL do have Porsche A40 approval which is a very demanding approval.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: AMSoil Signature / AMSoil European - 5-40 [Re: 335xiE92FBO] #5329517 01/22/20 12:40 PM
B
BMWTurboDzl Offline
B
Fuel dilution was allegedly an issue with the N54 and consequently Terry Dyson (former forum sponsor and tribologist) at the time was recommending an extremely short interval. I don't see why any ACEA A3/B4 on your 2k OCI would not be adequate.
Your power levels aren't an issue. BMW is running oils LL01FE(A5/B5) with an HTHS of 3.0 on engines making well over 420 hp. That's lower than the A3/B4 (LL01, A40, 229.5) which have a HTHS of 3.5 or more.
435i
Re: AMSoil Signature / AMSoil European - 5-40 [Re: 335xiE92FBO] #5329561 01/22/20 01:45 PM
J
JLTD Offline
J
Yeah, Amsoil is wasted on that short of an interval for sure.
Lates.
Re: AMSoil Signature / AMSoil European - 5-40 [Re: 335xiE92FBO] #5329609 01/22/20 02:36 PM
sloinker Offline
Ravenol if you want certifications and Red Line if you want the best oil for heat and shear imo.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: AMSoil Signature / AMSoil European - 5-40 [Re: BMWTurboDzl] #5329621 01/22/20 02:58 PM
3
3
Fuel dilution is definitely a big issue. Forgot to mention I just installed a RADIUM oil catch can system.
http://www.radiumauto.com/Universal-Dual-Catch-Can-P189.aspx
Re: AMSoil Signature / AMSoil European - 5-40 [Re: 335xiE92FBO] #5329709 01/22/20 05:13 PM
B
BMWTurboDzl Offline
B
That was a good idea for that particular engine.
435i
Re: AMSoil Signature / AMSoil European - 5-40 [Re: 335xiE92FBO] #5329756 01/22/20 06:11 PM
E
edyvw Offline
E
Do you have updated injectors? I would definitely do UOA not bcs. of wear numbers, but to see what is actual fuel dilution, remaining TBN etc.
As for Amsoil, you can definitely run it, but IMO, any LL01 or MB229.5 oil will cut it.
I just got at the Advance Auto Parts Pennzoil Platinum Euro 5W40 on sale for my 328. $33 for 5qt plus filter (though I got filter for my minivan).
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: AMSoil Signature / AMSoil European - 5-40 [Re: kschachn] #5329767 01/22/20 06:22 PM
B
Bjornviken Offline
B
+1
Re: AMSoil Signature / AMSoil European - 5-40 [Re: 335xiE92FBO] #5329787 01/22/20 06:51 PM
M
MCompact Offline
M
Do a UOA- otherwise you are just guessing.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: AMSoil Signature / AMSoil European - 5-40 [Re: 335xiE92FBO] #5332557 01/26/20 09:15 AM
M
Mau Online Sleepy
Online Sleepy
M
Pennzoil Platinum Euro 5w40 is what I use in my modded C43.
17 MB C43 AMG - Pennzoil Platinum Euro 5w40
