International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
113 registered members (ammolab, 1978elcamino, alex_at, Aichiguy, 28oz, 01VFR, 8 invisible), 2,395 guests, and 20 spiders.
Topics301,905
Posts5,205,137
Members70,798
Tracing wires in walls #5329458 01/22/20 11:32 AM
Dave Sherman Offline OP
Some yutz who had my house before me did some amateur wiring in the basement. Trouble is, the house has aluminum wire, but he added in copper. Based on the Cu-Only outlet that burned up because it was attached directly to the aluminum, I'll bet he didn't know anything about aluminum and just joined the copper and aluminum together. Second problem is, I don't think he did the junction inside any of the existing outlets or switches, because I can't find where the original aluminum meets the new copper; all the boxes I've looked in either have all copper that looks new or all aluminum that looks original. Is there a nice way of finding where the wires are routed without having to take down the drywall? The gizmos that plug into an outlet and have a sounder to trace it all look ridiculously expensive; it would be cheaper to just replace all the basement drywall.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Tracing wires in walls [Re: Dave Sherman] #5329485 01/22/20 12:05 PM
M
maxdustington Offline
M
You need a wall scanner. It sounds like this is a job that would be worthy of a purchase, but that's not a tool that will be used much after this job although it would be handy to have.
You could try renting one, but I think hiring someone might be more expensive than the tool itself.
https://www.amazon.ca/Walabot-DIY-Plus-Advanced-Smartphones/dp/B07XP94548/ref=dp_ob_image_def I googled wall scanner and this came up first, I thought they were much more expensive than that.
99 Toyota Tercel CE 5EFE/C151
Re: Tracing wires in walls [Re: Dave Sherman] #5329511 01/22/20 12:31 PM
Donald Offline
There are a 1000 and one ways a wanna-be electrician could have done wiring not up to code. Boxes buried behind drywall is up there on the list. Non grounded boxes. Using 14-2 with ground when you needed 14-3 with ground. Using the "quick" outlets where you shove a wire in the back and a spring loaded contact makes the connections and hold the wire in place. Putting electrical tape over a switch or circuit breaker (don't use) but never fixing the problem. Wires jammed into a box vs neatly folded. Twisted hot or neutral wires and then duct tape over connection. Junctions not in a box. Branch box with combined ground & neutral bus.
One way to get your home safer (in my view) is to install all arc-fault breakers for every 15 and 20 amp 110V circuit. That way if something does happen the arc-fault should catch it.
2015 Ford F-250 w/Powerstroke
Re: Tracing wires in walls [Re: Donald] #5329541 01/22/20 01:21 PM
M
Miller88 Offline
M
Had that sitting on the ceiling drywall above my living room.They just twisted the wires together and taped over them. Wonder why the lights flickered when the washing machine ran.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Tracing wires in walls [Re: Miller88] #5329547 01/22/20 01:29 PM
Donald Offline
WIre nuts cost money. Tape is cheap.
Re: Tracing wires in walls [Re: maxdustington] #5329564 01/22/20 01:49 PM
diyjake Online Content
Online Content
Does this scranner really work? I don't know why but it sounds too much like a gimmick.
Re: Tracing wires in walls [Re: Dave Sherman] #5329569 01/22/20 01:54 PM
O
Oily_Thing Offline
O
You could have a real (dangerous) mess on your hands. Like Donald said, there are a million and one things that a hack could have done. You might want to hire a licensed electrician to look it over.
2020 Nissan Rogue SL AWD times two! (white and black)
Re: Tracing wires in walls [Re: diyjake] #5329595 01/22/20 02:19 PM
M
M
I have no idea but I know "real" wall scanners are a few hundred bucks. The reviews do not look so good for that one, but you could always just return it if it didn't work.
Re: Tracing wires in walls [Re: Oily_Thing] #5329645 01/22/20 03:43 PM
M
M
I wouldn't want to pay electrician's wages for that job. Any idiot can fish new wires. Also, they will most likely indiscriminately destroy drywall, increasing the price and scope of the work. Electricians don't like working on houses.
Re: Tracing wires in walls [Re: Dave Sherman] #5329830 01/22/20 07:36 PM
Snagglefoot Offline
Here is a few wild ideas. Remove and check any ceiling light fixtures and check in the box. Check plug boxes even if they are in adjacent rooms. Does your basement have a hanging ceiling? If so remove a few panels and take a look up there.Buy one of those circuit testers you plug into a socket and check all the sockets for problems. Good luck.
If you want the job done right......do it yourself.
Re: Tracing wires in walls [Re: Dave Sherman] #5329885 01/22/20 08:55 PM
O
Oldtom Offline
O
Harbor Freight has a cable tracker for about 30 bucks. Here is a cut and paste of a review. Sounds like it might help you:
Tells you where the wires are! UNDER sheetrock even
Wow! We lost a circuit in the house we recently moved into... really strange, circuit breakers all intact, no tripped breakers... break in wire in wall? hooked this tracer up to the dead circuit (after shutting off master power to house) and within 10 min was led to a GFCI outlet in the garage I never knew about! Resetting it had power to the circuit again. Saved possibly thousands not calling an electrician... even if they had found it quickly they would have charged many hundreds of $$. Now I have a very useful tool in case of other electrical problems. Win-win.
Re: Tracing wires in walls [Re: Dave Sherman] #5330080 01/23/20 07:54 AM
Thanks Oldtom, I'll check out the HF one, looks like I can't go wrong on the price. Thanks all, it's been interesting so far, I've gathered from the realtor that the house was a flipper. He may have made it look pretty, but took shortcuts and didn't do anything to improve it structurally.
