Cartridge Filter Question
by Tundra73 - 02/25/20 01:21 PM
Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
109 registered members (ABerns, aquariuscsm, alex_at, AlaskaMike, bbhero, Astro_Guy, 8 invisible), 2,397 guests, and 21 spiders.
Topics301,910
Posts5,205,213
Members70,800
Steering Lubricant Suggestion #5329440 01/22/20 11:08 AM
L
lancerplayer Offline OP
L
What lubricant is suitable for these steering components? The application is an off road vehicle (Polaris Ranger).
[Linked Image from i.ibb.co]
Re: Steering Lubricant Suggestion [Re: lancerplayer] #5329444 01/22/20 11:15 AM
N
nthach Offline
N
Look for a port for a flush-tip grease gun needle or a Zerk fitting can thread into. If you have one, use any good quality non-moly grease for those U-joints.
Re: Steering Lubricant Suggestion [Re: lancerplayer] #5329539 01/22/20 01:20 PM
V
vavavroom Offline
V
If the service manual doesnt say what use, I'd go with a water resistant CV joint lube.
Re: Steering Lubricant Suggestion [Re: lancerplayer] #5329540 01/22/20 01:20 PM
O
Olas Offline
O
How exposed is the joint? If its protected or out of the way id be tempted to clean it, moly-grease it and put a boot or gaitor over it.
Re: Steering Lubricant Suggestion [Re: lancerplayer] #5329571 01/22/20 01:55 PM
O
Oily_Thing Offline
O
Don't use moly grease on ball or needle bearing joints.
2020 Nissan Rogue SL AWD times two! (white and black)
Re: Steering Lubricant Suggestion [Re: lancerplayer] #5329624 01/22/20 03:03 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I would use a calcium based grease, grade 1.5. Calcium to resist washout; grade 1.5 because you don't want to use anything too heavy for micromotion application.
Re: Steering Lubricant Suggestion [Re: lancerplayer] #5329670 01/22/20 04:19 PM
L
L
I checked the service manual. There is no mentioning of lubricating these joints, but I figure any lube is better than none.
Re: Steering Lubricant Suggestion [Re: lancerplayer] #5330280 01/23/20 12:12 PM
Srt20 Offline
Those are sealed. Not meant to be lubed.
