Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
Advise for Euro E36 M50 engine
by Lucase483 - 02/23/20 05:43 PM
Those with 5.3's weigh in
by Speak2Mountain - 02/23/20 04:26 PM
wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
wjamyers, L00btech, Lucase483, Chaucha, UofA
70790 Registered Users
30 registered members (Black_Thunder, Dan55, blufeb95, 750IX, Char Baby, Dave_Mark, 4 invisible), 1,008 guests, and 28 spiders.
Topics301,852
Posts5,203,963
Members70,790
Open up area in basement #5329298 01/22/20 07:42 AM
R
redhat Offline OP
R
My basement has 3 sections. At the bottom of the stairs is an area with the washing machine and dryer, next to that is a somewhat finished room (that I am renovating) for an office and then there is an opening that goes to the other part of the basement with the furnace, water tank, electrical panel, etc.
In renovating this office, I have been thinking about taking down the walls that separate the laundry area from the office and make it one big area. I am thinking this would be nice to allow natural light from both of the windows to really brighten the area during the day. Also, these walls are making these areas seem small. The only thing I am thinking is how to transition from a studded and dry walled wall to the concrete basement wall. Below I drew a little picture. I want to take out the walls with the "X". My thoughts are to also laminate the rest of the floor. Maybe a header where the old wall used to be.
[Linked Image from i.imgur.com]
19 F150 2.7 - M1EP 5W-30, FL2062, 11k
17 Taurus Limited AWD - M1EP 5W-20, FL500S, 30k
84 JD 316 Repowered w/Vanguard 18
Re: Open up area in basement [Re: redhat] #5329300 01/22/20 07:49 AM
B
BISCUT Offline
B
No true knowledge of the construction of your home but from drawing I'd ask if you have a steel girder or are there lolly columns buried in your current walls. If no girder you can still remove the walls but probably have to keep the lollies in place (you can just wall them each individually).
2015 F150 Lariat M1 5-30 EP FRAM Ultra(44k)
2017 Sub OB M1 5-30 EP FRAM Ultra(74k)
Re: Open up area in basement [Re: BISCUT] #5329303 01/22/20 07:52 AM
R
redhat Offline OP
R
I am not sure but I would just wall any lollies I find.
Re: Open up area in basement [Re: redhat] #5329311 01/22/20 08:05 AM
PimTac Offline
Verify that any walls you want to remove are not bearing walls.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Open up area in basement [Re: redhat] #5329313 01/22/20 08:09 AM
Donald Offline
I have yet to see a basement that had a studded wall as a load bearing wall. Its either an I-beam or lolly columns. The wall could be hiding lolly columns.
I would stud and insulate the basement concrete walls.
2015 Ford F-250 w/Powerstroke
Re: Open up area in basement [Re: Donald] #5329356 01/22/20 09:04 AM
J
JLTD Offline
J
Yep before doing anything else you need to know where the structural supports, if any, are placed.
Lates.
Re: Open up area in basement [Re: redhat] #5329371 01/22/20 09:13 AM
W
WyrTwister Offline
W
If you wish to have dry wall where there is currently only bare concrete , it is common to attach studs ( either wood or metal studs ) to the concrete to provide a space for electrical , plumbing and insulation . Then nail / screw the dry wall to the face of the studs .
To provide future access , i would install a 2' x 4' lay in ceiling + insulation .
Wyr
God bless
Re: Open up area in basement [Re: redhat] #5329374 01/22/20 09:15 AM
dbias Offline
I'd say the load bearing wall is the one separating the has the opening to the other half of the basement
2011 VW JETTA RIP totaled at 180k 😥
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
Re: Open up area in basement [Re: Donald] #5329393 01/22/20 09:48 AM
PimTac Offline
I mentioned this because it might be the case that a previous owner may have taken out supporting joists and beams and put in a stud wall as a replacement.
2017 Mazda CX5
Roki OEM filter.
Re: Open up area in basement [Re: PimTac] #5329428 01/22/20 10:42 AM
Donald Offline
I would worry about someone who removed lolly columns and installed a stud wall unless an engineer was involved in the design. I do not think a plain stud wall can carry the weight. Maybe if it was an overbuilt stud wall.
Re: Open up area in basement [Re: redhat] #5329439 01/22/20 11:05 AM
M
maxdustington Offline
M
Anyone in this thread who mentions a load bearing wall in a basement in this thread has never swung a hammer. Basements use posts for support, not walls.
There are probably posts in the current partition wall, you can just enclose them with drywall. As mentioned above, you have to frame or strap the exterior walls of the basement to accept drywall. If you want insulation, frame them. If you just want to get some drywall on them so they will match just get some 1x, 2x or metal stud furring strips and screw them to the wall with tapcons or framing spikes/construction screws and wire. The hard part will be making sure those strips are level and even enough that you can hang drywall from them. You might be better off with a 2x2 framed wall over straps if they walls are really out of whack. I would vapor barrier even if you don't insulate to protect the drywall from moisture damage, and I would prefer metal studs for the same reason.
I would also enclose the utility area and insulate the walls for sound. You could reuse your old office door there.
99 Toyota Tercel CE 5EFE/C151
Re: Open up area in basement [Re: redhat] #5329445 01/22/20 11:15 AM
R
redhat Offline OP
R
I could extend the drywall down and encase the rest of the newly opened up larger room, but I was trying to get ideas for leaving the 2/3 remaining finished walls and tying them in with the unfinished concrete in a way that looks good.
Re: Open up area in basement [Re: redhat] #5329456 01/22/20 11:28 AM
PimTac Offline
“Anyone in this thread who mentions a load bearing wall in a basement in this thread has never swung a hammer. Basements use posts for support, not walls.“
I have been in a basement where the posts were removed and the area was walled off. It was one of those shake your head moments.
Anything is possible.
2017 Mazda CX5
Roki OEM filter.
Re: Open up area in basement [Re: redhat] #5329481 01/22/20 12:00 PM
M
M
I've been in basements like that too, a beam was being installed to remove the posts and the walls were temporary. I didn't say it was not possible. I said basements use posts for support, not walls.
If you are OK with a drywall to concrete finish, just frame in that header that you mentioned earlier and drywall it.
You could do something similar to a door casing with a piece of trim on the edge of the drywall, a plain piece at right angle to that to cover the difference in depth of the drywall to the concrete, and then another piece of trim on the concrete itself.
If the gap is smaller you could try to get away with a single piece of trim to cover the gap similar to quarter round or shoe mould.
It's hard to recommend anything without actually seeing it. The severity of the transition between the concrete will determine what needs to be done but I like your header idea.
Re: Open up area in basement [Re: PimTac] #5329489 01/22/20 12:07 PM
Donald Offline
My home has a couple of 6x6 posts that appear to be supporting a steel I-beam. Were there before I bought the house and are still there. Building inspector was in the basement looking at some plumbing and sad nothing.
So maybe prior homeowner thought they would be a good idea or they added on a story to original house. I would think lolly columns would required if the I-beam was not strong enough without support. Lolly columns are placed over a footing under the floor. Not just on the floor.
