Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
47 registered members (ArgleBargle, Amkeer, bbhero, BlakeB, AZjeff, bmod305, 5 invisible), 1,174 guests, and 25 spiders.
Topics301,934
Posts5,205,768
Members70,801
Briggs Intek Leaking Crankshaft Oil Seal #5329261 01/22/20 06:26 AM
U
UncleNorby Offline OP
U
I have a 20hp Briggs Intek engine that leaks at the shaft oil seal. I replaced it an seated the seal down to the inner shoulder, because that's where the old seal was. It began leaking again. I looked around on the internet and saw that the seal should not be seated that deep, so I replaced it again. This time I seated just below flush. I ran the engine a bit over the weekend, but noticed it leaking again last night. There is an oil re-circulation hole below the inner shoulder, so the seal was not interfering with that in either situation. Does anyone know what may be going on? I saw a product by Blue Devil that is supposed to fix leaky seals. Has anyone tried it? Thanks for any advice!
Re: Briggs Intek Leaking Crankshaft Oil Seal [Re: UncleNorby] #5329271 01/22/20 06:48 AM
E
Eddie Offline
E
Is the crankcase pressurizing because of the vent hose being plugged? Ed
2014 CX5 Touring 2.5L :-)
Re: Briggs Intek Leaking Crankshaft Oil Seal [Re: Eddie] #5329285 01/22/20 07:06 AM
J
jeepman3071 Offline
J
+1
Also these engines like to blow head gaskets, and it could be pressurizing the crankcase. Does it burn any oil?
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (58k) - Liqui Moly 5w40, MANN HU816X
Re: Briggs Intek Leaking Crankshaft Oil Seal [Re: Eddie] #5329289 01/22/20 07:12 AM
supton Offline
On a new-to-me snowblower I found it kept kicking out the seal under the flywheel. Some 179cc Briggs. After pushing the seal in a second time I poked around and found that the breather hose from engine to airbox didn't have a hole in the airbox. Like it was casting flash over the hole. I zipped in a hole and no more issues.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Briggs Intek Leaking Crankshaft Oil Seal [Re: UncleNorby] #5329319 01/22/20 08:15 AM
E
edwardh1 Offline
E
wonder who makes the airboxes- sounds like a manufacturing defect
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Briggs Intek Leaking Crankshaft Oil Seal [Re: edwardh1] #5329437 01/22/20 10:56 AM
SubieRubyRoo Offline
Probably 5 letters long, starts with sea...
De omnibus dubitandum.
Re: Briggs Intek Leaking Crankshaft Oil Seal [Re: SubieRubyRoo] #5329611 01/22/20 02:41 PM
R
Rand Offline
R
did you mean 6 letters?
Re: Briggs Intek Leaking Crankshaft Oil Seal [Re: UncleNorby] #5330179 01/23/20 10:08 AM
U
U
I will check the vent hose. Thanks!
Re: Briggs Intek Leaking Crankshaft Oil Seal [Re: Rand] #5330180 01/23/20 10:09 AM
1
1978elcamino Offline
1
C.H.I.N.A. I believe that is the direction subie was going. Some 8yr old may loose their job at the factory because of this post.
2018 F150 5.0
2016 Ford Fusion 2.5
