school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
112 registered members (28oz, 92saturnsl2, 53' Stude, 94astro, 2003f7, 1978elcamino, 9 invisible), 2,330 guests, and 29 spiders.
Topics301,660
Posts5,200,124
Members70,751
Page 1 of 3 1 2 3
Project Farm Lucas transmission additive video #5328599 01/21/20 09:43 AM
1
1978elcamino Online Content OP
OP Online Content
1
I recently saw a project farm video that was about a high mileage honda accord v6 automatic that had some odd shifting going on. Some shifts were latent and appeared to him as slight slippage. He added the Lucas additive and the video showed overall shifting improvement. What I thought was interesting was the VOA from Blackstone on the Lucas. Basically, the Lucas has just about no additives but a very high viscosity index. So the conclusion was the Lucas makes the fluid thicker. As I suspected, magic transmission rebuild in a bottle is snake oil that raises the viscosity and nothing more.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328603 01/21/20 09:47 AM
old1 Offline
I am NOT a fan of Lucas, but is the transmission product also a vI improver like the engine oil product, or something entirely different?
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328609 01/21/20 09:57 AM
M
mpack88 Offline
M
I just put some in a 2001 Saturn SL1. It was slipping real bad between 2 and 3 I added that bottle and the slipping stoped imediately. It don't fix anything but if it can prolong its life for a little old Saturn then it's worth it to me.
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328621 01/21/20 10:15 AM
K
kschachn Offline
K
Blackstone measures viscosity index? How?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Project Farm Lucas transmission additive video [Re: kschachn] #5328632 01/21/20 10:33 AM
1
OP Online Content
1
Maybe Im wrong on that, I watched it last night. IIRC he said in the video that it raises viscosity and makes it thicker.
2018 F150 5.0
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328659 01/21/20 11:07 AM
SVTCobra Offline
They measured the viscosity, not the viscosity index. I think in general when you see a high viscosity oil in an application that normally calls for a thinner oil, such as transmission fluid, you could assume it's a VII instead of a thicker base oil.
A VII will not get diluted as easy as just a thicker base stock, and therefore more functional. The instructions say to use 24 oz in a transmission which in my F150 has a capacity of 16-17 quarts.
Think twice, speak once.
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328674 01/21/20 11:40 AM
RDY4WAR Online Content
Online Content
It's just a bottle of heavy olefin copolymer with a really poor shear stability index.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Project Farm Lucas transmission additive video [Re: RDY4WAR] #5328682 01/21/20 11:49 AM
O
OVERKILL Offline
O
This. It made the fluid thicker. It did not improve on any of the characteristics of the existing fluid and in fact it diluted them with cheap, heavy brightstock. But the thicker fluid changed the behaviour of the unit so perception is that it "works".
Re: Project Farm Lucas transmission additive video [Re: OVERKILL] #5328728 01/21/20 12:32 PM
1
OP Online Content
1
Got it, that makes sense.
I also wondered why someone would use their oil product. Example; the vehicle specs 5w20, next OCI use 10w30 or maybe even a 15w40. This results in a full add pack and thicker oil instead of diluting the current fill with a quart of lucas.
2018 F150 5.0
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328751 01/21/20 12:56 PM
Online Content
By making the fluid more viscous, it increases charge pressure which puts more pressure on the clutch packs to grip. The problem with that is it increases pressure to every other part of the transmission including the torque converter. I've torn down a few engines with eaten up thrust bearings because of high charge pressure pounding the converter and flexplate causing the crank to want to walk forward in the block. This isn't a realistic issue with a small dose, but not a direction you want to go.
Re: Project Farm Lucas transmission additive video [Re: kschachn] #5328795 01/21/20 01:55 PM
Brian553 Offline
No metallic additives. VOA won't show ashless additives.
I agree; I don't think it's a good idea to use it.
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328828 01/21/20 02:42 PM
SubieRubyRoo Offline
Only trans additive I will personally use is Lubegard Red. I have heard good results of the Trans-X conditioner or whatever it is in the blue bottle for slipping transmissions, but I've never personally used it. To me, Lucas is just deceptive marketing speak for "don't use, avoid at all costs". They won't get any of my nickels.
De omnibus dubitandum.
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328850 01/21/20 03:03 PM
K
kstanf150 Offline
K
Back in the day, I had a buddy who’s dad owned a use car lot
If he had a car with a slipping trans he’d put a couple of cans of STP in the transmission to get it through the auction sale.
It worked for a short time not sure how it worked long term
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328933 01/21/20 05:08 PM
T
thastinger Offline
T
Before Forest Lucas started selling his snake oils, sawdust was used to do the same thing
Re: Project Farm Lucas transmission additive video [Re: 1978elcamino] #5328935 01/21/20 05:10 PM
caprice_2nv Offline
I think it will help out a transmission on its last legs like the one in the video because the extra viscosity is obviously helping with the slipping clutch packs. It would be nice if there was actually thicker fluid than stock fluid available that still meets the specs for certain transmissions, that might help when the transmission is starting to get on the lazy side.
This might delay getting to the state where it's actually slipping badly like the one in the video. He admitted that it's still going to fail anyway, probably in the next 10-15k miles. That's the only case where I would bother with the Lucas. If you plan on rebuilding the existing transmission, the Lucas could be a bad idea if the extra viscosity and pressure hurts other parts of the transmission by the time you go to rebuild it.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Page 1 of 3 1 2 3
