Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
This is a good example of engineering today.
by Exhaustgases - 02/16/20 04:25 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
100 registered members (aba4430, 762fermeandyou, 97prizm, Ada_Potato, 01VFR, 2015_PSD, 7 invisible), 2,608 guests, and 36 spiders.
Topics301,518
Posts5,197,140
Members70,712
Page 1 of 4 1 2 3 4
Should I Stick With My Truck? Buy "new"? #5328229 01/20/20 08:04 PM
M
Miller88 Offline OP
M
My truck is a 2001 F350. BASE model - only options are 4x4, LS rear and heavy service suspension. No AC, no power windows, vinyl seat ... the only thing I would like is AC.
LOTS OF RUST!!!!!
I got it for "free" from my parents a few years back at 58000. However, I did have to do the below to it:
- Engine $550 --- engine has 225K, truck is at 70K
- Radiator, coolant hoses $200 (I got a good discount)
- Intake Manifold $175
- Coils / spark plugs $150 (used OE coils)
- Starter $75 (got a good discount on new)
- Ball Joints / Wheel Bearings / U Joints in front axle - $1100
It sat for 10 years after my dad had some serious health issues. So it rusted pretty badly from sitting in a gravel driveway. Real bad rust.
I have been using it mainly for towing. The bed is way too shot to use for truck stuff. But I have towed my Jeep all over with it, towed a F250 back from Vermont. I have a "trust" range of about 200 miles or so ... because that's why my AAA membership is. For the most part, I can't imagine doing too much to my Jeep that I wouldn't be able to drag my trailer with Surge brakes home on back roads if needed. Short of a serious mechanical failure.
However, we're starting to do a lot longer runs. This year we are going to Maine and down to VW, along with local stuff and trips to the usual spots in PA. Probably about 3500 miles of towing my Jeep. Definitely out of my comfort zone with this truck. Especially the 450 mile (one way) Maine trip.
The truck is 20 years old. The transmission is physically broken and has been for some time.
So here's some things that the truck needs:
- New Bed $2800 minimum for the 8' steel superduty bed
- Transmission fixed ($1000 to have someone pull and install the transmission, then whatever it costs to have the case tigged together then reinstall)
----- As part of above, I'll do a new clutch, flywheel, pressure plate, slave cylinder, throwout bearing --- $350 for a good set
- Passenger door
- Shock Absorbers - $150 for a good set
"likes" would be getting a drivers side rocker panel and cab corner replaced.
Even if I went through all of that, I would have a nice looking and very functional truck. But it is still all of 20 years old. I don't know when the fuel pump is going to quit. I don't know when the water pump might go out. What if it blows out a plug somewhere? What if the 1997 F150 engine decides to scatter somewhere on the side of the road? These questions drive me a bit nuts and anytime I go anywhere I end up worrying what will break and where it will break.
I have been looking at mid size trucks. Honestly, I prefer my small fleet of utility trailers for house work. Easier to load and unload. Easy to get out of the way if needed. Getting a Ranger / Taco / Colorado with a mini bed wouldn't bother me because I could just use a trailer to move stuff around. There's no reason one of the mid size trucks rated to tow couldn't tow my Jeep on a trailer. And it would have AC! I'd get rid of my Subaru, of course, to find one that's 2 or 3 years old.
There's a lot of sentimental value in the F350, so that wouldn't be going anywhere either way. I remember riding off the dealer lot with my dad when it was brand new. Just have a new bed and some of the costlier items delayed.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Should I Stick With My Truck? Buy "new"? [Re: Miller88] #5328234 01/20/20 08:11 PM
CKN Offline
The truck you have now needs to be replaced. You have not mentioned cost to buy another truck-so I guess you can afford it. My only suggestion is to look at half-ton trucks verses smaller ones. It opens a lot more of possibilities -as far as looking at used vehicles.
Your towing experience will not be that great-towing your Jeep behind a mid-size truck.
BTW-you will get a lot of replies on here by people who don't own a truck or have never even owned one-or even towed with one.
It happens on every truck thread.
Re: Should I Stick With My Truck? Buy "new"? [Re: Miller88] #5328243 01/20/20 08:20 PM
O
OVERKILL Offline
O
What's the budget?
Re: Should I Stick With My Truck? Buy "new"? [Re: OVERKILL] #5328251 01/20/20 08:28 PM
M
Miller88 Offline OP
M
It does need to be replaced. Everytime I tell my dad that I'm towing somewhere longer distance with it, he just shakes his head and goes "you know that truck is junk right?"
A 1/2 ton would be better --- tows better and gets the same or better mileage than the midsize trucks too. As far as power goes, I don't need much. I can't imagine anything being slower than the tired old Triton in the hills. I'd be fine with the NA v6 versions of the Big three or even a Titan. But it's a size issue.
Since it will be replacing my primary vehicle, it would have to be a 4 door (regular doors, not suicide like F150 has). I can't fit a 4 door cab 1/2 ton in my driveway, even with a microbed. My single cab F-350 barely fits in the part of the driveway infront of the house. I could fit a crew cab / long bed truck in the garage without issue, though.
Originally Posted by OVERKILL
What's the budget?
Mid 20s - Mid 30s
The biggest issue I'll have used is I want a work truck! I want vinyl interior and steel wheels.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Should I Stick With My Truck? Buy "new"? [Re: Miller88] #5328252 01/20/20 08:28 PM
01rangerxl Offline
Buy another Super Duty that shares parts, but isn't rusty.
New trucks have problems too, often just out of the applicable warranty, and they are not cheap to fix.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: Should I Stick With My Truck? Buy "new"? [Re: CKN] #5328253 01/20/20 08:28 PM
F
FordBroncoVWJeta Offline
F
Op, Have you considered a Crown Vic?
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Should I Stick With My Truck? Buy "new"? [Re: FordBroncoVWJeta] #5328260 01/20/20 08:31 PM
O
OVERKILL Offline
O
crackmeup
Re: Should I Stick With My Truck? Buy "new"? [Re: FordBroncoVWJeta] #5328262 01/20/20 08:32 PM
M
Miller88 Offline OP
M
The biggest thing is the rust with this truck. If I could find a 2wd gas v8 or v10 early Superduty with no rust, I would be able to change over the axles, transmsision/transfer case and buy a bolt in kit to convert the front to leaf springs for the front axle. Mechanically my transmission is fine, just the ears where it bolts to the transmission mount have snapped off.
Yes, and with Michelin tires, of course!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Should I Stick With My Truck? Buy "new"? [Re: Miller88] #5328264 01/20/20 08:33 PM
O
OVERKILL Offline
O
What's the budget?
Mid 20s - Mid 30s
Maybe a fleet truck? Does your local utility sell off their used trucks? I know ours does and they are typically pretty spartan but well maintained.
Re: Should I Stick With My Truck? Buy "new"? [Re: Miller88] #5328272 01/20/20 08:41 PM
E
eljefino Offline
E
My f150 with 2.73 gears is sketchy for towing. Lots of clutch slippage starting off. I've towed (on a dolly) a bonneville, camry, HHR. It'd be better with 3.55 gears. You, shopping used, are going to run into more turkeys like mine vs proper trucks. At least with the long wheelbase it handles okay once moving.
I'd stay 3/4 ton and heavier. I have a dodge w250 plow truck and it's great to go 1 mph with the clutch up. My Ford can't go that slow. LOL Your dad's old truck honestly sounds perfect.
We have stake-side F250s and F350s at work, sprung for, I'd say, 10k plus lbs. Real rough riding. But they hold together.
Re: Should I Stick With My Truck? Buy "new"? [Re: Miller88] #5328273 01/20/20 08:41 PM
J
jimbrewer Offline
J
You can get a new V-8 half ton Chevy or Dodge for about 20k that will tow a Jeep all day, every day.
For some reason Fords go for a considerable premium at the moment. As a highly satisfied F-150 owner—-I wouldn’t pay it.
I’m generally in favor of running a truck forever. That’s one of the advantages of owning a truck. It can segue from first vehicle to second car to hand me down saving you and your family big bucks along the way. Unfortunately that’s not in the cards with your existing vehicle.
To my mind a Super Duty is a specialty vehicle. Unless you have something like a horse trailer to haul don’t get one. The capability of a half ton these days is just awesome. It’s not like it was even 15 years ago,
3.7L Ford
Re: Should I Stick With My Truck? Buy "new"? [Re: Miller88] #5328274 01/20/20 08:43 PM
G
gregk24 Offline
G
Why did the engine go out with such low miles?
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Should I Stick With My Truck? Buy "new"? [Re: OVERKILL] #5328277 01/20/20 08:48 PM
02SE Offline
crackmeup
Maybe a 4Runner? I hear they have what are considered to be the most comfortable seats in existence...
Re: Should I Stick With My Truck? Buy "new"? [Re: Miller88] #5328280 01/20/20 08:49 PM
02SE Offline
But seriously, take your dad with you, and then you'll have sentimental value of him being there when you buy the new(er) truck.
Re: Should I Stick With My Truck? Buy "new"? [Re: 02SE] #5328282 01/20/20 08:50 PM
O
OVERKILL Offline
O
That's a fantastic idea! thumbsup
Page 1 of 4 1 2 3 4
