Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
71 registered members (Aero540T, Aaron_Patton, brages, AC1DD, apollo18, 4 invisible), 1,110 guests, and 20 spiders.
Topics303,465
Posts5,235,633
Members71,074
75w140? #5326513 01/18/20 07:00 PM
M
mpack88 Offline OP
M
In my 1988 Ford F150 it has a rear 8.8 axle. I saw the other day after repairing the rear brakes that I have a seal leaking and it's probably the explanation of why I hear a roaring noise over 65 miles per hour. I'm plan on replacing the bearings and maybe getting the whole unit rebuilt but I want to put oil in it in the mean time should I use a thicker oil like 75w 140 to slow its leak down and how do I know if it's a track lock
Re: 75w140? [Re: mpack88] #5326520 01/18/20 07:07 PM
K
Kira Offline
K
I'd guess a thicker gear oil would leak more slowly.
Check for a rear axle code on the door jamb or have the VIN run at a dealership.
I don't know if there's a tell-tale sign like a differently shaped diff cover.
Where would you go for the rebuild? Ask them.
Re: 75w140? [Re: mpack88] #5326521 01/18/20 07:08 PM
L
Linctex Offline
L
Make sure the rear diff vent is not plugged!
Re: 75w140? [Re: mpack88] #5326532 01/18/20 07:33 PM
Slick17601 Offline
I would go with an 85W-140 conventional gear lube.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: 75w140? [Re: Kira] #5326533 01/18/20 07:34 PM
M
mpack88 Offline OP
M
Ford, at least my local dealer don't help much with older vehicles. I've tried before with the VIN and he will say it don't show up, then he will ask what year I'll tell him 88 and he says that's why. They don't support older fords for some reason. At least fairway ford in greenville sc. So no help there. I can look for parts here with year and model but nothing specific to its VIN.
Re: 75w140? [Re: mpack88] #5326739 01/19/20 04:31 AM
L
Langanobob Offline
L
One way to check for a limited slip differential, if it is working, is jack up both rear wheels off the ground. With parking brake off rotate one of the tires in a forward direction. The other tire will rotate in response; in reverse direction if the differential is open and forward if the differential is a limited slip.
You can also log on to Ford-trucks.com with your axle code in hand and ask there. Those guys know everything.
Re: 75w140? [Re: mpack88] #5326843 01/19/20 09:32 AM
CT8 Offline
75W-140 is a good choice.
2015 F150 2.7
2018 F350 6.2
Re: 75w140? [Re: mpack88] #5326851 01/19/20 09:39 AM
L
Lubener Offline
L
Worth a try but it didn't help me with my 87 f150 (8.8) when the axle shaft seal leaked two years ago. A new seal did, my bearings were still good..
The "thinking" man's friend.
Re: 75w140? [Re: Lubener] #5326914 01/19/20 10:54 AM
M
mpack88 Offline OP
M
Was it difficult? I never messed with a differential before?
Re: 75w140? [Re: Linctex] #5327122 01/19/20 03:12 PM
M
mpack88 Offline OP
M
The vent was plugged however the case was full of oil. So maybe this leak is slower than I thought. I guess I can ride a little longer until I get new bearings in it cuz it makes this roaring noise on the highway it's not real bad it's more like a vibration but I'm pretty sure it's coming from the rear. I've already had my tires checked once
Re: 75w140? [Re: Slick17601] #5327306 01/19/20 08:00 PM
Z
zeng Offline
Z
+1
Re: 75w140? [Re: mpack88] #5327525 01/20/20 06:15 AM
L
Lubener Offline
L
If you let it go too long with a bad bearing you stand to have to replace the axle shaft because it serves as the race for the bearing. You have to remove the rear cover, a couple bolts to remove a cap to gain access to the c-locks which need to be removed to pull the axle out. I would reseal both sides. I would have a good technician look at it. You will need access to a press for the bearing . Just make sure it is not a u joint causing your vibration. If you see powdered rust on it, it is bad.
Re: 75w140? [Re: Lubener] #5327835 01/20/20 01:41 PM
M
mpack88 Offline OP
M
I replaced the ujoints last summer so they should be good. Yeah I'll go to a shop and have them look at it.
Re: 75w140? [Re: zeng] #5328132 01/20/20 07:27 PM
Y
Y_K Offline
Y
+1
I had done this by mistake the first time around, and in my case it was Delo ESI 85-140. Has been fabulous in that nefarious Ford 8.8, Those are especially leaky if you have prolonged highway runs. I had that after a few coast-to-coast road-trips (although the unit had more than 200k miles by then).
Mr Zeng helped me to clear my head then, thank you. Now I pay attention to ISO numbers, apparently that is what engineers go by.
