Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
This is a good example of engineering today.
by Exhaustgases - 02/16/20 04:25 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
100 registered members (aba4430, 762fermeandyou, 97prizm, Ada_Potato, 01VFR, 2015_PSD, 7 invisible), 2,608 guests, and 36 spiders.
Topics301,518
Posts5,197,140
Members70,712
NAPA Gold vs Platinum vs Ultra in Jeep JLU #5328110 01/20/20 06:07 PM
T
The_Captain Offline OP
T
I recently upgraded to a Jeep JL from a JK. I used NAPA gold or Fram Ultra in my JK. I just found out that they now make a NAPA platinum for the 3.6 Pentastar. The JK used 5w20 and the JL uses 0w20. Any benefit using the platinum over the Gold or Ultra?
2020 Jeep Wrangler Unlimited Altitude 4x4
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: The_Captain] #5328118 01/20/20 06:16 PM
B
Bettez88 Offline
B
Only if you’re doing long oci. The platinum has worse filtration vs the gold. But like I said, if run longer oci like 15k +, then go for the platinum. If not, the gold will suffice and the ultra is beloved here on bitog
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: The_Captain] #5328352 01/20/20 10:19 PM
slacktide_bitog Offline
The Platinum is wire-backed, so it won't buckle like just about every Pentastar cartridge posted on here does. Even Fram Ultras come out twisty because the Ultra uses a plastic mesh that isn't strong enough cry
But the Napa Platinum does use a steel wire backing, so it should be stronger.
So for your Jeep, or any Pentastar, my oil filter of choice would be the Napa Platinum/Wix XP
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: The_Captain] #5328435 01/21/20 05:00 AM
T
Triple_Se7en Offline
T
I think I might have missed seeing pics of Ultra media that wasn't strong enough. I sometimes fall asleep reading stuff at BITOG......lol
1-2 BITOGERs harrassing you? Use the Ignore User feature.
Keep your Pistons Clean
2019 Hyundai Santa Fe 2.4 GDI / 2020 Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filter
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: Triple_Se7en] #5328700 01/21/20 12:12 PM
Here is a recent XG11665 run for 4k crzy
[Linked Image from iili.io]
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: slacktide_bitog] #5328764 01/21/20 01:05 PM
Z
ZeeOSix Offline
Z
Lots of cartridge filters get twisted when they are installed and the cap gets torqued on.
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: ZeeOSix] #5330025 01/23/20 05:37 AM
Skippy722 Offline
I think that’s the case. The 3 filters I’ve done on my 300’s Pentastar, including an OEM mopar, came out with a slight twist, as well as whatever filter was in our vans Pentastar.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: ZeeOSix] #5330119 01/23/20 08:50 AM
demarpaint Offline
I found that lubing the O-ring on the bottom of the filter, as well as the larger O-ring on the filter housing cap, along with snugging the cap vs. tightening to the torque spec helps reduce the twisting of the filter media a lot. I'm pretty sure it will reduce the odds of cracking the filter housing as well.
God Bless Our Troops
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: ZeeOSix] #5330228 01/23/20 10:58 AM
JohnnyJohnson Online Content
Online Content
Yes Zee I believe you've hit on the main cause of the damaged cartridge filter. My opinion is that its an engineering problem with these filters. But my opinion and a dollar something will buy you a large coffee at 7-11.
2004 Corolla 138781
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: The_Captain] #5330663 01/23/20 08:20 PM
I
IndyFan Offline
I
I've run several Ultras and they twisted, but not as bad as the original Mopar (Purolator) filter did. None of them tore or were compromised, so I don't think the twist is a big deal. I'm currently running a Mobil 1 filter, as I picked up 13 of them for $4 each on Walmart clearance. I'm at almost 5k on this OCI and will run it out to the end of the OLM. It is currently showing 45%, so I'm guessing it will go to 7.5 or 8k and then we'll take a look. I torque my filter cap to the OEM spec, so I am not sure that overtightening is causing the twist.
I did tear apart one of the Ultras and even though they twist, they are assembled VERY strongly. I had to use vice grips to get the pleats to come apart from the end caps and from their polymer mesh. The mesh backing looks alot like monofiliment, but it is very strong. I've heard that the M1 filter in this application is metal backed, but am not sure. Unless someone else knows, I'll tear it apart and will compare the two.
Here are pics of the Ultra torn apart. I'm telling you, that mesh is really strong!
[Linked Image from i.imgur.com]
18 Jeep JLUR Wrangler 3.6 25k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 22k
08 Jeep Wrangler 3.8 135k
04 Jeep Grand Cherokee 4.7 105k
99 Mercedes E430 Sport 92k
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: The_Captain] #5337352 01/31/20 01:02 PM
K
kkreit01 Offline
K
I'm on my 4th Pentastar, I haven't had a filter twist on me yet. I mainly run Napa Gold, and a few Platinums mixed in. I always put a film of fresh oil on the top and bottom of filter, and torque the cap to spec.
2017 Jeep Grand Cherokee 4x4 3.6: 0w20 PP/Napa Gold filter
2018 Ram 1500 CC Hemi: 5w20ish QSUD/Napa Platinum filter
2007 Honda Civic Hybrid: ? ?
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: The_Captain] #5337885 02/01/20 04:37 AM
B
Bighorn2500 Offline
B
I have a FRAM Ultra in a Pentastar currently running on its second 5k interval. I plan to go three or maybe four, 5k intervals and will pull and post later. In the past I get very little twist if any. Just lube the new oring and snug the cap down.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: NAPA Gold vs Platinum vs Ultra in Jeep JLU [Re: The_Captain] #5337902 02/01/20 06:05 AM
W
wdn Online Content
Online Content
W
The love for the Fram Ultra here is the Bob hive mind in action. Many people here are afraid to go past 5,000 miles on an oil and filter (another mass hysteria here). It's like people claiming its a 20K filter and by the way is better than some other brand’s 20K filter because of XYZ, but they won’t dare drive past 5K or 7K themselves in their own cars. Maybe we better play it safe and do 4K. Negates the whole purpose of buying it in the first place. Just look at how very few 20K reports there are in the used oil analysis forum.
I buy NAPA Gold, or Wix, and run them for 10,000 minimum with Castrol Edge EP, and done with it. Longer than that even. I have to remove the skid plate when I change the oil in my Tundra and once a year is plenty. I sleep like a baby. No cutting them open, no agonizing over it, not sending Blackstone my $20 either.
On my Corolla I use conventional oil and $2 Wix jobber filters and yes change it when the annoying dashboard light comes in. The engine on that car will outlast most of us.
