End of Holden...
by Shannow - 02/16/20 09:10 PM
Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
Daytona 500 engine related question
by OilUzer - 02/16/20 07:37 PM
2006 Subaru Forester 2.5 NA
by 762fermeandyou - 02/16/20 07:29 PM
DIY Paintless Dent Removal....
by dblshock - 02/16/20 07:17 PM
Bad sports teams
by 53' Stude - 02/16/20 06:42 PM
Valvoline 20W-50 Baja 1000 Race oil
by kstanf150 - 02/16/20 06:21 PM
How to stand on the roof of a Saturn Vue?
by atikovi - 02/16/20 06:09 PM
Spliceline wire connectors
by Donald - 02/16/20 05:22 PM
Found a few clearance oils at AZ today
by PantherFan88 - 02/16/20 04:55 PM
NASCAR electric
by CourierDriver - 02/16/20 04:52 PM
Valvoline Modern Engine vs Regular synthetic?
by PantherFan88 - 02/16/20 04:50 PM
Converting 1970 396 to Fuel Injection
by 007 - 02/16/20 04:47 PM
2016 frontier.
by red7404 - 02/16/20 04:34 PM
Ruger .22 SA - not a good show
by JHZR2 - 02/16/20 03:48 PM
engine maintenance Jaguar
by jssaab - 02/16/20 03:02 PM
New TSC clearance
by Greg L - 02/16/20 02:58 PM
Castrol Edge 5w20 and 5w30 Costco
by nlife - 02/16/20 02:41 PM
FlightRT, 74Widebody, mmmmmnnn, jjrockbush, eamerritt
70721 Registered Users
123 registered members (2009Caraman, 2003f7, 2015Corolla, 2002 Maxima SE, 4WD, 15 invisible), 2,063 guests, and 40 spiders.
Topics301,543
Posts5,197,634
Members70,721
Page 1 of 4 1 2 3 4
The thin grease for firearms #5327706 01/20/20 10:07 AM
F
fnbrowning Offline OP
F
Many of you know that firearms need a lube that not only ensures firing reliability, but also absorbs or suspends dirt/carbon from firing. In various forums, you hear the old saw, "If it slides, grease it. If it rotates, oil it." But the point argued around the web is that traditional auto grease is too stiff for many sliding parts, and rotating bolts found in many semi-auto firearms need something more 'stay put' than the traditional 'gun oil' that we all grew up with.
There must be over 50 specialty gun greases for sale across the web. Lubriplate, Tetra, Frog, and a new player CherryBalmz all come to mind. I think what they are trying to do is to provide ultra high lubricity, with ultra high 'stayinplacity' by mixing up a very thin grease. Most appear to be in a consistency somewhere between a 00 "Applesauce" and 000 heavy oil.
But look at what they charge! Most of these heavily-hyped gun greases are $14-$16 for a few ounces! crzy However, if I want to save money by running down to the local auto parts or hardware store, all I can find is "Normal" NLG #2 Grease with the consistency of peanut butter. Many of you know that there are less than a dozen major grease manufactures in North America. So, none of these gun grease sellers make their own grease. They must be buying a 00 or 000 from one of the majors and repackaging it to make $1000 a gallon.
My question the BITOG hive mind is: Can I take an auto grease & an auto oil and mix them to get the desired consistency? Or who do you think sells a reasonably priced semifluid grease formulated to lubricate and protect in a dirty environment with a wide temperature range?
I'm your biggest fan, Ms Blake. .
Well, the most heavily armed anyway
Re: The thin grease for firearms [Re: fnbrowning] #5327755 01/20/20 10:54 AM
JohnnyJohnson Offline
Unless you shoot a whole lot more than me this is likely a 3 to five year supply.
https://www.creedmoorsports.com/pro...=GoogleUS&pk_source=GoogleUS&pk_
I've found there just isn't room in my range box for my grease gun.
2004 Corolla 138781
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: The thin grease for firearms [Re: fnbrowning] #5327761 01/20/20 11:01 AM
L
Leo99 Offline
L
Compared to the cost of ammo, the cost of grease is trivial.
Or just spray a little LCP and be done with it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: The thin grease for firearms [Re: fnbrowning] #5327769 01/20/20 11:11 AM
B
buck91 Offline
B
I really like the breakfree CLP and LP products. I know they got a bad rep a few years back but ever since they returned to mil-spec they have been working very well for me. The LP is significantly tackier than the CLP.
As for grease, Jet-Lube offers a lot of different products. I would be they have a low # grease for you. I think valvoline greases are made in multiple weights, but I've never seen anything but #2 on the shelf.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: The thin grease for firearms [Re: fnbrowning] #5327773 01/20/20 11:18 AM
Yah-Tah-Hey Offline
Gun Oil
Re: The thin grease for firearms [Re: fnbrowning] #5327796 01/20/20 11:36 AM
O
OVERKILL Offline
O
I use the AMSOIL synthetic grease and found it worked quite well. It's definitely thinner than peanut butter, though not as thin as what you are looking for. They do produce a semi-fluid 00 synthetic grease, but it appears to be only available in a pail:
https://www.amsoil.com/shop/by-product/grease/semi-fluid-00-synthetic-ep-grease/?code=GSF35-EA
Re: The thin grease for firearms [Re: Yah-Tah-Hey] #5327807 01/20/20 11:50 AM
F
F
Only $700 per gallon!!
Originally Posted by Yah-Tah-Hey
Gun Oil
Which is not a grease. I've already got a great gun oil, it is called Mobil 1. I can take a couple of oz off the top of an oil change and keep myself supplied forever. But I need a product for "if it slides,grease it" and I was thinking the tribologists of BITOG could come up with something was wasn't $700+ a gallon! smile
Re: The thin grease for firearms [Re: fnbrowning] #5327808 01/20/20 11:52 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
There are tons of ranges of lubricants. Its just that there arent many that are heavily used in the automotive environment to get nicely packaged units to end users.
Gun product companies are providing this "value", maybe with a little manufacturing/blending of their own, and packaging it to you in a convenient for your needs size. But Im sure because typical use is miniscule, the overall volume is low, and thus costs are still high.
Its fun to play your own blender. You can try - adding oil to grease might not work - it may drop out or not - all you can do is try it.
Re: The thin grease for firearms [Re: fnbrowning] #5327820 01/20/20 12:18 PM
T
tundraotto Offline
T
I just use the mobil 1 grease when i (rarely) grease my AR's...with a toothpick
Re: The thin grease for firearms [Re: tundraotto] #5327832 01/20/20 12:35 PM
A
askani79705 Offline
A
Good from -40 to 400 degrees F,
2019 Ford F150 NAPA syn 5w20 Motorcraft Filter
2000 Chevy 2500 Silverado NAPA conv 5w30 AC Delco Filter
2012 Impala MileSYN 5w30 AC Delco Filter
Re: The thin grease for firearms [Re: fnbrowning] #5327853 01/20/20 01:00 PM
J
jjjxlr8 Offline
J
Any grease will generally be better than no grease, but most of my firearms run on no grease just fine. Why not use an automotive grease if you prefer? I've never seen a grease that was so stiff that it prevented any of my firearms from functioning properly.
1993 Toyota MR2 Turbo
2008 Mazdaspeed3
2014 Toyota Highlander XLE
Re: The thin grease for firearms [Re: fnbrowning] #5327862 01/20/20 01:12 PM
J
JohnG Offline
J
My brother used to shoot PPC in North Carolina. There were a lot of .45 Colts there as you can well imagine. Most of the old timers would mix there own slide lube from STP and Marvel Mystery Oil. You can control the blend yourself to achieve the desired consistency. I think this might be just what you are trying to achieve. Lots of ZDP, plus whatever the "mystery" is! It would stay for the entire match anyway.
It has been my experience that some gun oils like M-Pro 7 and Break Free contain a solvent that will evaporate over time leaving behind a pretty stiff residue. I avoid those in most applications. I have never seen good old Hoppes gun oil stiffen up, so that's still my go to product for thin oil applications.
Re: The thin grease for firearms [Re: fnbrowning] #5327893 01/20/20 01:45 PM
M
MGF1964 Offline
M
Lubriplate isn't a gun grease or gun oil, per se, but a food-service industry line of lubrication products, some of which shooters (including the US military at some points) chose for their uses. They make a huge line of both fluids and greases. Their oils can be found in sizes from a quart to a gallon to a pail to a drum.
Only product of theirs that I can say I use regularly for firearms is their SFL 0 grease, which I've found quite useful in firearms apps ranging from shotguns that have to shoot high volumes in all sorts of weather to some carry handguns (the rails). I like it expressly for its light consistency and relatively easy clean & replace properties.
If you want to blend and experiment, have fun and good luck.
Gotta say though, and I'm not trying to be smart***, I don't see cost per gallon as a practical concern, as I don't think I could use a gallon (or pound) of grease in a lifetime of firearms apps for a lone individual.
I think if I was looking for a semifluid, I'd get a quart (or gallon) of something from Lubriplate that meets the specs I want, or I'd consider military LSA.
JMO/YMMV
Re: The thin grease for firearms [Re: JHZR2] #5327950 01/20/20 02:37 PM
M
MGF1964 Offline
M
Yep re the convenience factor and the relatively low-volume need/usage for firearms.
I keep two greases on the bench -- Lubriplate SFL 0 and Shooters Choice Synthetic. Both are in pre-packaged syringes, and I find they meet my firearms needs and last for literally years. And I run a fairly wide assortment of guns.
Well, wait ... I also have a tube of Rig Universal. Applied to one of their sheepskin "Rig's Rag" sheepskin applicators, pretty nice stuff as a long-term protectant if you're putting a gun up for some time. But single container still lasts a very long time.
Re: The thin grease for firearms [Re: fnbrowning] #5328290 01/20/20 08:54 PM
Gun Oil
Except you'll never live long enough to use a gallon let alone a half gallon.
2004 Corolla 138781
2006 Duramax 77060
Page 1 of 4 1 2 3 4
