Yep, my fault, lets get that out of the way.
Ok, my neighbor, who has a decrepit vehicle and plenty more problems than that, texted my wife asking for a jump, so off I went.
Upon arrival, I noticed the lights on her car were on pretty bright, and she was trying to start her car. It was trying mightily, sounded like it was just barely not starting.
She informed me her battery was only three months old, and the car had been parked since Thursday. Her driveway was such that I had to pull in behind her and clamp two sets of cables together. When attaching to her car, i noticed a spark upon connecting to what thought was her positive terminal. Yes, I crossed polarity. There was only a spark, I never even fully clamped the clip to the negative terminal. However, the negative cable was clamped to positive on her end. My car, the donor car, was not running, and obviously her ignition was off too. I corrected for polarity and then started my car. Her car tried to start, and wouldn't. Behaved just as it was when I got there- barely not starting. I tried swapping my battery in- same thing. Tried bypassing solenoid- no dice. Gave the starter a few good whacks with the wrench for what that's worth. Everything remained the same, and for me that's the end of what I know to try.
My car runs like normal. Did I break anything, or is it more likely her car has the same issue it always did, whatever that is? I couldn't sleep knowing I did in some poor family's only vehicle.
EDIT: And now, really bizarrely, 15 minutes after I posted this and several hours after doing the deed, her car started and is running as normal.
