Originally Posted by 4WD
I think much of the fear comes from a bad experience when the OEM's did not adjust quickly … and even then more issues on the marine side or OPE (the two I have experienced)
I have a smaller skiff these days and only used maybe 5 times a year … so I spurge for E0 that's a buck more than regular but is also 92 octane and the motor runs great. I just add Techron Marine multi purpose …
Yamaha had issues with hoses … My dealer tossed their hoses for a couple years and used Evinrude hose until he was satisfied his make started to source the same hose.
West Marine recommends the use of ethanol in gasoline. They note that all fuels will need to be treated anyways if not used.
Quote
https://www.westmarine.com/WestAdvisor/Busting-Ethanol-Fuel-Myths
MYTH: Ethanol-blended fuels are bad and should be avoided.
TRUTH: Ethanol blended fuels (E10) are common throughout much of the United States. After the transition period from non-ethanol fuel, E10 may actually be a superior marine fuel, as it tends to keep low levels of water moving through the fuel system, keeping the system "dry". For over a decade, marine engines have been engineered to handle E10 gasoline. However, all types of fuels should be treated if they won't be used in a few weeks.
Quote
