Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Burned and boycotting!
by sloinker - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
61 registered members (2010Civic, ammolab, Ag76, alex16, 02F250XLT, 6 invisible), 1,271 guests, and 33 spiders.
Topics307,395
Posts5,310,303
Members71,843
Page 1 of 3 1 2 3
Windows 10 Upgrade Guide #5327451 01/19/20 10:59 PM
O
OVERKILL Offline OP
O
Since Windows 7 is now EOS and there have been numerous threads on this I think it prudent to have the most commonly sought Windows 10 upgrade information all in one thread. Please feel free to add your own tips and info here.
Windows 10 is a direct upgrade from Windows 7 (except Enterprise) Windows 8 and 8.1. The tool used to perform this upgrade is the Windows 10 Media Creation Tool and at this point, still provides a free upgrade path for all supported OS's.
If you wish to do a fresh install, the same tool allows you to create a bootable USB or download an ISO image to burn to disc. In the case of a fresh install, if you are running Windows 7, the key from your existing COA will work as your key for Windows 10. With later versions of Windows where the key is embedded in the BIOS you should not be prompted for a key. There have been reports of Windows 7 keys not working for 10, but I've done hundreds of installs and have not experienced it personally. A workaround if you are concerned is to do the upgrade to Windows 10 first, which will activate your copy of 10 and bind it to your hardware ID and then perform a fresh install indicating you do not have a key and it will activate against that hardware ID again.
If you are doing an upgrade, MOST drivers will be retained and continue to work with 10. There are obviously exceptions, but generally this works. This means that if you are doing a fresh install and are concerned because your OEM may only have 7, 8 or 8.1 drivers, you can safely assume that you will be able to download and use those and it is prudent to do that beforehand and put them on a USB stick in case you end up needing them for network connectivity. It's a good idea to open Device Manager and expand the Network Connections area to ensure you grab the right network controller drivers as many OEM's will have more than one LAN and WLAN option depending on how the unit was shipped. This is also the case for Display Adapters, where there is often more than one option.
On a fresh install, older Intel chipsets will have generic support like "Standard AHCI controller" and the like and you will need to find your Intel Chipset drivers on your OEM's website, as intel has either buried or removed their universal 9.x-series drivers from their website at this time.
Useful links:
ATI/AMD Video drivers: https://www.amd.com/en/support
- If you don't see a Windows 10 driver, just choose the one for the latest OS that is supported, say Windows 8/8.1 or 7.
NVidia Video drivers: https://www.geforce.com/drivers
- Same note as for the AMD/ATI drivers.
HP/Compaq support website: https://support.hp.com/ca-en/drivers
If your computer is manufactured by HP/Compaq, you may find that some of the drivers won't install, yielding a red "blocked by Administrator" box. This is easily circumvented by downloading 7Zip from: https://www.7-zip.org/ and once that is installed, right-clicking the package, going to the 7Zip menu and extracting it. You'll then be able to run the setup that was contained within the archive.
A number of the OEM's, particularly DELL and HP have released very recent BIOS upgrades that include improvements for Windows 10. Also, if you are doing a fresh install from a system that contained Windows 7, you may want to go into your BIOS and change the operating mode from legacy to UEFI.
If you find yourself in a situation where you have a device in Device Manager that doesn't have a driver and you don't know what it is you can right-click it, go to properties -> Details -> Hardware Id's, then right-click and copy the 2nd one down (without the revision) and paste that into Google. That'll typically point you in the right direction. Careful what sites you click on! You don't want to get duped into installing some "driver wizard" or "driver update tool", look for a link from an OEM like HP, DELL, Lenovo, ASUS....etc.
If you want to skip using the tool and just get an ISO image, these can be obtained from here: Windows 10 IOS images
2020 Jeep Grand Cherokee SRT Ravenol SSL 0w-40, FRAM Ultra
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327476 01/20/20 12:06 AM
bdcardinal Offline
I updated my Alienware M18 last month. One thing I noticed was I had to wait 30 days or so to do the major updates.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327537 01/20/20 07:06 AM
Z
ZZman Offline
Z
Good info. Thanks
2005 Toyota Avalon XLS 3.5 motor
2014 Ford Fusion 2.5 motor
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327541 01/20/20 07:26 AM
wwillson Offline
Administrator
Administrator
Great info, going to sticky
Thanks!
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327547 01/20/20 07:35 AM
R
Richie Offline
R
I need to do this upgrade one of these days.
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327556 01/20/20 08:03 AM
R
redhat Offline
R
Great info Overkill. The Google-ing of the hardware ID is a great tip for folks with unknown hardware.
I am happy to say that I have had my entire organization on Windows 10 months prior to the EOL.
20 Accord 2.0T - HGMO 0W-20, PLM A02, 2k
19 F150 2.7 - MCSB 5W-30, FL2062, 18k
84 JD 316 Repowered w/Vanguard 18
Re: Windows 10 Upgrade Guide [Re: redhat] #5327572 01/20/20 08:30 AM
O
OVERKILL Offline OP
O
thumbsup
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327596 01/20/20 08:59 AM
P
Pew Online Content
Online Content
P
+1 if you have an HP too check for BIOS updates. I purchase HP exclusively for my company and some of the older Elitebook and Probook G1/G2/G3 series (~2013-2016) needed BIOS/UEFI updates to work with Windows 10 to stop random BSODs. The latest BIOS updates can be updated straight from the UEFI interface, where it will check online itself.
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327625 01/20/20 09:27 AM
B
beast3300 Offline
B
Great info thanks! I upgraded 7 to 10 last week on my computers. W10 isn't as terrible as I remember or at least this build seems better? Either way I am happy with it.
'03 Regal GS L67: PPUP 5w30/FU3980
'03 Sable Duratec QS conv 5w20/NAPA Gold
'03 Lesabre Val PP 10w30/TG3387A
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: Windows 10 Upgrade Guide [Re: beast3300] #5327669 01/20/20 10:24 AM
V
Variant_S Online Content
Online Content
V
This is a good thread. Thanks for starting it and for links and other guidance.
I did two upgrades this past weekend, both ultimately successful. I am not a fan of the Win10 user interface, but the computers work as they should.
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327686 01/20/20 10:39 AM
M
madRiver Offline
M
No real pain in updating in place on a Win7 Pro machine.
It is important though to make sure you go to your laptop support site and get the specific drivers for your machine (my case Thinkpad W530). The PC was running real hot running chrome and Minecraft for daughter. After visiting the Lenovo site and getting latest drivers it went away. I think the nVidia driver is what helped as laptop has a built in video card.
Re: Windows 10 Upgrade Guide [Re: beast3300] #5327697 01/20/20 10:55 AM
MrMoody Offline
Version 1803 was a huge improvement from earlier releases.
My peeves vs. 7:
Recent documents can be handily pinned, either to programs in the Start menu or on the task bar. In Windows 7, you could drag & rearrange the pinned items into any order you wanted. Windows 10 will not.
With multiple monitors, you could slide the mouse pointer along the top edge from one to the other. W10 snags at the corners and you have to go around the snag.
Items progressively disappear from Control Panel and move to Settings, with less flexibility and options.
Programs cannot be set as default for their file types unless Microsoft approves, nor can the program do it itself.
And the most frequent frustrating annoyance supporting many computers, imagine this:
You jump in your car to go to work, and push the Start button. Instead of starting, the screen says, "Applying Ford updates. This may take some time. Do not power off your car ..." mad
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Windows 10 Upgrade Guide [Re: OVERKILL] #5327752 01/20/20 11:53 AM
69GTX Offline
So what will happen to windows 7 users that just "do nothing." When I had my first home computer with either Windows 95 or 98 I never allowed updates....didn't trust MS I guess. IIRC that system went about 5 yrs before it finally ran into issues and it came time to get a new computer and OS. With proper malware, spyware, ad blocker, and security system loaded can't the most recent Windows 7 keep on cranking for years? My Dell desktop ($550 brand new) is already 7 yrs old as it is. Works great though. All previous Dells and OS's I had failed hard within 3-5 yrs. I'm a light duty user on a basic Comcast high speed internet line just surfing the web, minimal documents. No games, no hi def, no heavy streaming or wifi. Just figured this computer would eventually fail when the OS was getting ancient.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Windows 10 Upgrade Guide [Re: 69GTX] #5327763 01/20/20 12:05 PM
Quattro Pete Offline
Possibly, but with time, as additional security holes are uncovered, they will no longer be patched by Microsoft, so your system will become vulnerable. Some of these holes might not be effectively addressed by anti-malware/anti-virus software.
Also, over time when new applications/programs come out, they may not have W7 support, so in the future if you're interested in some new piece of software, you might not be able to install it on your W7 machine.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Windows 10 Upgrade Guide [Re: 69GTX] #5327764 01/20/20 12:06 PM
O
OVERKILL Offline OP
O
It'll continue to operate just fine but will not receive any new security updates. So if there are vulnerabilities discovered in the OS, it will continue to be susceptible to them and won't be patched.
Page 1 of 3 1 2 3
