Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
109 registered members (53' Stude, 01rangerxl, 762fermeandyou, 2015_PSD, 69GTX, 390pi, 12 invisible), 2,522 guests, and 24 spiders.
Topics301,888
Posts5,204,609
Members70,796
Detroit 4-53T swap update. #5327081 01/19/20 12:54 PM
A
A310 Offline OP
A
I've now got 400 miles on my Detroit 4-53T swap into a 2009 Ford F350 and so far it's been great. I'm now learning how to program the 5R110 to shift cleaner on full throttle shifts as well as locking the torque convertor in 3rd. All in all very happy with the power delivery and overall function. Here's a quick tube video going through the gears in town.:
https://www.youtube.com/watch?v=1cOgPjSE8sc&t=8s
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Detroit 4-53T swap update. [Re: A310] #5327105 01/19/20 01:33 PM
02SE Offline
Screamin' Jimmy in a Ford. That will bother some blue oval fan boys.
I think it's cool. cool
Re: Detroit 4-53T swap update. [Re: 02SE] #5327126 01/19/20 02:16 PM
53' Stude Online Content
Online Content
Yes, thays the cats meow right there smile
Great work A310
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Detroit 4-53T swap update. [Re: A310] #5327134 01/19/20 02:28 PM
F
FlyNavyP3 Offline
F
How quiet it is in the cab makes me want to put my 4-53T into something newer vs older. I will be curious to hear how your starting aids work for you, I would imagine that the oil heater and coolant heater should be more than sufficient at the house. I'm curious if the webasto will be needed for afternoon starts at the shop or not, but I suppose you could plug it in there as well. Do you have your modulator hooked up on the rack, or are you using your foot for smoke control?
The compound turbos sure make big big airbox pressure! If you ever overhaul it, I'd be tempted to use Silver liners and silver cams with advanced timing. With all the airbox pressure you have those would do a better job of keeping that air in the cylinder. I'd probably stick with green trunk pistons over the silver cross head, mostly because of their ability to withstand more RPM.
Cheers!
Luke
Re: Detroit 4-53T swap update. [Re: A310] #5327170 01/19/20 03:58 PM
O
OVERKILL Online Content
Online Content
O
Thanks for the update, really cool! thumbsup
Re: Detroit 4-53T swap update. [Re: A310] #5327183 01/19/20 04:21 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Nice. I want one!
Re: Detroit 4-53T swap update. [Re: A310] #5327207 01/19/20 04:59 PM
P
pitzel Online Content
Online Content
P
I've toyed with the idea of putting one of those in a 1956 Chevy Bel-Air... Very cool that you were able to get it into such a (relatively) modern vehicle..
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Detroit 4-53T swap update. [Re: A310] #5327209 01/19/20 05:01 PM
M
Macsignals Offline
M
That is insanely cool... Now I want one.
-Ian A.
Mine:
2016 GMC Sierra 1500, L83 5.3L V8. Castrol Magnatec 0w20, Bosch 3502 oil filter. Daily driver.
1992 Dodge Dakota, 3.9L V6. Delvac 10W30, Napa Silver filter. Out of service for restore.
Re: Detroit 4-53T swap update. [Re: 02SE] #5327247 01/19/20 05:43 PM
J
Jarlaxle Offline
J
Fords offered Detroits for decades...F-series had 2-strokes and 8.2s, OTR tractors offered 71s and 92s. The C-series offered the 6V53 and 8.2 Detroits (though most had Cat power). When I got my class B, one of the semi tractors the school had was a Ford L8000 with a 6-71 turbo.
1979 Coupe de Ville, 542 stroker, parked for winter frown
2011 Crown Vic P71, 5W-20 NextGen, Super Tech
2011 Sportster 883, parked for winter frown I hate winter.
Re: Detroit 4-53T swap update. [Re: A310] #5327248 01/19/20 05:44 PM
N
nascarnation Offline
N
What's the vintage on the motor? I remember the 6V53 in the M113!
Re: Detroit 4-53T swap update. [Re: A310] #5327258 01/19/20 05:55 PM
A
A310 Offline OP
A
Cheers!
It is pretty quiet as the road noise is almost the same as the engine at 60-70 mph. I haven't hooked the fuel up to the Webasto yet as I have to lift my box to complete that job. I've been using the 750 watt block heater and that works great. I don't plug it in during the day and it starts fine, so that's a good thing. I'm getting a fair amount of blowby with the full power climbs and hope that reduces as the rings start to seal up again. I made a temp catch can to see how much I collect and in 400 miles I've collected 2 ounces and the airbox drain is less than an ounce. I want a closed blowby system, but not if I'm getting large amounts of oil in the blowby.:) As for the pistons I think your right, the trucks are stronger so I'll be staying with those. I'm in the process of tuning the 5R110 and should not see anymore than 2300 rpm shift when I'm done.:)
Re: Detroit 4-53T swap update. [Re: nascarnation] #5327259 01/19/20 05:56 PM
A
A310 Offline OP
A
It's a 1979 green 4-53T.:)
Re: Detroit 4-53T swap update. [Re: A310] #5327318 01/19/20 07:10 PM
B
Blkstanger Offline
B
Very nice!
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: Detroit 4-53T swap update. [Re: Jarlaxle] #5327333 01/19/20 07:21 PM
02SE Offline
Well aware. But I was specifically referring to late model Ford pickups.
Re: Detroit 4-53T swap update. [Re: A310] #5327338 01/19/20 07:29 PM
N
N
A 30 year throwback swap. That has to be incredibly rare. OK next you can put a flathead V8 in a Fox body Mustang!
