Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
106 registered members (2013ecof150, ABomb369, AC1DD, 2010Civic, 2K2AcuraTL, 762fermeandyou, 8 invisible), 2,591 guests, and 19 spiders.
Topics301,888
Posts5,204,655
Members70,796
UOA shelf life #5327025 01/19/20 12:02 PM
STIcandy Offline OP
So I've got a bit of a conundrum. I just drew a UOA sample from a 2017 subaru wrx. I'm concerned with possible fuel dilution.
I ordered a few UOA kits from a local amsoil guy for Oil Analyzers inc. He says they're back ordered an he'll call me when they come in.
I can send them to Blackstone lab but with over $100 in UOA kits on order this isn't really optimal. I've also read a lot of conversations about them not being overly precise with regards to fuel dilution.
So my question is how long is a UO sample valid for can I wait for my UOA kits? If not, should I get it out right now and is it worth sending to Blackstone labs?
Re: UOA shelf life [Re: STIcandy] #5327039 01/19/20 12:08 PM
P
Pelican Offline
P
How much does an oil analysis cost vs an oil change, that would be my 1st step if the oil change is only a few $ more that's what I'd do and also get peace of mind.
UOA are really intended for fleet or big trucks where a small savings can be multiplied by the nbr of liters of oil used.
Re: UOA shelf life [Re: STIcandy] #5327057 01/19/20 12:26 PM
Donald Online Content
Online Content
Get some from NAPA for $16/each. They may need to get from warehouse but that is a day at most. No need to spend what Oil Analyzers or Blackstone charge. NAPA gives the TBN also. No extra charge like Blackstone.
2015 Ford F-250 w/Powerstroke
Re: UOA shelf life [Re: STIcandy] #5327065 01/19/20 12:39 PM
J
jbutch Offline
J
From Blackstone labs' FAQ:
I took a sample three months ago and forgot to send it in. It’s been on a shelf in my garage ever since. Can I still send it in? Will the results still be good?
Should be fine.
As long as it's in a sealed container i believe it will be ok.
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: UOA shelf life [Re: STIcandy] #5327093 01/19/20 01:17 PM
STIcandy Offline OP
[DELETED
Re: UOA shelf life [Re: Donald] #5327094 01/19/20 01:18 PM
STIcandy Offline OP
I didn't know Napa did UOA!
Re: UOA shelf life [Re: Pelican] #5327110 01/19/20 01:42 PM
STIcandy Offline OP
Sorry my fault. I should have specified. I did change the oil and took the sample at the same time. My concern is more so the validity and fuel dilution in the sample if I don't get it out right away.
Re: UOA shelf life [Re: STIcandy] #5327145 01/19/20 02:49 PM
M
Mad_Hatter Offline
M
So does RA and Wally's sells the Wix kit via 3rd party vendor for abt $13 and that includes shipping to you, so not priced bad at all.
Re: UOA shelf life [Re: STIcandy] #5327376 01/19/20 08:24 PM
T
Talent_Keyhole Offline
T
As long as your used sample is sealed and properly obtained, should not be an issue. Agitate the the oil to mix anything that may have settled and add it to the sample bottle when received.
The Cleveland Open Cup Flash Point test by Blackstone does not test for fuel directly. They correlate the flashpoint of the oil with possible causes including fuel dilution. Manufacturers flashpoint specs vary, and even within the same brand the spec can vary depending on formulation.
I would use Oil Analyzers if you are concerned with Fuel Dilution.
Re: UOA shelf life [Re: STIcandy] #5327390 01/19/20 08:34 PM
M
Mainia Offline
M
Blackstone is not advanced enough to get accurate fuel dilution figures. Amsoil's Oil Analyzers, is sent to Polaris Labs Inc. They have the high $$$ equipment to properly give you a proper fuel dilution figure. BUT you have to play a "game" with Polaris Labs, they will give you the simple fast % with the cheap test, you call back for description of your test by a person and tell them you want the advance test that has the more accurate %. It's kind BS you have to play this game with them, but they have the equipment to get the more accurate readings. Just be forewarned the test is really only good up to 5% after that they give you a 5%> figure. If you want to order bottles and get it to Polaris through their private label 3rd party system that Amsoil uses. Amsoil or JG Lubrication it all goes to Polaris Labs. Go here, I use them at work. The owner is a retire lead engineer at Allison transmission.
https://www.jglubricantservices.com/online_store.html
Added note: I bought my 2018 Hyundai Kona AWD 1.6T knowing I would have a high fuel dilution problem and bought a 10 pack test kit from JG to watch it. And yes, I was over 5% I am a short tripper 10 miles back and forth to work in Minneapolis Minnesota. I gain as much as 1/2 liter PLUS of fuel after 1,000 miles and then it levels off. I dump at 3,000 miles in winter and go 3,750 in summers since I am on boost more then most. What you learn and a Honda 1.5T guy on here that has it worse then I did, is you learn with all the testing you don't have any worse wear then if you did not have the dilution problem. You get all worried for basically nothing. It still bugs you, I know, but you keep testing and you keep getting normal wear so eventually you give up testing and change your oil at a rough service interval and ENJOY your car. Run about 3 tests so you see you are fine and then move on like most of us fuel dilution owners do.
https://www.hyundaikonaforum.com/showcase/2018-kona-awd-1-6t-lowered.1162/
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: UOA shelf life [Re: Mainia] #5327528 01/20/20 05:29 AM
STIcandy Offline OP
Thanks for all your input. Car looks sweet! Which kit do you buy for fuel dilutions? The advanced or ultimate?
Re: UOA shelf life [Re: Mainia] #5327555 01/20/20 07:03 AM
M
Mad_Hatter Offline
M
That's a niiiiice looking ride! 👍
Re: UOA shelf life [Re: STIcandy] #5328063 01/20/20 04:59 PM
M
Mainia Offline
M
[/quote]
[/quote]
I bought the basic since that gives you fuel dilution, but I wished I did the advanced for more info. Even the oil analyst guy there I work with because he use to race Hyundai's and built engines, wished I did the next level to advanced for him to see how the engines running.
2005 Honda Civic
Re: UOA shelf life [Re: Mainia] #5328098 01/20/20 05:51 PM
STIcandy Offline OP
[/quote]
.[/quote]
OK that's good to know. It doesn't show fuel dilution being part of the test. Without looking back at it again I think the advanced has TBN and TAN. That's probably the one I'll go for.
