Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
119 registered members (AC1DD, 762fermeandyou, 2K2AcuraTL, A4nKar, 01rangerxl, 53' Stude, 14 invisible), 2,557 guests, and 21 spiders.
Topics301,888
Posts5,204,634
Members70,796
2015 Ram Engine Oil #5327024 01/19/20 12:02 PM
N
nemtulea Offline OP
N
So i have the 2015 Ram 1500 with 5.7 L Hemi and i used till now the PP Pennzoil Platinum 5w-20 engine oil with Mopar filter and i am seeing lot of mixed info about people moving to PUP Pennzoil Ultra Platium 5w-20 . I am due for other oil change in few weeks and wanted to know if i should move to PUP or stick to PP? I am in Central California weather.
Thanks,
2015 Ram 1500 Hemi 5.7L.
Re: 2015 Ram Engine Oil [Re: nemtulea] #5327027 01/19/20 12:03 PM
O
OVERKILL Offline
O
Either is fine and more than enough for the application assuming you are going by the OLM. I prefer the FRAM Ultra filter due to its superior efficiency but the Mopar filter is just fine.
Re: 2015 Ram Engine Oil [Re: nemtulea] #5327047 01/19/20 12:17 PM
B
BAJA_05 Offline
B
You will "never" know the difference between either oil. One is very easy to find at Wal Mart and the other is not so easy to find -- being the PUP not being found.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPPP 0W20 & FU (114K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: 2015 Ram Engine Oil [Re: OVERKILL] #5327053 01/19/20 12:22 PM
N
nemtulea Offline OP
N
@BAJA_05
Thanks for that info. Looks that Amazon has it for around $15 for 5qts.
Re: 2015 Ram Engine Oil [Re: OVERKILL] #5327054 01/19/20 12:23 PM
N
nemtulea Offline OP
N
Thank you!
Re: 2015 Ram Engine Oil [Re: OVERKILL] #5327068 01/19/20 12:42 PM
J
JC1 Offline
J
+1.
I'm using PU because it's easy to get at Canadian Tire and it was on sale during Black Friday. I've use PP previously.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 2015 Ram Engine Oil [Re: nemtulea] #5327102 01/19/20 01:29 PM
Snagglefoot Offline
Easy to get here. smile
If you want the job done right......do it yourself.
Re: 2015 Ram Engine Oil [Re: nemtulea] #5327188 01/19/20 04:33 PM
Slick17601 Offline
The Ultra Platinum is a sweet deal on Amazon right now but not a thing wrong with Platinum either.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: 2015 Ram Engine Oil [Re: nemtulea] #5327241 01/19/20 05:35 PM
N
nascarnation Offline
N
Looks like you can grab a (vehicle) lifetime stash of PUP for 16+ bucks a jug. Hard to beat that.
Re: 2015 Ram Engine Oil [Re: nemtulea] #5327328 01/19/20 07:18 PM
I
irv Offline
I
I use both as well without any concern whatsoever. If your OLM is anything like mine, it takes forever to wind down to zero.
I'm at the point now where I do 1 oil/filter change a year and the OLM still isn't at zero. I believe I currently have around 8,000 kms+ on my last OC and I am still at 60%.
I use a Fram Tough Guard, TG2, as I like the larger size. All depends on the type of service/abuse you put your Ram through?
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: 2015 Ram Engine Oil [Re: nemtulea] #5327992 01/20/20 03:29 PM
F
fijicorey Offline
F
I have the same truck and have used PP 5w-20 without issue. I even have two UOA's posted here showing how well it does. My OCIs have been around 6k with both analysis' showing I could go longer.
