Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Selling my Mustang
by SilverGt - 02/24/20 11:05 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
130 registered members (762fermeandyou, 1978elcamino, 2013ecof150, 390pi, 07titan, 928, 8 invisible), 2,577 guests, and 19 spiders.
Topics301,887
Posts5,204,577
Members70,796
2013 Escape 2.0 Ecoboost surge #5326962 01/19/20 10:36 AM
H
HoosierJeeper Offline OP
H
I have a 2013 Escape with the 2.0 Ecoboost in the family and it has a surge/shudder under light load. RPMs fluctuate by like 250. Just goes up and down constantly. It's like when you're cruising between 30-45 mph - anything under 2000 rpm. Runs completely normal at higher RPMs like on the highway. Any ideas?
19 Jeep Renegade Trailhawk 1.3T
15 Jeep Cherokee Limited V6
07 Land Rover LR3 SE V8
05 Jeep Liberty Limited V6
96 Jeep Cherokee Country 4.0
Re: 2013 Escape 2.0 Ecoboost surge [Re: HoosierJeeper] #5326979 01/19/20 11:04 AM
T
tcp71 Offline
T
Things to try:
-New spark plugs. Even low level misfires that don’t throw a CEL can cause surging. Replace the COP boots while you’re in there and use a bit of dielectric grease to make removal easier and reduce the chance of arcing.
-Dirty MAF (or MAP, depending which this engine has) sensor. Clean it.
-Slight leak in the post-turbo intake tubing. May need a smoke test to find this.
-Torn BOV diaphragm. This can have the same affect as a leak in the tubing.
-Leaking wastegate actuator tubing or solenoid. Wastegate is opening and closing when it shouldn’t. Pressure test the line from the solenoid to the wastegate at the turbo. It should hold pressure (don’t go higher than 15psi in that system, no compressors).
Also possible, but less likely is that The torque converter is locking and unlocking repeatedly making the rpms fluctuate. Not sure how to test for this without a dedicated Ford diagnostic system.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: 2013 Escape 2.0 Ecoboost surge [Re: HoosierJeeper] #5326985 01/19/20 11:09 AM
H
H
https://www.fordescape.org/threads/2015-2-0-engine-surging-sluggish.107858/
This is the exact issue, seems like the consensus was tranny fluid. This one has 115k on it, is it too risky to change it now?
Thanks for the reply! I agree new sparkplugs should be in order too.
Re: 2013 Escape 2.0 Ecoboost surge [Re: HoosierJeeper] #5326995 01/19/20 11:29 AM
T
Triple_Se7en Offline
T
I'm not into Ford products. But why would it be risky to change tranny fluid?
I had the Colorado done recently at 14Y/125K. Had the now donated Malibu done at 15Y/110K. Both are fine 1-1/2 years later.
Trolled Here? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
Re: 2013 Escape 2.0 Ecoboost surge [Re: HoosierJeeper] #5327449 01/19/20 09:58 PM
T
tcp71 Offline
T
Drain and fill the transmission a couple of times over the next 1000miles and you shouldn’t have any problems. Each time will change out half of the fluid or so. Should be Mercon LV in there.
