Rislone Gas Fuel Sys Treatment Sale/Rebate
by Jackson_Slugger - 04/03/20 03:33 PM
2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil
by apollo18 - 04/03/20 03:15 PM
FRAM Extra Guard PH16 CUT OPEN
by 53' Stude - 04/03/20 03:11 PM
CARQUEST R 84502 CUT OPEN 4,600 MILES
by 53' Stude - 04/03/20 02:58 PM
5w-20 PP Walmart & Amazon $12
by jayjr1105 - 04/03/20 02:28 PM
Chicken Marsala Recipe Help
by 97prizm - 04/03/20 02:02 PM
Oil Filter Removal
by Kansas_Ron - 04/03/20 01:24 PM
Pressure regulator made in USA
by rainman49 - 04/03/20 01:08 PM
mitsubishi outlander
by ernied - 04/03/20 12:43 PM
WM - Pennzoil Platinum $18.68
by The Critic - 04/03/20 12:13 PM
Going from a PAO to a Ester base MT oil
by Bill_W - 04/03/20 11:54 AM
Spring Cleaning
by Mad_Hatter - 04/03/20 11:40 AM
Starting Over - 2013 Prius
by Greg L - 04/03/20 11:15 AM
Glue for dovetail joints
by spasm3 - 04/03/20 11:08 AM
In my face "wake up" call
by Kira - 04/03/20 10:58 AM
repairing old stereo equipment
by Donald - 04/03/20 10:44 AM
Valvoline Syn. Grease 14oz tube
by zfasts03 - 04/03/20 10:39 AM
WIX XP oil filter leaking....
by dkryan - 04/03/20 10:36 AM
K&N PS 1017 VIRGIN FILTER CUT OPEN
by 53' Stude - 04/03/20 09:56 AM
TJim, Andreeas1978, lawmanracing14, ebarker, Knop
71082 Registered Users
102 registered members (53' Stude, AdditiveOCD, 007, ammolab, 2010Civic, 2015_PSD, 5 invisible), 2,566 guests, and 20 spiders.
Topics303,530
Posts5,237,002
Members71,082
16 Audi S3 G13 Coolant - 40,500 miles #5326698 01/19/20 01:43 AM
A
agpatel Offline OP
A
Below is Polaris Coolant Analysis on my 2016 Audi S3 with 40,500 miles. Coolant has not been changed and serviced by the dealer regularly. I think a service or so ago they topped off the coolant with concentrate thus the higher than 50/50 concentration. I sucked out all the coolant in the expansion tank and filled with new 50/50 and will do this every 500-1000 miles and see how it is after few thousand miles.
I cant find a good G13 virgin analysis and thus do not know how the other perimeters look like. Not too worried and will dump the fluid at 75k unless someone thinks it should be done now.
[Linked Image from photos.smugmug.com]
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5326804 01/19/20 08:32 AM
R
Railrust Offline
R
I think you're fine and this (as you know) is a long life coolant...I believe Audi says it's good for the life of the vehicle...I wouldn't go THAT far, but a 75,000 mile change should be more than good enough for this coolant.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5326842 01/19/20 09:31 AM
F
FordCapriDriver Offline
F
Interesting that there are Phosphates present, G13 isn't supposed to have any, just Silicate + OAT
The new G12 Evo ( TL-774-L ) that was introduced in 2019 does however add Phosphates to the Silicate and OAT.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Whatever keeps the lifters quiet...
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5326930 01/19/20 11:09 AM
G
gregk24 Offline
G
I don't fall for the "lifetime" nonsense. The heater core on our 2014 Jetta plugged up with only 54,000 miles. This is common on VAG products. Likely will change every 30K moving forward.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: FordCapriDriver] #5327034 01/19/20 01:05 PM
A
agpatel Offline OP
A
I am wondering if the dealer topped it off with G12+ but I would assume that they would not have any left as G12++ is the last verson before G13 and its the same essentially. Did not see any build up on the sensor in the tank and the silicate packet is still in tact - primary reason for me draining the tank was to check on the packet in the expansion tank.
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5340712 02/04/20 11:02 AM
B
BMWTurboDzl Offline
B
What is a "silicate packet"?
435i
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: BMWTurboDzl] #5355883 02/20/20 07:33 PM
A
agpatel Offline OP
A
VW/Audi in the newer cars have a packet
Of silica in the expansion tank to supplement the coolant as the silica is used up. The silica is to protect against aluminum corrosion.
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5367114 03/04/20 12:56 PM
B
BMWTurboDzl Offline
B
thumbsup learned something new.
435i
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5381312 03/20/20 02:26 PM
F
F
Interesting, as VW coolant from 2012 onwards already has Silicate + OAT
The newest, called G12 Neo, is the same as G13 but has Phosphate aswell
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: gregk24] #5382418 03/21/20 08:50 PM
U
UG_Passat Offline
U
Never had a VW with the heater core plugged up at 54,000 miles... 2002 Golf TDI at 170,000 miles... no issues. Coolant was replaced at 100,000 miles with the timing belt change
2008 Passat, traded in at 217,000 miles. Coolant was replaced at 100,000 miles with timing belt change
2016 Tiguan, up to the new engine at 107,000 miles... no issues... new engine came with new coolant.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
