drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Havoline ProDS Full Synthetic
by Fordiesel69 - 02/21/20 01:32 PM
Correct oil for flat tappets
by Gokhan - 02/21/20 11:55 AM
Laser tachometer?
by Elkins45 - 02/21/20 11:13 AM
Best beginner press?
by MVFarms - 02/21/20 10:20 AM
Help me pick a generator size
by dlundblad - 02/21/20 09:56 AM
...musical 'flat-tappet' oils
by Mad_Max_Sam - 02/21/20 09:44 AM
KIA
by WyrTwister - 02/21/20 09:42 AM
Valvoline NextGen Conventional
by Char Baby - 02/21/20 07:20 AM
Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
109 registered members (bdcardinal, 928, Audios, b1amgm47, atikovi, 53' Stude, 8 invisible), 2,263 guests, and 16 spiders.
Topics301,750
Posts5,202,094
Members70,766
16 Audi S3 G13 Coolant - 40,500 miles #5326698 01/19/20 12:43 AM
A
agpatel Offline OP
A
Below is Polaris Coolant Analysis on my 2016 Audi S3 with 40,500 miles. Coolant has not been changed and serviced by the dealer regularly. I think a service or so ago they topped off the coolant with concentrate thus the higher than 50/50 concentration. I sucked out all the coolant in the expansion tank and filled with new 50/50 and will do this every 500-1000 miles and see how it is after few thousand miles.
I cant find a good G13 virgin analysis and thus do not know how the other perimeters look like. Not too worried and will dump the fluid at 75k unless someone thinks it should be done now.
[Linked Image from photos.smugmug.com]
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5326804 01/19/20 07:32 AM
R
Railrust Offline
R
I think you're fine and this (as you know) is a long life coolant...I believe Audi says it's good for the life of the vehicle...I wouldn't go THAT far, but a 75,000 mile change should be more than good enough for this coolant.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5326842 01/19/20 08:31 AM
F
FordCapriDriver Offline
F
Interesting that there are Phosphates present, G13 isn't supposed to have any, just Silicate + OAT
The new G12 Evo ( TL-774-L ) that was introduced in 2019 does however add Phosphates to the Silicate and OAT.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Repsol Elite Super 20W-50
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5326930 01/19/20 10:09 AM
G
gregk24 Offline
G
I don't fall for the "lifetime" nonsense. The heater core on our 2014 Jetta plugged up with only 54,000 miles. This is common on VAG products. Likely will change every 30K moving forward.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: FordCapriDriver] #5327034 01/19/20 12:05 PM
A
agpatel Offline OP
A
I am wondering if the dealer topped it off with G12+ but I would assume that they would not have any left as G12++ is the last verson before G13 and its the same essentially. Did not see any build up on the sensor in the tank and the silicate packet is still in tact - primary reason for me draining the tank was to check on the packet in the expansion tank.
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: agpatel] #5340712 02/04/20 10:02 AM
B
BMWTurboDzl Offline
B
What is a "silicate packet"?
435i
Re: 16 Audi S3 G13 Coolant - 40,500 miles [Re: BMWTurboDzl] #5355883 02/20/20 06:33 PM
A
agpatel Offline OP
A
VW/Audi in the newer cars have a packet
Of silica in the expansion tank to supplement the coolant as the silica is used up. The silica is to protect against aluminum corrosion.
