Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
115 registered members (Anduril, apollo18, Astro14, 928, 2012AccentSE, aquariuscsm, 6 invisible), 2,202 guests, and 19 spiders.
Topics301,698
Posts5,200,876
Members70,759
Mobil 1 Extended Performance Oil Filters #5326043 01/18/20 08:08 AM
J
jrommelt Offline OP
J
Who makes Mobil 1 Oil Filters? .....Fram?
Re: Mobil 1 Extended Performance Oil Filters [Re: jrommelt] #5326047 01/18/20 08:12 AM
B
bullwinkle Offline
B
It has been Champ, pretty much continuously, Fram & Champ were the same company for a whie-they jointly made M1 filters then.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Mobil 1 Extended Performance Oil Filters [Re: jrommelt] #5326095 01/18/20 09:09 AM
N
NormanBuntz Offline
N
If you are eligible to open an account with servicechamp.com, it has the best prices on M1 oil filters. You need to be a registered user to obtain pricing.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 11K, 2nd owner
2007 Honda Ridgeline RTS, 96K, original owner
2007 Infiniti M35, 115K, original owner
Re: Mobil 1 Extended Performance Oil Filters [Re: NormanBuntz] #5326142 01/18/20 09:58 AM
B
bullwinkle Offline
B
I'm going to try that, I've heard of them before.
Re: Mobil 1 Extended Performance Oil Filters [Re: NormanBuntz] #5326151 01/18/20 10:07 AM
B
Bettez88 Offline
B
Do you need a real business or can you, you know just fib?
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Mobil 1 Extended Performance Oil Filters [Re: NormanBuntz] #5326213 01/18/20 11:15 AM
J
jrommelt Offline OP
J
Thank you very much.
Is it a good thing that they are made by Champ?
Re: Mobil 1 Extended Performance Oil Filters [Re: jrommelt] #5326227 01/18/20 11:29 AM
L
Linctex Offline
L
Sure.... The expen$ive Royal Purple filters are made by Champ labs, also.
I believe AmsOil filters are, too.
Re: Mobil 1 Extended Performance Oil Filters [Re: jrommelt] #5326530 01/18/20 06:28 PM
V
volk06 Offline
V
M1 filters are a pretty solidly built filter. Efficiency is only ok being 99% at 30 microns.
Re: Mobil 1 Extended Performance Oil Filters [Re: volk06] #5326578 01/18/20 07:36 PM
B
Bettez88 Offline
B
I’m guessing that’s for the longer oci they are going for now. Think the trend will be more toward flow and longer drain intervals in the future over filtration?
Re: Mobil 1 Extended Performance Oil Filters [Re: jrommelt] #5330311 01/23/20 01:22 PM
DGXR Offline
Many extended service oil filters can be run longer because they sacrifice filtration efficiency for better flow. Wix XP is a good example of this -- the service life is longer than the regular Wix filter but the filtration efficiency is lower. I think Purolator Boss is another good example, but not totallly sure about the efficiency vs the Purolator One filter.
A few extended service oil filters are built for long life and high efficiency filtration. Fram TG/Ultra are good examples of this.
I'm sure someone will chime in with a comment about filter capacity.
My $0.02
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
