What sort of ATF and is Merc V synthetic?
by Stinky123 - 02/20/20 12:37 PM
Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
107 registered members (1978elcamino, 77GrandPrix, 928, 69GTX, 330indy, 12 invisible), 1,977 guests, and 15 spiders.
Topics301,699
Posts5,200,905
Members70,759
Page 1 of 3 1 2 3
Do all synthetic oils act as a cleaner? #5326057 01/18/20 08:26 AM
L
Loobit Offline OP
L
I occasionally read about synthetic becoming darker quicker and/or causing leaks in older MPI engines because it loosens leftover deposits in engines that supposedly always used conventional. Wouldn't fresh conventional with the same additives do the same thing, or does the fancier base stocks of synthetic contribute to this cleaning far better?
Re: Do all synthetic oils act as a cleaner? [Re: Loobit] #5326066 01/18/20 08:39 AM
F
FordCapriDriver Offline
F
Some synthetic base stocks like PAO if i remember correctly have intrinsic solvent characteristics, others like Group III and Esters not so much.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Repsol Elite Super 20W-50
Re: Do all synthetic oils act as a cleaner? [Re: Loobit] #5326068 01/18/20 08:41 AM
Donald Offline
Yes. But if you want to clean a less expensive synthetic changed more often is best.
As always, the valve cover should be pulled to check for sludge.
2015 Ford F-250 w/Powerstroke
Re: Do all synthetic oils act as a cleaner? [Re: FordCapriDriver] #5326083 01/18/20 08:57 AM
CT8 Offline
[quote=FordCapriDriver]Some synthetic base stocks like PAO if i remember correctly have intrinsic solvent characteristics, others like Group III and Esters not so much.[/quote} Esters clean PAO and GPIII not so but then there are the additive packages.
2015 F150 2.7
2018 F350 6.2
Re: Do all synthetic oils act as a cleaner? [Re: Loobit] #5326097 01/18/20 09:10 AM
sloinker Offline
The Ester or Group V is the base oil that is known to clean. You won't find much Group V ,if any, in off the shelf oil nowadays. If I had to guess it would be that there is no ester content of any amount in any mass marketed synthetic oil in America. It's probable the modern add pack may substitute some of Ester's characteristics used in the predominately Group III base oil found on the shelf at the local Walmart..
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Do all synthetic oils act as a cleaner? [Re: FordCapriDriver] #5326104 01/18/20 09:15 AM
shanneba Offline
Exxon Mobil has this to say about Group V base stocks
The use of Synesstic™ AN base stocks or Esterex™
esters as PAO co-base stocks can offer the following benefits:
• seal swell and additive solubility
• improved lubricity
• improved cleanliness
• improved thermal and oxidative stability
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: Do all synthetic oils act as a cleaner? [Re: FordCapriDriver] #5326132 01/18/20 09:47 AM
L
Loobit Offline OP
L
I figured group III would behave like group II in terms of cleaning. I bet it's each oil brand's high end line of oils that have a mix of PAO and whatnot that really do the cleaning. You can see it in the volatility rating and flow characteristics in -30° temps. What about GTL derived oils? I know Pennzoil Platinum cleaned the living trash out of one engine we got (a 1MZ-FE).
Re: Do all synthetic oils act as a cleaner? [Re: Loobit] #5326134 01/18/20 09:52 AM
R
RDMgr Offline
R
PAOs are Group IV and esters and alkylated naphthalenes are Group V. Group IV, PAO, fluids are more thermally stable than mineral oil and contribute less to deposits. However, they don’t have any significant cleaning advantages over mineral oils. Esters and ANs tend to have better solubility characteristics which is why many PAO-based engine oils contain a low treat level of them. The 8-10% ester or AN in many synthetic oils improves additive solubility which is less than satisfactory in PAO fluids. Some suppliers may use Group III oil for additive solubility which doesn’t contribute to cleaning.
PAO and ester/AN oils will improve cleaning, but they probably will have little impact on existing carbon and varnish. They will solubilize sludge. These oils will also reduce deposit formation.
Re: Do all synthetic oils act as a cleaner? [Re: Loobit] #5326136 01/18/20 09:52 AM
B
bullwinkle Offline
B
Some "conventionals", actually most, are synthetic blends including Grp. III bases-I still have a case of PYB 5W20 from the days when Shell was using GTL base in PYB, along with the old high moly formula (pre-SN+)-I would wager that it would clean as well as most lower-end synthetic oils.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Do all synthetic oils act as a cleaner? [Re: FordCapriDriver] #5326156 01/18/20 10:12 AM
O
OVERKILL Offline
O
You've got that somewhat backwards.
As the purity of the base oil increases with respect to catalyst derived and solvent dewaxed bases, the solvency and polarity decrease. So, Group I is the most polar of the traditional hydrocarbon bases and as you go up the chain, this decreases until you are at Group III where you have next to no solubility, which is only eclipsed by PAO, which is even worse. These bases offer better thermal stability and superior cold temperature performance (particularly PAO) but because they are so pure; so "neutral" they that an oil blended with them be dosed with something else to improve solubility. This is either a lower group base or something like POE. Esters have a great deal of polarity, which is one of the reasons Mobil uses them in their PAO-based formulations and even shows them in their blending guide, as they facilitate proper solution of the addpack and give the oil the ability to better keep contaminants and combustion byproducts in solution.
GTL, being a Group III product, would be as bad as VISOM and other group III bases, if not worse, in terms of solubility and is probably as close as you can get to PAO in that department.
Re: Do all synthetic oils act as a cleaner? [Re: Loobit] #5326281 01/18/20 12:28 PM
B
benjy Offline
B
more than anything $$$$$ determines whats in oils + all oil blenders strive to meet specs using the least costly base oils + add pack that meets a spec + classification. in most cases its the additives + since diesel oils use more even basic diesel oils clean better. only real synthetics PAO + Esters are totally clean because they are man made in labs not from dirty CRUDE oil!!
Re: Do all synthetic oils act as a cleaner? [Re: Loobit] #5326322 01/18/20 01:15 PM
B
BigCahuna Offline
B
Do they sell blended oils only for people that don't care about keeping their motors clean?.,,,
Re: Do all synthetic oils act as a cleaner? [Re: Loobit] #5326345 01/18/20 01:39 PM
RDY4WAR Offline
Group IV PAO has the lowest solvency of any oil group and also the harshest on seals. This is why you won't find a straight PAO oil. It will have some amount of group III, ester, or napthalene to give it some solvency and help condition seals. The group III and IV synthetic oils actually have less cleaning ability than conventional group I and II oils because of that lower solvency. Solvency is what breaks down sludge so it can be picked up in suspension and filtered out. The additive package has little to do with this. A common misconception is that detergents clean the engine, but that's false. Detergents keep the oil clean as a way of sludge prevention, but they do not remove sludge that's already there.
If you want to clean up sludge from your engine, the best way to go is an oil with a lot of ester. This is the basis for Valvoline Premium Blue Restore (VPBR) as it's ~60% ester.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Do all synthetic oils act as a cleaner? [Re: shanneba] #5326358 01/18/20 01:46 PM
4WD Offline
I’m thinking the 30-40% that is not PAO in M1AP is a cocktail of all of the above … must have been endless combos tested in development … they might have learned some things usable to M1 EP which I think they can just fill the EP bottles with AP once they give up.
Re: Do all synthetic oils act as a cleaner? [Re: BigCahuna] #5326378 01/18/20 02:25 PM
CT8 Offline
proper oil change intervals work wonders. What does it matter when you d\get the cat towed to the junk yard with a clean engine?
2015 F150 2.7
2018 F350 6.2
Page 1 of 3 1 2 3
