Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
120 registered members (928, 2012AccentSE, apollo18, Anduril, ABomb369, 750IX, 10 invisible), 2,265 guests, and 22 spiders.
Topics301,698
Posts5,200,852
Members70,759
These the same? #5325977 01/18/20 06:53 AM
B
Bettez88 Offline OP
B
Seeing as both these filters are built by Champion, would that mean that they are exactly the same construction?
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: These the same? [Re: Bettez88] #5325980 01/18/20 06:56 AM
spk2000 Offline
Can might be the same but the insides likely are not.
Cut them open and find out. Might do it after use just to minimize waste.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: These the same? [Re: Bettez88] #5325985 01/18/20 06:59 AM
dlundblad Offline
I believe an ecore AC Delco filter will have an e on the end of the p/n.
The ST filter should be an ecore. I believe there is a p/n that isn’t though and has metal end caps so you’d have to just find one and look.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: These the same? [Re: Bettez88] #5325994 01/18/20 07:15 AM
A
atikovi Offline
A
If they were, wouldn't it say it was compatible with PF46?
Re: These the same? [Re: Bettez88] #5326006 01/18/20 07:31 AM
Sayjac Offline
First issue here, using the pics equivalent application oil filters are not being compared. ST3614 not equivalent application to ACD PF46 pictured. With that in mind the ST3614 ecore uses a combo valve for bypass/adbv. The PF46 is for older GM with block bypass so has no filter integral bypass. So whether ACD an ecore or classic construction, the two not the same.
Re: These the same? [Re: Bettez88] #5326022 01/18/20 07:46 AM
K
krismoriah72 Offline
K
I thought they were made by Champ
Re: These the same? [Re: Sayjac] #5326038 01/18/20 08:03 AM
B
Bettez88 Offline OP
B
Cross referencing then says they are
Re: These the same? [Re: Bettez88] #5326050 01/18/20 08:13 AM
Sayjac Offline
Please post cross reference showing ST3614 is the equivalent filter to PF46 shown. Linked are multple Xrefs showing they are not. Here's one for each filter shown and a Fram xref /(competitor comparison) to PF46. Also the bypass information as posted accurate says not equivalent.
https://www.oilfilter-crossreference.com/convert/AC-Delco/PF46
https://www.oilfilter-crossreference.com/convert/SUPERTECH/ST3614
https://www.fram.com/parts-search/P...IgJxAGhABQGIAsAbFgHYCuANpZhdbVTXU4w9QLpA
Re: These the same? [Re: Sayjac] #5326065 01/18/20 08:38 AM
MrMoody Offline
Yes, you are correct. 3614 is 3/4 in. thread with approx. 10-12 lb. bypass that fits older Fords, Chryslers, etc. . PF46 is 13/16 inch thread with no bypass, pretty much GM only. They won't even screw onto the same car.
ST3614->PF53
PF46->ST3506
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: These the same? [Re: MrMoody] #5326088 01/18/20 09:00 AM
Sayjac Offline
Yeah, thanks for that. Fairly familiar with both applications. 3614 used on Toyota Tacoma 3.4L amongst many others. And no filter integral bypass PF46, used on the GM models with block bypass. Yes, ST3506 equivalent to PF46
As for that xref showing 3614 and PF46 equivalent....
[Linked Image from media.giphy.com]
Re: These the same? [Re: Sayjac] #5326102 01/18/20 09:13 AM
4WD Offline
I’d take the PRV in the can any day … my Fusion and lawn tractor both get some of those on ST can
Re: These the same? [Re: Sayjac] #5326114 01/18/20 09:26 AM
Sayjac Offline
It''s less about whether the ST uses a filter bypass or not, by rather whether the application specs one. In the case of older GM, the bypass is in block making filter application unneeded like PF46. In the ST 3614 applications, not the case, filter bypass required and used.
If given the choice between a combo valve and separate bypass/adbv, I prefer the latter. Apparently GM sees it similarly, as for newer vehicle GM ACDelco ecores have separate poppet type bypass, no combo valve. But that OT.
Re: These the same? [Re: Bettez88] #5326133 01/18/20 09:49 AM
B
Bettez88 Offline OP
B
Whoops my mistake, I was just using those as a comparison. I’m talking more about the quality of the media etc.
Re: These the same? [Re: Bettez88] #5326143 01/18/20 09:59 AM
dlundblad Offline
Oops. I figured they were the same in terms of application. I assumed it was a question about the construction since they were 2 different brands technically.
You know what they say about assuming..
Re: These the same? [Re: dlundblad] #5326223 01/18/20 11:27 AM
L
Linctex Offline
L
How About this:
Quote
"Seeing as both these PF46E and ST3506 filters are built by Champion, would that mean that they are exactly the same construction?
That should get us pretty close.....
And my guess would be "VERY similar inside"
