Forums Migration
Please read this thread
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Purolator Boss
by RazorsEdge - 07/08/20 02:01 PM
B2300 frame repair.
by simple_gifts - 07/08/20 01:48 PM
O2 sensor adapter with "mini catalytic converter"
by keantoken - 07/08/20 01:48 PM
Peeled veneer paint on vintage Pioneer
by Alfred_B - 07/08/20 01:40 PM
Shift Solenoids Cleaner additive?
by Husam - 07/08/20 01:11 PM
D rings for towing
by cknight49090 - 07/08/20 01:06 PM
Rotella T6 5w40 sale
by reaperman - 07/08/20 12:44 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
122 registered members (77Se7en, 4WD, 55hambone, afree, AdmdeVilleneuve, 379KITTY, 13 invisible), 1,876 guests, and 32 spiders.
Topics307,619
Posts5,314,346
Members71,888
Page 1 of 3 1 2 3
19 Ram Rebel oil choices #5325638 01/17/20 08:35 PM
Schwifty Offline OP
Hey all,
Very long time lurker here. I finally decided to join up and ask a few questions. I purchased a new Ram Rebel and did my ritual of pulling out the factory oil at 1k and I switched it with Rotella Gas Truck 5w20 and a Fram Ultra filter. I'm about to hit 5k and I was wondering about swapping over to Redline 5w30 to prevent the dreaded issue with Hemi tick and the cam wear they have been notorious for lately. So, my questions is, swap to Redline or stick with Gas truck? The cost is not an issue for me, but I do what whats best for my truck. I tend to drive it hard in the mountains, and it will see a fair amount of offroad time crawling around forest service roads in all weather conditions. Currently the truck sees about 80% straight highway with very little stop and go. But ones spring hits it will be probably offroad every weekend. I don't tow but the bed is normally loaded with quite a bit of gear, wood, and camping and hunting equipment.
Re: 19 Ram Rebel oil choices [Re: Schwifty] #5325642 01/17/20 08:44 PM
J
jayjr1105 Offline
J
Won't hurt to try. If you don't see significant improvement then go back to $20 5qt jugs of Mobile 1 or whatever name brand oil you like.
Nevermind, I didn't realize you said "prevent". I thought you were hearing it already. I'll let the more seasoned members chime in.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: 19 Ram Rebel oil choices [Re: jayjr1105] #5325652 01/17/20 08:52 PM
Schwifty Offline OP
Yeah, doing this as cheap insurance. I don't mind paying for a premium oil if that is what it takes. It seems a lot of the hemi crowd likes the high moly contents of the Redline oils.
Re: 19 Ram Rebel oil choices [Re: Schwifty] #5325668 01/17/20 09:07 PM
O
OilReport99 Offline
O
Originally Posted by Schwifty
Hey all,
Do you have a tick? If no, keep using the RGT 5W-20. It is the required grade for your engine, and it carries the recommended approval (MS 6395). If you do have a tick, take it to your dealership - you're likely under warranty. The way I see it, there are two types of ticks: the ones that wear the cam lobes, and the ones "succesfully killed by Redline". For the latter, just keep using RGT. No need to bend out of shape over anecdotal "evidence".
2018 Ram owner here. Tried RL 5W-30, all I got was a parasitic drag due to the high viscosity and the conviction that Chrysler engineers know their business better than I do. CAFE notwidthstanding.
2018 Ram 1500 - VME 5W-20
Re: 19 Ram Rebel oil choices [Re: OilReport99] #5325673 01/17/20 09:15 PM
Schwifty Offline OP
Hey all,
Interesting response. I can appreciate that! Ok, what if I wanted to switch to Redline just for the better add pack? Is having higher counts in Moly, Zinc, Calcium and Phosphorous worth it in the long run? I'm just now getting back into n/a v-8s after spending a decade daily driving high HP turbo imports, one of which thrived on very high moly oils. I guess I am asking, for this Hemi, is the juice worth the squeeze, even if I stayed with a 5w20.
Re: 19 Ram Rebel oil choices [Re: Schwifty] #5325683 01/17/20 09:26 PM
O
OilReport99 Offline
O
Hey all,
kschachn in 3...2...1
LOL
Re: 19 Ram Rebel oil choices [Re: Schwifty] #5325703 01/17/20 09:38 PM
7
77Se7en Online Content
Online Content
7
Hey all,
Welcome to BITOG
Since money isn't an issue and you want to avoid the tick prior to it's occurrence, then switch to Red Line and stick with it.
Excellent choice and it's great to read from a Ram owner that wants to avoid the eventual, dreaded tick right now - not after the tick starts.
Crusader / Intuitive / Whisperer-Medium
My Christmas Wish List reads.....
Ravenol DXG
Schaeffer 9000
Amsoil Signature Series
Re: 19 Ram Rebel oil choices [Re: Schwifty] #5325705 01/17/20 09:42 PM
SubieRubyRoo Offline
OP, since you've been lurking, you've probably seen it here before... NO oil, regardless of its additives, can "fix" an engineering or manufacturing problem. Search the board for something like "Hemi SADI camshaft". That being said, in its HP Hemis they use PUP 0W40 from the factory, so that would be as robust a choice as any...
De omnibus dubitandum.
Re: 19 Ram Rebel oil choices [Re: Schwifty] #5325712 01/17/20 09:45 PM
Danno Offline
For my Grand Cherokee Hemi, I'm sticking with PYB 5W-20 and OE filter at 6,000 mile intervals. Oil life monitor should be at about 40%. Did an early change at 1,000 miles.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 19 Ram Rebel oil choices [Re: 77Se7en] #5325713 01/17/20 09:45 PM
O
OilReport99 Offline
O
Hey all,
Welcome to BITOG
Do you have any data to back up the statement that Redline kills the tick? Or, are you just trolling as usual?
Re: 19 Ram Rebel oil choices [Re: SubieRubyRoo] #5325716 01/17/20 09:48 PM
7
Online Content
7
Subie
OP hasn't a problem to fix. The tick has not developed yet and he's trying to avoid it. I have read a Ram BITOG member or two here, that's gone this exact route when the vehicle is still new and the engine remains silent using Redline.
Ravenol DXG
Schaeffer 9000
Re: 19 Ram Rebel oil choices [Re: OilReport99] #5325719 01/17/20 09:50 PM
7
Online Content
7
OilReports
Where did I say it kills the tick? I recommended Red Line to the OP, to avoid the tick.
Please, learn how to read replies here.
Ravenol DXG
Schaeffer 9000
Re: 19 Ram Rebel oil choices [Re: 77Se7en] #5325722 01/17/20 09:52 PM
O
OilReport99 Offline
O
OilReports
Sorry, My bad!
Do you have any data to back up the statement that Redline is good to avoid the tick?
Re: 19 Ram Rebel oil choices [Re: OilReport99] #5325727 01/17/20 09:57 PM
7
Online Content
7
Only that I've read a couple Ram Owners here that are currently using it. Read it here and over on a busy Rams board.
Ravenol DXG
Schaeffer 9000
Re: 19 Ram Rebel oil choices [Re: 77Se7en] #5325733 01/17/20 10:00 PM
O
OilReport99 Offline
O
And that's the data you rely on to give advice to the OP?
Page 1 of 3 1 2 3
