- Joined
- Nov 29, 2009
- Messages
- 7,267
I'm trying to remove the pump just enough so I can install the proper sized barbed fitting for the hose I need. I had limited space and figured since the bottom nut was larger it should have kept the studs from turning. What a mess. Now the very back nut is coming off like it should I wish all three would have just come loose. Would have been easier to get back on. Opinions?
