Washing coolant down a storm drain?
by jharrison - 02/22/20 12:57 AM
storm door installation question
by FirstNissan - 02/22/20 12:13 AM
Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
35 registered members (aquariuscsm, 2013ecof150, BBDartCA, 750IX, bhmax, Aero540T, 2 invisible), 1,194 guests, and 18 spiders.
Topics301,769
Posts5,202,397
Members70,775
Page 4 of 5 1 3 4 5
Re: Help understanding Pennzoil Ultra Platinum oil [Re: kschachn] #5322992 01/14/20 11:06 PM
H
holder Offline
H
Originally Posted by kschachn
Originally Posted by holder
Does the highest quality base oils have issues with fall out?
Let’s make this easier, what brands use “the highest quality base oils”?
I mean purest, as in least contaminants. But I dont need the info this bad.
Re: Help understanding Pennzoil Ultra Platinum oil [Re: holder] #5323009 01/14/20 11:50 PM
dave1251 Offline
If it looks like dirt, walks like dirt, smells like dirt, and talks like dirt, it is actually additives that fall out of suspension. I'm just wondering if certain base oils allow contaminants to fall out of suspension more then group 3 oils?
Ok which respawn are you?
don't use.
Re: Help understanding Pennzoil Ultra Platinum oil [Re: rav] #5323014 01/14/20 11:56 PM
O
OilUzer Offline
O
op,
Nothing new. I observed this with PP and I still use it. Refer to my thread below:
brown streak in oil
I saw brown streaks like a vane or hair when I let the oil drip from the dipstick after the car had cooled down. This was 2500 miles after oil change.
Re: Help understanding Pennzoil Ultra Platinum oil [Re: rav] #5323053 01/15/20 01:21 AM
R
rubberchicken Offline
R
I have probably gone through about 10 gallons of PUP 5w30, and have seen this frequently. The older it is, or the longer it has been on the shelf, the more pronounced it seems. I have not seen one of my samples as dark as yours. I called the help line for Pennzoil and asked the same question. The answer I got was " Let me take your number and email, and somebody will get back with you. But the short answer is that it is additive fallout that is harmless, and should be shaken so it gets poured into the engine." If you rub some between your fingers you cannot feel anything abnormal, at least in my case.
Along with PUP, I have seen it in M1 and Amsoil. I have a few quarts of marine gear lube and it is probably the most pronounced in that product after sitting for a few years.
Re: Help understanding Pennzoil Ultra Platinum oil [Re: rav] #5323274 01/15/20 09:37 AM
B
buddylpal Offline
B
I’ve seen this with other oil brands too. PUP definitely has more sediment at the bottom than others, with the other brands it’s easily shaken back into suspension. I’ve had no luck shaking the sediment in PUP back into suspension.
A couple GM's and a Hyundai.
Re: Help understanding Pennzoil Ultra Platinum oil [Re: OilUzer] #5323836 01/15/20 07:54 PM
M
Mad_Hatter Offline
M
Originally Posted by OilUzer
op,
brown streak in oil
Stop saying "brown streaks", it gives me the shivers! 😂
Re: Help understanding Pennzoil Ultra Platinum oil [Re: buddylpal] #5323844 01/15/20 07:59 PM
K
kschachn Offline
K
Nor would you at room temperature.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Help understanding Pennzoil Ultra Platinum oil [Re: Mad_Hatter] #5324025 01/16/20 01:47 AM
O
OilUzer Offline
O
op,
brown streak in oil
lol
First time ever I noticed the color diff. I usually raise the dipstick over my head and away from the engine to have some light in the background and I let the oil slowly drip on a paper towel. I can see the color as it's dripping and love to go by color and I know experts say color means nothing ... anyway that's when I noticed the dark band like a hair in the oil.
Notice I said "dark band" instead of "brown streaks" grin2
Re: Help understanding Pennzoil Ultra Platinum oil [Re: rav] #5324073 01/16/20 05:33 AM
P
pbm Offline
P
I have found this 'residue' on the bottom of the containers of many brands. Sometimes it's dark like this Pennzoil...sometimes its lighter and gooey (SM rated Havoline in the black container had a layer of white goo on the bottom after sitting in my stash awhile). Shaking does virtually nothing to re-mix this (what I believe is additive dropout). What I do is cut each empty container and add some oil and stir it back into suspension before adding it to the engine. I've never had a bad UOA using this method. This additive fallout is the main reason that I don't like black containers.
'Journalism is Dead'
Re: Help understanding Pennzoil Ultra Platinum oil [Re: pbm] #5324410 01/16/20 12:12 PM
O
OilUzer Offline
O
Whatever it is, it won't mix or it will regroup again! I had over 2500 miles. The engine was cold when I checked the oil. Maybe when the engine is warm it will mix. I need to try it when the engine is warm/hot but not worried about it. Car sounds very smooth with PP. I may try Euro L PP next time if it's not for diesel engines. Saw some recently at local walmart.
Re: Help understanding Pennzoil Ultra Platinum oil [Re: rav] #5324437 01/16/20 12:51 PM
DGXR Offline
Obviously it's NANO DIAMONDS! LOL laugh
[Linked Image]
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Help understanding Pennzoil Ultra Platinum oil [Re: rav] #5324891 01/17/20 02:10 AM
R
R
I have had very good luck mixing the brown goo on the bottom of PUP. I find its best to empty the gallon bottle down to about 16 ounces, then shake the snot out of it. It completely blends back in.
Re: Help understanding Pennzoil Ultra Platinum oil [Re: rubberchicken] #5324916 01/17/20 04:38 AM
T
Triple_Se7en Offline
T
The brown goo and snot is the #1 reached-for oil brand name in the USA.
Additives that hang-out, are better than brands that haven't enough to exceed. Clean bottoms are for the meeter-lovers.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Help understanding Pennzoil Ultra Platinum oil [Re: OilUzer] #5324958 01/17/20 06:30 AM
4WD Offline
Walmart’s here ran a clearance of PP Euro and I have run out of that. They only sell PP vanilla.
Just got the last five quarts PP Euro they had at AZ clearance …
It’s 0w40 and I’ll use in the Cruze … now at 128k
Re: Help understanding Pennzoil Ultra Platinum oil [Re: rav] #5324984 01/17/20 07:05 AM
B
Bjornviken Offline
B
hmm... Not really the first time i see that
Page 4 of 5 1 3 4 5
