Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
116 registered members (53' Stude, 01rangerxl, 762fermeandyou, 2015_PSD, 69GTX, 390pi, 14 invisible), 2,487 guests, and 24 spiders.
Topics301,888
Posts5,204,609
Members70,796
Dry Gas in exteme cold weather #5324976 01/17/20 06:57 AM
FA_WRX Offline OP
I'm wondering if other board members bother with using dey gas in extreme cold weather. I personally do not but wonder if it's a thing.
2015 WRX FA20F
PP Euro L 5W30
WIX 10078
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5324989 01/17/20 07:11 AM
spasm3 Online Happy
Online Happy
I don't anymore. Fuel has enough alcohol in it already.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5325005 01/17/20 07:33 AM
dadto2 Offline
The cashier at the parts store tried to upsell me some dry gas a couple of years ago. I said "No thanks, the gasoline is already almost 10% dry gas". He smirked and said "Yup, okay." Coffee2
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: Dry Gas in exteme cold weather [Re: spasm3] #5325051 01/17/20 08:28 AM
J
Jimzz Online Happy
Online Happy
J
Yep not really needed anymore, 10% ethanol and all, unless you made an enemy.
yup
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5325052 01/17/20 08:31 AM
Donald Online Content
Online Content
If you are using E10 fuel there is no need and you do not want to get over 10% as your engine was not designed for more than 10%. But most times its not really 10%, more like 7% so while adding dry gas will not help it will not hurt either.
But the quickmart store sell it and their gas is E10.
2015 Ford F-250 w/Powerstroke
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5325062 01/17/20 08:41 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
The pumps around here say "up to" 10% ethanol. I have found at times they sell pure gas. This was back a couple years ago when gas prices hit a low.
I still have an old can of dry gas from the 60s or 70s with a bottle cap lid. The contents are methanol..
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5325079 01/17/20 08:59 AM
N
nascarnation Offline
N
The other factor is fuel pumps. In the old days you had mechanical fuel pumps on the engine that could only pull a vacuum to get gas from the tank to the pump. Now you have 60 psi electric pumps sitting back in the tank.
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5325089 01/17/20 09:13 AM
A
ARCOgraphite Offline
A
E10 gas doesn't need it.
Plus most places sell Methanol DG which is a fuel system killer.
If It doesnt say Isopropanol dont go near it,
We use DG for home made soda pop can camping stoves though smile
[Linked Image]
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Dry Gas in exteme cold weather [Re: ARCOgraphite] #5325170 01/17/20 10:32 AM
spasm3 Online Happy
Online Happy
That is cool! How do you construct the can? Is hole size critical? What do you use to make consistent holes? Drill bit?
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5325191 01/17/20 10:51 AM
V
volk06 Offline
V
What is dry gas? I just try to use E0 when it gets below 0f. A little E10 mixed in there here n there too for moisture.
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5325195 01/17/20 10:56 AM
supton Offline
I don't. Personally I am often running my fuel tank down to near E, thus it's always getting filled up with fresh gas. And E10 has "dry gas" in it.
But I'm not sure where it'd get moisture from in the first place. The fuel system is very tightly closed.
2011 Toyota Camry, base, 2.5L/6MT, 201k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Dry Gas in exteme cold weather [Re: nascarnation] #5325293 01/17/20 12:40 PM
L
Linctex Offline
L
These also add a small amount of heat to the fuel.
Re: Dry Gas in exteme cold weather [Re: spasm3] #5325294 01/17/20 12:41 PM
L
Linctex Offline
L
Just do a search for " aluminum can alcohol stove "
Re: Dry Gas in exteme cold weather [Re: FA_WRX] #5325438 01/17/20 03:04 PM
Y
y_p_w Offline
Y
It might be able to lower the freezing point if there's any water in there. I don't think it's just about the dispersal of water in an E10 solution, but that something like isopropanol will lower the freezing point of the mixture even further. The freezing point of isopropanol is higher than ethanol, but I thought that some mixtures tended to freeze at lower temperatures.
Re: Dry Gas in exteme cold weather [Re: dadto2] #5325604 01/17/20 06:58 PM
Marco620 Offline
Quit making the parts guy look dumb lol. I must have got the same guy as he told me STP oil was what all the racecar drivers use. Told me my Redline was nothing special.
15' Civic 1.8 i-vtec 311,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
