Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
123 registered members (A4nKar, 01rangerxl, 762fermeandyou, AC1DD, 53' Stude, 2015_PSD, 14 invisible), 2,560 guests, and 24 spiders.
Topics301,888
Posts5,204,618
Members70,796
inline oiler for water separator on compressor #5324853 01/16/20 10:55 PM
M
motor_oil_madman Offline OP
M
I'm finally going to upgrade to a 60 gallon air compressor and i'm thinking of getting a different water separating filter, one that automatically oils. Can anyone tell me about this? I like to use a blow gun to blow myself off so is it going to be blowing oil out when I use this? I know you're suppose to use a different hose when painting since you don't want a hose that oil has been run through. All this time I just add a little air tool oil manually to my tools because the separator I had didn't have an oiler.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: inline oiler for water separator on compressor [Re: motor_oil_madman] #5324857 01/16/20 10:59 PM
P10crew Offline
I would not use an inline Oiler. Just get some air tool oil. And occasionally give your air tools a couple drops.
Re: inline oiler for water separator on compressor [Re: P10crew] #5324878 01/17/20 12:07 AM
spasm3 Online Happy
Online Happy
This. Plus if you ever want to use a paint gun, you will get oil from from the line in your gun and ruin anything you try to paint.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: inline oiler for water separator on compressor [Re: motor_oil_madman] #5324948 01/17/20 06:09 AM
Donald Offline
I have an inline oiler. And two different recoil hoses. One filtered only and one with oil.
2015 Ford F-250 w/Powerstroke
Re: inline oiler for water separator on compressor [Re: motor_oil_madman] #5324964 01/17/20 06:39 AM
skyactiv Offline
I'm a semi mechanic and no shop I worked at ever had one. I'm guessing it's because we use blow guns and who on earth wants an oil mist blowing out?
Cordless impacts have replaced using an air impact much of the time. We use the company owned 1" air impact for semi wheels.
This is on my tool chest at work:
[Linked Image]
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: inline oiler for water separator on compressor [Re: motor_oil_madman] #5325007 01/17/20 07:35 AM
L
Linctex Offline
L
Always oil at the tool only.
I don't like inline oilers because then *everything* gets oiled.
The oil can soften air hoses from the inside out, too.
Re: inline oiler for water separator on compressor [Re: motor_oil_madman] #5325011 01/17/20 07:38 AM
T
Trav Offline
T
All you need is a setup similar to this and use different fitting for oil/air and air. I use 2 hoses one with automotive fittings for tools and industrial fittings for air only.
This is about 12 years ago and has been changed a lot over the years but the principal is the same. The setup in the garage is similar only with a bigger compressor.
Top is air/water seperator and pressure regulator and the bottom is filter/regulator unit and oiler, it works great for the work bench.
[Linked Image]
Re: inline oiler for water separator on compressor [Re: motor_oil_madman] #5325048 01/17/20 08:20 AM
Donald Offline
I worked in a place that made roof trusses in the 1970s. Every 25' hanging from the ceiling was an air hose and quick disconnect. We used a lot of pneumatic staplers and would drag over an air hose and stapler and connect it to the quick disconnect hanging down.
We had to reach for the quick disconnect to insert the male end and as it was being connected an ounce or two of air tool oil would be shot down your arm. Good way to start the day.
It looked like ATF but I never asked what it it was.
The big machines to used press the trusses were all hydraulic, but air was used for some ancillary functions.
Re: inline oiler for water separator on compressor [Re: motor_oil_madman] #5325065 01/17/20 08:45 AM
T
Traction Online Content
Online Content
T
You can get an oiler that attaches on the tool, but all you need is a couple drops of oil when you use the tool, and maybe when you put it away. I have oilers on both of my tire machines, which have several air cylinders on them, but the oilers are usually empty anyway when I remember to check them. I would never blast oil through all of my airlines. The best upgrade for your new compressor would be a refrigerated air dryer. Not cheap, but dry air is priceless. Won't mess up a paint job, and air tools last much, much longer.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: inline oiler for water separator on compressor [Re: Traction] #5325177 01/17/20 10:38 AM
T
Trav Offline
T
Whats the problem blowing oil mist through air lines that are only used on air tools? I have a Goodyear air hose that has had oil mist run through it for the last 15 years.
I run a separate line for air only no oil.
Re: inline oiler for water separator on compressor [Re: Trav] #5325504 01/17/20 04:47 PM
T
Online Content
T
Probably nothing wrong with oil mist blowing all of the time, but I wouldn't want to be getting into the room air, and putting down a fine film of oil everywhere. I worked maintenance in a diesel engine factory, and we had three 500 horsepower compressors, and many miles of air lines everywhere in a million square foot building. They only used oilers as needed a the point of use. And, they were usually empty.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: inline oiler for water separator on compressor [Re: Traction] #5325564 01/17/20 06:21 PM
T
Trav Offline
T
I can see that, oil in the room air is not good.
