Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
99 registered members (53' Stude, 4WD, 762fermeandyou, 92saturnsl2, 007, 7 invisible), 2,114 guests, and 18 spiders.
Topics303,306
Posts5,233,690
Members71,038
Interesting Taillight Out Code #5324820 01/16/20 10:39 PM
G
Gebo Offline OP
G
Sunday I got a warning code on my 1998 LS400 saying "Taillight Out" or something similar to that. After a while, it went out. I checked my taillights and a 5W side bulb was out. You could barely notice that it was out. Replaced it and everything is ok. Tonight the same warning came on and then went out in about 20 minutes. When we got to our destination we checked the taillights and all the bulbs were working fine.
I'm not gonna lose sleep over this but is there something going on I need to know about?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Interesting Taillight Out Code [Re: Gebo] #5324837 01/16/20 11:11 PM
E
edwardh1 Offline
E
check the high mount light too
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Interesting Taillight Out Code [Re: Gebo] #5324936 01/17/20 06:17 AM
G
Gebo Offline OP
G
Will do. Thanks!
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Interesting Taillight Out Code [Re: Gebo] #5324977 01/17/20 07:57 AM
W
wag123 Offline
W
If you can't identify another bulb that is out, pull and reseat all of the bulbs in their sockets. After a long time, corrosion can develop on the contacts, increasing the resistance. The circuit that is checking the bulbs works by checking their resistance.
Re: Interesting Taillight Out Code [Re: Gebo] #5325006 01/17/20 08:34 AM
A
atikovi Offline
A
Just the fact the bulb is new could mean the resistance is different from the others. Let it break in for a few days.
Re: Interesting Taillight Out Code [Re: atikovi] #5325010 01/17/20 08:37 AM
supton Offline
I can't say I've ever heard of a break-in period for a light bulb... Maybe exists for some sort of mercury or arc lamp or some other exotic thing that I wouldn't expect to find on an automobile? shrug
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Interesting Taillight Out Code [Re: Gebo] #5325023 01/17/20 08:53 AM
A
atikovi Offline
A
I guess you could ohm a new vs. used bulb and see if there is any difference.
Re: Interesting Taillight Out Code [Re: wag123] #5325025 01/17/20 08:56 AM
G
Gebo Offline OP
G
Would you spray anything in the sockets? WD-40?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Interesting Taillight Out Code [Re: Gebo] #5325029 01/17/20 09:04 AM
supton Offline
I'd burnish the contacts and then use bulb grease.
Re: Interesting Taillight Out Code [Re: atikovi] #5325033 01/17/20 09:05 AM
supton Offline
True that. Although I'd compare the same bulb as the slight difference between bulbs might matter; I have to wonder if a 4 wire measurement would be better. And measuring ambient temperature as I do believe light bulbs have a positive tempco to their resistance (might not matter at room temp though).
Re: Interesting Taillight Out Code [Re: Gebo] #5325055 01/17/20 09:34 AM
G
Gebo Offline OP
G
Never heard of “bulb grease.”
I replaced this 5 watt bulb with a non OEM bulb. Could this be a problem? I’m an OEM guy but I didn’t think 🤔 a 5watt bulb could make a difference. That is, however, the first bulb I have ever replaced in this car.
It’s not the third brake light.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Interesting Taillight Out Code [Re: Gebo] #5325057 01/17/20 09:39 AM
W
wag123 Offline
W
Electrical contact cleaner.
From personal experience, I have found that this is the best product... https://www.amazon.com/MG-Chemicals-Contact-Cleaner-Aerosol/dp/B001U3X3PA/, but there are a number of other less expensive products available.
Re: Interesting Taillight Out Code [Re: Gebo] #5325063 01/17/20 09:44 AM
A
atikovi Offline
A
Best stuff out there.
[Linked Image from images-na.ssl-images-amazon.com]
Re: Interesting Taillight Out Code [Re: Gebo] #5325067 01/17/20 09:47 AM
W
wag123 Offline
W
I don't know what you mean by "non-OEM" bulb. Lexus/Toyota does not manufacture light bulbs. Yes, the wrong light bulb will make a difference because, if the wattage is different, the resistance will be different. But, light bulbs are standard generic items that you can purchase at any auto parts store and will perform exactly the same as the bulbs that came from the factory if they are the same number.
Re: Interesting Taillight Out Code [Re: wag123] #5325076 01/17/20 09:55 AM
G
Gebo Offline OP
G
I bought a 5W 12 V bulb from Amazon that fits in the socket. The Lexus bulb was a 5W 12 V bulb. I didn’t buy it from Lexus. Yep, I know they don’t make their parts and was just wondering “their” part is somehow different in some freaky way. The internals do not look the same. But of course 1998 bulb vs 2019 bulb, I wouldn’t expect them to look the same. LOL
Im gonna drive a few more times and see if I get the warning light.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
