Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
117 registered members (01rangerxl, 762fermeandyou, 53' Stude, 2015_PSD, 69GTX, 390pi, 13 invisible), 2,554 guests, and 25 spiders.
Topics301,888
Posts5,204,618
Members70,796
Trans runs better in severe cold... #5324664 01/16/20 06:41 PM
2
2009Caraman Offline OP
2
My trans(4 speed auto in a 2009 Grand Caravan) has been running much smoother since this -30c cold spell has started where I live. Less harshness in gear changing.
It doesn't really run terrible in hot weather but definitely jerky sometimes. I assume this is because the ATF +4 has a higher viscosity in the cold. Any additives that can mimic this in warm weather that are safe for Chrysler ATF 4 transmissions?
Re: Trans runs better in severe cold... [Re: 2009Caraman] #5324701 01/16/20 07:16 PM
J
JC1 Offline
J
When was the last time the tranny was serviced?
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Trans runs better in severe cold... [Re: 2009Caraman] #5324709 01/16/20 07:22 PM
Snagglefoot Offline
Someone once posted the viscosities of all the popular transmission fluids as a function of temperature. It would be interesting to have a look at that again. smile
If you want the job done right......do it yourself.
Re: Trans runs better in severe cold... [Re: JC1] #5324710 01/16/20 07:23 PM
2
2
It has received 2 drain and fills and a new filter in the last 5000km.
It's at 186 000 but 1st service isn't actually recommended until 200 000km by Dodge. They only do a pan drop and fill for recommended service.
Re: Trans runs better in severe cold... [Re: 2009Caraman] #5324768 01/16/20 08:28 PM
sloinker Online Shocked
Online Shocked
I went to Red Line transmission fluid on my [email protected] 50K miles. The C+ has 30% higher viscosity and is used by many folks as a popular replacement to the ATF-4 OE fluid.
https://www.redlineoil.com/c-atf
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Trans runs better in severe cold... [Re: sloinker] #5324808 01/16/20 09:21 PM
2
2
This is the kind of info I am looking for. Thx.
Re: Trans runs better in severe cold... [Re: 2009Caraman] #5324865 01/16/20 11:32 PM
slacktide_bitog Online Content
Online Content
If your transmission doesn't have a drain plug, get an aftermarket pan that has one, so future ATF changes will be much easier since you won't have to drop the pan smile
In a Chrysler minivan, I'd change the fluid annually. Like someone else said, Redline C+ is the best thing to use where ATF+4 is called for
Re: Trans runs better in severe cold... [Re: slacktide_bitog] #5324874 01/16/20 11:56 PM
N
nobb Offline
N
There's still a filter that you have to get at. Or do you only need to change that every other time?
Re: Trans runs better in severe cold... [Re: 2009Caraman] #5324896 01/17/20 02:57 AM
O
Olas Offline
O
Without legs it wont run anywhere, anytime. Ever.
How about 'performs' or 'works' or 'operates'?
Re: Trans runs better in severe cold... [Re: Olas] #5324900 01/17/20 03:23 AM
Danno Offline
Where's the down vote button when you need one?
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Trans runs better in severe cold... [Re: 2009Caraman] #5324935 01/17/20 05:12 AM
SteveSRT8 Offline
I love the operation of our 3500 service vans in cold weather because the torque converter stays unlocked for a while until things warm up a bit.
Much smoother, perfect shifts. I wonder if that's really what the OP is feeling here...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Trans runs better in severe cold... [Re: 2009Caraman] #5324947 01/17/20 06:05 AM
Snagglefoot Offline
Folks. Good luck with mimicking the viscosity of transmission fluid at -30 C. The viscosity of ATF 4 at 40 C is about 35 cSt. At -30 C it is 2200 cSt. smile
Re: Trans runs better in severe cold... [Re: Snagglefoot] #5324955 01/17/20 06:22 AM
4WD Offline
Snag - Got to feel -34C windchills a few weeks ago …
Think I will just continue to suffer 3-4 hot months per year …
Re: Trans runs better in severe cold... [Re: 4WD] #5324988 01/17/20 07:09 AM
Snagglefoot Offline
LOL
Re: Trans runs better in severe cold... [Re: SteveSRT8] #5325042 01/17/20 08:10 AM
M
Miller88 Offline
M
I put a biiiig cooler on my old Taurus to try to keep the trans from failing. Usually late Jan - Early Feb when we have our really cold season, it would never get up to temperature. I could drive 45 miles or so to see my parents and it wouldn't warm up enough so the torque converter would lock up.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
