Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
105 registered members (14Accent, 4WD, 55hambone, 53' Stude, 54Robert, 7 invisible), 2,060 guests, and 18 spiders.
Topics300,274
Posts5,172,159
Members70,464
Most Online3,728
Jan 11th, 2020
New Valvoline video showing engine teardown #5324417 01/16/20 12:24 PM
N
njohnson Offline OP
N
Hey everyone,
Just saw this video. Looks like Valvoline wanted to follow Mobil's example and show engine teardown results. They not only have the engine that has used Valvoline its entire life, but, also one that has not been maintained very well. Enjoy!
https://team.valvoline.com/diy/ray-evernham-uncovers-importance-using-right-motor-oil-your-engine
https://youtu.be/xJihDSp9d4o
Re: New Valvoline video showing engine teardown [Re: njohnson] #5324429 01/16/20 12:41 PM
SpitFire6 Offline
Apples & bananas.
2002 206 CC 2L 4Cyl.
1972 Spit 2L5 6Cyl.
Re: New Valvoline video showing engine teardown [Re: njohnson] #5324448 01/16/20 01:07 PM
W
walterjay Offline
W
For a fair comparison they need two motors that were properly maintained on schedule. One with Valvoline and one with something else.
Re: New Valvoline video showing engine teardown [Re: njohnson] #5324473 01/16/20 01:44 PM
gathermewool Offline
For a fair comparison, they'd need ten+ motors, each run on a test-dyno, with the only major variables being building tolerances and oil choice...
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: New Valvoline video showing engine teardown [Re: njohnson] #5324482 01/16/20 02:23 PM
B
BigCahuna Online Content
Online Content
B
I've watched several of these type videos where they take an engine apart, and they look pretty clean inside. And here's my takeaway from all of them, 1) use ANY brand of modern oil, and change it when you should and your motor will last. 2) your motor is the most durable part of any brand of car, and it should outlast the rest of the car if it was designed correctly. Those guys shouldn't be amazed when the oil does it's job, only when it doesn't do it's job.,,
Re: New Valvoline video showing engine teardown [Re: njohnson] #5324513 01/16/20 03:05 PM
1
1978elcamino Offline
1
What would be interesting is to have three engines take on the same durability testing. One engine at manufacture specified intervals, engine 2 at 1.5 x manufacture specified interval and engine 3 at 2 x manufacture specified interval. Then, tear all three down and have an engineer explain the wear difference.
Do the same with a regular vanilla conventional and compare the results of both oils.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: New Valvoline video showing engine teardown [Re: njohnson] #5324538 01/16/20 03:41 PM
ChrisD46 Offline
*For an engine that has used a SM / SN / D1 Gen 1 or 2 synthetic oil at appropriate OCI's - I'm not convinced it needs a "High Mileage" oil . The 2007 Kia 3.8L in my sig has used nothing but 5W30 synthetic oil after it's first 25K miles and today has 226K miles with no leaks and does not burn any oil during it's 5K mile OCI . I only used a high mileage synthetic oil once (M1 10W30 High Mileage during a cross country drive and back at 221K miles) ... Until I see any signs of oil burning or leaks I'll stay with Castrol , Pennzoil , M1 or Valvoline D1 / Gen 2 5W30 synthetic oil .
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: New Valvoline video showing engine teardown [Re: BigCahuna] #5324686 01/16/20 07:00 PM
M
Mitch Alsup Offline
M
Originally Posted by BigCahuna
I've watched several of these type videos where they take an engine apart, and they look pretty clean inside. And here's my takeaway from all of them, 1) use ANY brand of modern oil, and change it when you should and your motor will last. 2) your motor is the most durable part of any brand of car, and it should outlast the rest of the car if it was designed is cared for correctly. Those guys shouldn't be amazed when the oil does it's job, only when it doesn't do it's job.,,
Re: New Valvoline video showing engine teardown [Re: njohnson] #5324716 01/16/20 07:37 PM
I
IndyFan Offline
I
I really don't see why everyone gets their junk in a knot over these videos. I think that video serves a great purpose, which is to give you confidence that if you run Valvoline and follow the proper maintenance schedule for oil changes, your engine will be in great shape at high mileage and could outlast the rest of the car. That's an honest video, if you ask me, and the engines came out of real world vehicles, not taxi fleets or run on simulators. (I'm an M1 fan, but their videos aren't nearly as useful as this one, to me.) I think it clearly shows that Valvoline does what they promise it to do. (Or Napa, if you want to save a couple bucks.)
Good on Valvoline.
18 Jeep JLUR Wrangler 3.6 25k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 22k
08 Jeep Wrangler 3.8 135k
04 Jeep Grand Cherokee 4.7 105k
99 Mercedes E430 Sport 92k
Re: New Valvoline video showing engine teardown [Re: njohnson] #5324767 01/16/20 08:26 PM
E
Eddie Offline
E
I would find it believable if a micrometer was used to measure the crank journals instead of just looking at them. Maybe this was a spoof video ? ED
2014 CX5 Touring 2.5L :-)
Re: New Valvoline video showing engine teardown [Re: IndyFan] #5324835 01/16/20 10:07 PM
7
77GrandPrix Online Content
Online Content
7
Good on Valvoline.
Exactly!!
