Super Moon Photos
by Snagglefoot - 04/08/20 07:30 AM
Lord Willing, I'm Gonna Buy a Tundra
by Speak2Mountain - 04/08/20 07:05 AM
Discount Tire Resumes All Services
by Egg_Head - 04/08/20 06:07 AM
Nissan Airbag settlement check and another recall
by MoneyJohn - 04/08/20 04:23 AM
Edelbrock E Force SC on a 2009 Hemi
by watajob - 04/08/20 03:27 AM
Basket Case
by clinebarger - 04/08/20 12:17 AM
RIP John Prine
by 2015_PSD - 04/07/20 10:12 PM
Transfer to FFL - Missing Accessory
by Maddog1337 - 04/07/20 09:58 PM
Bronze Valve Guide Wear
by contraption22 - 04/07/20 09:24 PM
Bored at work, post a work photo or two...
by sloinker - 04/07/20 08:41 PM
Picked up an extra...
by Sonic - 04/07/20 08:40 PM
Mobil 212 A cut open.
by Micahmcmeen - 04/07/20 08:09 PM
German Castrol is back! (But you can't get it)
by Gokhan - 04/07/20 07:38 PM
Anybody drinking more liquor these days?
by JC1 - 04/07/20 07:25 PM
Super Tech 5W-30 HM Deal
by Jackson_Slugger - 04/07/20 06:49 PM
Any brake system engineer here to explain why
by atikovi - 04/07/20 06:38 PM
Cleaner for vinyl siding
by buck91 - 04/07/20 05:49 PM
New motorhome, what to use
by another Todd - 04/07/20 05:35 PM
jhoffy22, EcoBoosted, gseven, mmich187, Voq
71124 Registered Users
80 registered members (AndyB, antone, 77GrandPrix, atikovi, aquariuscsm, BeerCan, 7 invisible), 1,904 guests, and 18 spiders.
Topics303,752
Posts5,241,275
Members71,124
Page 1 of 3 1 2 3
???? Highest Detergent Motor Oil #5324303 01/16/20 11:47 AM
B
BigJohn Offline OP
B
I suppose this is the right place for such a question....
What is the highest detergent motor oil?
Would it something like Rotella?
I am finalizing a refresh of a nice "barn find". The engine hasn't been running in.... maybe 6 years. I want the first fill to be an oil that will clean things up as best as possible.
And yes... the engine turns over and all ports appear to be clear and allow lubricant to flow. Once I fill the sump.... I am ready to fire her up.
14 Ram 1500 EcoDiesel 4x4, T6 5w40
15 Mercedes ML250 BlueTec, PenEuro 5w30
16 Honda VFR1200x, T4/T6 Blend
14 BMW G650GS Sertao, T4/T6 Blend
10 Mahindra 2816 HST, T6 15w40
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324360 01/16/20 12:34 PM
O
OVERKILL Offline
O
Probably Redline or Valvoline Premium Blue Restore.
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324376 01/16/20 12:47 PM
RDY4WAR Offline
No modern API SN/SN+ or CJ-4/CK-4 rated oil has a lot of detergent anymore. The last high detergent HDEO was CI-4.
That said, it's not detergents that you really need here. You need solvents. Oils that are high ester would be preferable. Valvoline Premium Blue Restore (VPBR) would be ideal, but it's expensive. What kind of barn find are we talking about here? Is it an older classic with flat tappet lifters?
Detergents is somewhat of a misnomer as they are really acid neutralizers. They exist to keep the oil clean, not clean up the engine.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324383 01/16/20 12:52 PM
T
tundraotto Online Content
Online Content
T
Valvoline Premium Blue Restore - but its not all that cheap.
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324384 01/16/20 12:52 PM
Bryanccfshr Offline
Yeah “detergents” prevent deposits from attaching to metal surfaces by attaching themselves forming a barrier.
Detergents and antioxidants will keep an engine clean but won’t clean it.
Another good option is Mobil 1 0w40 FS with higher levels of SAPS and a good dose of esters with historically claimed cleaning ability.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324420 01/16/20 01:29 PM
DGXR Offline
PUP has always been touted as an excellent cleaning motor oil.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324450 01/16/20 02:12 PM
N
nthach Offline
N
Pennzoil has touted the cleaning ability of their oil - but a detergent in a motor oil is a dispersant that also helps neutralize acid. Calcium sulfonate was the long time pick for that. Since LSPI is an issue, there's less Ca content in a modern motor oil.
VPBR is a freak of nature in that fact it has an ester-rich blend of base oils with a conventional diesel add pack that meets CJ-4 specs. Their reasoning for ester is the inherent solvent-like qualities and polarity. Red Line is also ester-heavy(if you don't buy the "OEM series" which is really re-bottled Kendall).
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324460 01/16/20 02:28 PM
P
PandaBear Offline
P
First several run should be some cheap SuperTech that you can quickly flush, you can't substitute volume of oil replacement, sort of like you should rinse your dirty dishes with plain water before being picky about what dish soap you should use to clean them best.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324502 01/16/20 03:49 PM
Z
ZZman Offline
Z
Amsoil SSO has always been known for high detergent levels.
2005 Toyota Avalon XLS 3.5 motor
2014 Ford Fusion 2.5 motor
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324516 01/16/20 04:09 PM
M
Mad_Hatter Offline
M
Barring your engine being some kind of sludge monster prone to sludging up, just make sure you change whatever oil you're using on time, since sludge is the byproduct of oil breakdown.
But fwiw, i thought diesel HDEO's were better at controlling particles and contaminants since they're designed to be used over longer drain intervals and have higher levels of antioxidants & dispersants to control soot and acids. As far as a PCMO goes, I'd think an long drain interval oils like a M1 EP/AP or Castrol EP would do an equally good job of controlling oil breakdown and particle control. And if you believe Valvoline and M1's marketing on MaxLife and M1 HiMi, they supposedly have added detergents and dispersants to control sludge and help clean out an engine. Here's a clip of M1's EP HiMi on an Accord with +100k miles that they ran for another +100k miles doing 15k mile oci's using M1 EP HiMi.. I'm not a fan of extended drain intervals but i gotta say the engine looked pretty darn good after the testing.
https://mobiloil.com/en/article/why...age-guide/honda-accord-motor-oil-results
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324529 01/16/20 04:29 PM
ChrisD46 Offline
M1 High Mileage 10W30 has been noted to be a good cleaning oil .
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324535 01/16/20 04:37 PM
B
BigJohn Offline OP
B
If I can find some.... Sound like VPBR is my huckleberry.
But it also sounds like a good idea to run some SuperTech for the first 100 miles, dump it and then pour in the VPBR.
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324539 01/16/20 04:41 PM
SR5 Offline
The highest detergent motor oil will have the highest TBN, as the detergents main job is to neutralise acids. It’s the dispersants that do most of the cleaning and help stop stuff deposit formation. Get a HDEO or a Euro A3/B4 oil and you probably get plenty of both.
I would get a cheap HDEO like SuperTech and change it more frequently for a bit.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324548 01/16/20 04:53 PM
O
Onetor Offline
O
I agree about Valvoline and Redline ^^. You can always get a stout motor oil like Mobil 1 0W40 and add a can of BG MOA. Just know that oil has a carefully balance of detergents, dispersants etc, but it's your decision.
N = R* x fp x ne x fl x fi x fc x L
Re: ???? Highest Detergent Motor Oil [Re: BigJohn] #5324557 01/16/20 05:14 PM
K
krismoriah72 Offline
K
If it were mine i would probably do whatever oil you have on the shelf plus a bottle of Rislone Engine Treatment.
If you dont have anything on the shelf I would pick the cheapest oil with a starburst when i picked up the Rislone.
How does Rislone Engine Treatment work?
Rislone Engine Treatment gradually dissolves and removes harmful deposits of varnish, sludge and gum from the internal metal parts without plugging oil passages. These deposits form within engines and can alter tolerances, stick valves and rings, cause noisy valves and lifters, and plug oil screens and passages. Regular use of Rislone Engine Treatment, with oil and filter changes at the proper intervals, will keep such deposits to a minimum.
https://rislone.com/product/engine-treatment-100qr/
Page 1 of 3 1 2 3
