Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
109 registered members (AlaskaMike, aquariuscsm, Astro_Guy, alex_at, ajchien, asleepz, 10 invisible), 2,432 guests, and 22 spiders.
Topics301,909
Posts5,205,205
Members70,800
ATO24 OIL ANALYSIS - 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL #5324234 01/16/20 09:26 AM
wemay Online Happy OP
OP Online Happy
https://www.ato24.de/en/blog/comparison-0w-20-engine-oils#anchor5
Quote
The automotive industry is nowadays moving in the direction of more fuel-efficient engines. Consequently, this development also has an impact on engine oils as the development here is clearly leaning towards low viscosity 0W-30 and 0W-20 engine oils, which enable lower fuel consumption compared to “conventional” 5W-30 or 10W-40 engine oils.
The current VW 508 00 / 509 00 approval with the viscosity class 0W-20 and the LongLife IV property is a good example for the current development - and that makes it a very good subject for our latest ATO24 oil analysis.
VW 509 00 / 509 00 APPROVAL
The VW 508 00 approval for petrol engines and VW 509 00 for diesel engines was specifically developed for the latest generation of VW engines. Engine oils with VW 508 00 / 509 00 approval rely exclusively on the viscosity class 0W-20, which significantly reduces wear. The low viscosity in combination with a greatly reduced HTHS viscosity (≥ 2.6 mPas for xW-20) and low friction enable a lower fuel consumption of up to 4 % compared to engine oils with 5W-30 viscosity class.
Due to their bluish colour, engine oils with the VW 508 00 / 509 00 approval are also referred to as "VW Blue Oil". This special colouring is intended to prevent accidental mixing with other engine oils.
However, despite being referred to as VW Blue Oil, the colour is described as being rather green than blue - so in this context please don't be suprised!
0W-20 OIL ANALYSIS - THE TESTING PROCEDURES
All the engine oils tested here meet the same VW 508 00 / 509 00 approval and also have the same 0W-20 viscosity class - however - are they all really the same or are there still differences between them? What are the potential strengths and weaknesses?
In order to answer these questions and also, among all, achieve a better comparability, we have again, as we already did with our ATO24 0W-30 oil analysis, commissioned a laboratory accredited according to DAkkS in Germany to test and analyse the following points for us:
▶ Viscosity at 40 °C and 100 °C
▶ Viscosity Index
▶ HTHS
▶ TBN
▶ Sulphate Ash
▶ CCS -35 degrees
▶MRV -40 degrees
▶ NOACK
▶ Pour Point
▶ Flash Point
THE TESTED 0W-20 ENGINE OILS
Among the engine oils tested are the original VW G052577 Longlife IV 0W-20, as well as engine oils from renowned manufacturers such as Shell Helix Ultra Professional AV-L 0W-20, Castrol Edge Professional LL-IV FE 0W-20, Mobil 1 ESP x2 0W-20 and Ravenol VSE 0W-20.
Here is an overview of the tested engine oils:
Aral Super Tronic LL IV FE 0W-20:
Approvals: VW 508 00, VW 509 00
Castrol Edge Professional LL-IV FE 0W-20:
Approvals: VW 508 00, VW 509 00, Porsche C20
Fuchs Titan GT1 Longlife IV 0W-20:
Specifications: ACEA C5
Liqui Moly Top Tec 6200 0W-20:
Recommendations: Porsche C20
See Product
Mobil 1 ESP x2 0W-20:
Specifications: ACEA A1 / B1 / C5, API SN / SL
Approvals: VW 508 00, VW 509 00, Porsche C20, MB 229.71, Jaguar Land Rover STJLR.51.5122
Motul Specific 508 00 509 00 0W-20:
Ravenol VSE 0W-20:
See Product
Shell Helix Ultra Professional AV-L 0W-20:
Total Quartz Ineo Long Life 0W-20:
VW G052577 Longlife IV 0W-20:
OEM Number: G052577
RESULTS OF THE ANALYSIS
The test results are shown in the following bar charts. They do not appear in alphabetical order, but in numerically order. In addition to the following results, we have put them together in a PDF. This can be found under the following link:
PDF ATO24 0W-20 oil analysis
In case you are interested in a more precise definition of the individual test procedures, we recommend you have a look at our first oil analysis: ATO24 Oil Analysis: Comparison of 0W-30 Engine Oils
19 VW Passat Wolfsburg TSI (VW Genuine 0W-20+OEM)
13 Hyundai Santa Fe Sport 2.0T (Shell RGT 5W-30+OEM)
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: wemay] #5324236 01/16/20 09:29 AM
OP Online Happy
Continued...
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: wemay] #5324329 01/16/20 11:06 AM
L
Linctex Offline
L
Mobil 1 ESP for the "non-boutique, off the shelf " oil selection win!
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: wemay] #5324374 01/16/20 11:45 AM
SubieRubyRoo Offline
Linctex, I can't argue a lot about your choice, but I was thinking that Liqui-Moly 6200 looks pretty dang good as well... until I saw the $78 price on Amazon for 5L... eek
De omnibus dubitandum.
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: wemay] #5324645 01/16/20 06:07 PM
H
Hounds Offline
H
Thanks for the post, wemay.
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: Hounds] #5324648 01/16/20 06:14 PM
OP Online Happy
thumbsup
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: wemay] #5325544 01/17/20 05:37 PM
K
KCJeep Offline
K
Tons of work great post thanks!
2018 VW Passat GT VR6 - 24k - Castrol Pro OE 5w40 - VW OEM filter
2012 KIA Sedona 105k - Valvoline Maxlife 5w30
2012 VW Tiguan 106k - Castrol 0w40
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: wemay] #5325753 01/17/20 09:12 PM
G
geeman789 Offline
G
These oils seem to be very similar ... splitting hairs close enough that price and availability would be my deciding factor.
Mobil 1 ESP would be the winner. Widely available, and on sale every 2nd month or so.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: geeman789] #5325923 01/18/20 02:14 AM
B
Bjornviken Offline
B
what do you pay for that oil?
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: geeman789] #5326335 01/18/20 01:27 PM
B
BrandonT Offline
B
It's ESP X2 just for VW508/509 and Porsche. Not the ESP on the shelf now.
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: geeman789] #5326601 01/18/20 08:35 PM
B
bulwnkl Offline
B
Yeah, that's kinda what oil specs do; drive everything to be essentially the same on broad and basic tests like these.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: KCJeep] #5326811 01/19/20 07:40 AM
OP Online Happy
thumbsup
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: BrandonT] #5329062 01/21/20 07:14 PM
T
TheIceStormof06 Offline
T
Not sure what you mean by this. The 0W-20 ESP formulation is always X2
‘19 VW Atlas V6 (Pennzoil PP Euro LX 0W-30)
'17 Acura MDX SH-AWD (Mobil 1 EP 0W-20 & Fram Ultra Synthetic Filter)
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: wemay] #5329385 01/22/20 09:35 AM
B
BrandonT Offline
B
Thought there was an X1?
Re: 0W-20 ENGINE OILS WITH VW 508 00 / 509 00 APPROVAL [Re: wemay] #5329806 01/22/20 07:14 PM
P
PowerSurge Offline
P
Motul for me. If you drive your performance cars like they were intended, Motul doesn’t burn off as bad as M1, SOPUS products, Castrol, etc. I’ve always had to use less make-up oil with Motul. Two of my cars live regularly above 4000 RPM’s. With daily beaters it’s not as big of a difference.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
