Originally Posted by buddylpal
I think many people are missing the point here. The Magnuson-Moss warranty act doesn't mean the consumer can go out and purchase aftermarket (non OEM) parts and expect warranty to cover issues if said aftermarket part fails. All it says is the consumer can use aftermarket parts and still have the manufactures warranty, and in the event of a failure, the dealer/manufacturer has to prove the aftermarket part was at fault.
I hate to say it, but if Ford were to question the ATF used, they are in every right to deny your warranty. Maxlife is not approved by Ford so they can and will blame the failure on the wrong fluid being used. General Motors considers ANYTHING besides approved DexronVI in a transmission to be a contaminate. I'm sure Ford says something very similar. All they have to say is "Sorry, you used a non OEM approved fluid and non OEM fluids are a contaminate to Ford transmissions. They have not been tested for compatibility and durability standards with our transmissions".
I'm not sure if Ford will do a fluid sample. They may diagnose it like they would on a car that is brand new and just replace it no questions asked, or they may put a lot of pressure on you since you're so close to surpassing the warranty.
No Ford can not simply deny the warranty and state Valvoline ATF caused failure because it isn't approved. Why does this practical application is difficult to follow is beyond me.
Ford has to take an identical transmission with Maxlife ATF test it in near identical conditions as the OP's car subject it to a similar environment with the same maintenance procedures and schedules then it would have to fail before the warranty period. Then Ford has to repeat this again and then Valvoline gets to present the data in the favor of it's product and how it's product meets the performance requirements outlined by the MERCON LV spec thus it is not root cause of the failure.
None of this makes any business sense for Ford to consider this as an option.
