2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
coondog, steelbeams, Pete44, Connie7, 2020XT
70520 Registered Users
77 registered members (BAJA_05, bbhero, atikovi, bachman, Bighorn2500, 11 invisible), 1,879 guests, and 19 spiders.
Topics300,520
Posts5,177,667
Members70,520
'18 Ford FLex 30K drain and fill #5323751 01/15/20 06:08 PM
R
Redright9 Offline OP
R
So my wife's 2018 FLex is approaching 30k miles and per the owners manual and all the advice I have been given a transmission drain and fill is in order along with some other items. It seems simple, drain plug on bottom, fill with about 5+ quarts when done to dip stick full level... Other than the appropriate fluid type, what brand should I go for? Anyone know if its synthetic from the factory?
Thanks.
Re: '18 Ford FLex 30K drain and fill [Re: Redright9] #5323765 01/15/20 06:27 PM
cos Offline
No need to bother with "when done to dip stick full level". Just check the fluid level sometime before you drain it to make sure you have the correct amount of ATF in the trans. Then measure exactly what comes out and pour that amount back in.
'15 Cadillac SRX
- Castrol Magnatec 5W30
- Valvoline Maxlife ATF
Re: '18 Ford FLex 30K drain and fill [Re: cos] #5323785 01/15/20 06:44 PM
M
maxdustington Offline
M
No need for that on a car with a dipstick, just look up the specs to get close.
99 Toyota Tercel CE 5EFE/C151
Re: '18 Ford FLex 30K drain and fill [Re: Redright9] #5323882 01/15/20 08:51 PM
J
JLTD Offline
J
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, 35k, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: '18 Ford FLex 30K drain and fill [Re: Redright9] #5324211 01/16/20 09:04 AM
H
hallstevenson Offline
H
Nothing wrong with Mercon LV especially if you're changing it every 30k miles. Castrol Full Synthetic ATF and MAG1 LV ATF are both licensed - not "recommended" and not "acceptable for" - but fully licensed by Ford for LV applications.
Re: '18 Ford FLex 30K drain and fill [Re: cos] #5324214 01/16/20 09:06 AM
H
H
If there's a dipstick, use it. Measuring the amount is certainly a good starting point and yes, it's what I would put back in first. Then I'd get it warm and ready to check the level using the dipstick for a final check.
Re: '18 Ford FLex 30K drain and fill [Re: hallstevenson] #5324265 01/16/20 10:00 AM
4WD Offline
I have two FWD’s in the mix and I always measure what it drains on my ramps
Re: '18 Ford FLex 30K drain and fill [Re: hallstevenson] #5324295 01/16/20 10:34 AM
slacktide_bitog Offline
Get a measuring bucket, if you don't already have one smile
Drain the fluid when cold, measure how much you drained, then refill with the same amount you drained.
approved
Both of those are good stuff
Re: '18 Ford FLex 30K drain and fill [Re: Redright9] #5324431 01/16/20 12:43 PM
R
R
The vehicle does have a dip stick so I am not worried about the quantity needed. More a good brand of ATF to use to replace what I drain out.
Re: '18 Ford FLex 30K drain and fill [Re: Redright9] #5324469 01/16/20 01:33 PM
DGXR Offline
I would stick with OEM fluid. I mean really, how much are you spending, how often? Not worth saving a few dollars per year on aftermarket stuff that's generic formula for dozens of models. My $0.02
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: '18 Ford FLex 30K drain and fill [Re: Redright9] #5324477 01/16/20 01:51 PM
P
panthermike Offline
P
I would say oem or Mag 1. I've used the Mag, it works very well and as mentioned is officially licensed.
'17 Armada Platinum; RGT 0w20, 52K
'19 Ram 1500; RGT 5w20, 15K
'70 F100; Valvoline 15w40
Biotech For All
