Forums Migration
Please read this thread
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
103 registered members (77Se7en, 2018matto, ArrestMeRedZ, Aichiguy, 87sammy, 2002 Maxima SE, 10 invisible), 1,980 guests, and 34 spiders.
Topics307,777
Posts5,317,599
Members71,917
filter for home heating oil #5323661 01/15/20 05:16 PM
O
Oldtom Offline OP
O
I heat my home with oil. The typical home heating oil filter has an element that looks like different colors of recycled wool compressed around a wire core. The design always looked sketchy to me, as I was worried about wool fibers detaching and plugging the burner nozzle. My local hardware recently started carrying a white plastic foam element made by Mitco. Trouble is, the plastic foam filter is only good for 50 microns, where the wool filter is rated at 10 microns. I have had nozzle clogging with the plastic foam filter.
Are the compressed wool filters fairly trouble free? Any other options that filter to 10 micron? I plan to change the element yearly and add Fuel Right sludge treatment once a year.
Thanks in advance for any advice.
Re: filter for home heating oil [Re: Oldtom] #5323666 01/15/20 05:22 PM
G
georgemiller Offline
G
[Linked Image]
[Linked Image]
Re: filter for home heating oil [Re: georgemiller] #5323674 01/15/20 05:33 PM
Driz Offline
I bet that spin on needs a new head to work. I don’t see how it could work with the old canister style arrangement. You’d need the whole filter housing I believe.
Re: filter for home heating oil [Re: Driz] #5323676 01/15/20 05:39 PM
G
G
[Linked Image]
[Linked Image]
Re: filter for home heating oil [Re: Oldtom] #5323677 01/15/20 05:42 PM
G
G
I have a General Large filter and never had any problems but do use the 4 in 1.
Maybe change filter more frequently. Like every 6 months.
[Linked Image]
Re: filter for home heating oil [Re: Oldtom] #5323703 01/15/20 06:10 PM
Rat407 Offline
My mom has her system cleaned and inspected every year. I guess he guy that does it replaces the filter with what ever it calls for or that company uses. She is in PA so I can't check. But I do give her AMSOIL Injector Clean to put in her tank when she fills up. I have been doing that for the past 10 years and no issues. Might be a waste of money but I remember back before Injector clean the diesel fuel treatment AMSOIL had stated on the bottle it was good to use in home oil heating systems.
2014 Cruze Diesel 5w-30 AMSOIL
Re: filter for home heating oil [Re: Oldtom] #5323744 01/15/20 07:01 PM
W
walterjay Offline
W
The wool type filter does a good job. Been using them for my customers for 40 years with no problems.
Re: filter for home heating oil [Re: Oldtom] #5323788 01/15/20 07:48 PM
CDX825 Offline
General Filter makes a gear tooth style polypropylene filter that fits your housing and works better than the wool type filters. They are rated at 10 microns like the wool filters but they do a lot better job of catching the sludge and gunk that is in most oil tanks. I service hundreds of oil furnaces and boilers and this is the only filter I recommend.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: filter for home heating oil [Re: Oldtom] #5323931 01/15/20 10:41 PM
Donald Offline
I have the spin on with a gauge that has been mentioned already in this post.
That is what I would get if I was installing a boiler.
Remember the home heating oil today is ULSD so a lot cleaner than it was several years ago.
I am sure there are some slime bag oil supply companies that buy bottom of the tank or ship oil that might be crappy. But heating oil from a reputable fuel oil dealer should be very clean these days.
But a filter is always needed.
2015 Ford F-250 w/Powerstroke
Re: filter for home heating oil [Re: Oldtom] #5324032 01/16/20 03:27 AM
F
FT92 Offline
F
the wool type filters have been used forever , cant be many problems with them if any
Re: filter for home heating oil [Re: Oldtom] #5324070 01/16/20 06:25 AM
dnewton3 Offline
Global Moderator
Global Moderator
HHO is akin to diesel fuel.
Any local farm store would have a decent selection of those clear-bowl type cellulose-media filter units. If the OP is adept at some basic plumbing, that would be an easy fix IMO and he could see the fuel filter element via the bowl. Spin on fuel filters work well also, but you cannot see the media. That choice may or may not matter to the OP.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: filter for home heating oil [Re: walterjay] #5324136 01/16/20 08:24 AM
Donald Offline
I think over the years as people worried about oil use and efficiency, the nozzle size has gotten smaller and so better filtering is needed. But as I said in another post at the same time the fuel going into your tank is cleaner than a decade ago. But plenty of sludge is probably in the bottom of most home oil tanks.
Re: filter for home heating oil [Re: Oldtom] #5324140 01/16/20 08:34 AM
A
ARCOgraphite Offline
A
I been servicing my burner for 28 years.
Have used string filters, now use expanded foam filters.
This applies to a Carlin 99 FRD fired at 0.85 gph
I've had clogging issues in the past with:
1) Not keeping the tank topped off in humid weather
2) Delivery Company putting a "tank cleaner" in without my authorisation
3) Ignition points too close to the nozzle head with too wide a spark gap - burning the nozzle
4) No using a HAGO brand Nozzle - the brand that works correctly ( Monarch clog easily, DELAVAN have poor spray patterns)
4) Too much air forced though the flame retention head causing flame impingement on the nozzle. Adjust head position.
5) Loose nozzle filter
and service your filter and pump screen BEFORE adjusting nozzle and flame A good nozzel should work for at least 3 years,
Annual nozzle change out is NOT preventative maintenance, its just waste of time an $$ and looking for trouble.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: filter for home heating oil [Re: Oldtom] #5324156 01/16/20 08:57 AM
E
edwardh1 Offline
E
do you use a fuel treatment to prevent bacteria growth in the diesel?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: filter for home heating oil [Re: Oldtom] #5324560 01/16/20 05:17 PM
O
Oldtom Offline OP
O
Edwardh1 - Yes, I use a treatment called Fuel Right which supposedly prevents sludge and bacteria. Every time oil is added to the tank, it gets a small bottle of Fuel Right first, to allow the additive to mix well. Everybody has a favorite fuel additive and this seems to reduce the amount of sludge on the filter element and bottom of canister.
