- Joined
- Nov 29, 2009
- Messages
- 7,217
Do they make flexible high pressure lines. This is one that feeds both fuel rails. The reason I ask is I need to removed the low pressure fuel pump to change out a barbed fitting. The fitting the shop used is too small and I can either remove the motor mount or just loosen the bolts on the low pressure fuel pump and move it over a tad to get the clearance I need to spin the fitting off. The issue is they put both pumps on a bracket so once I loosen the bolts both the high and low pressure pump will be free to move.
