Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
108 registered members (53' Stude, 2015_PSD, ABN_CBT_ENGR, 762fermeandyou, 1978elcamino, 2004tdigls, 9 invisible), 2,653 guests, and 67 spiders.
Topics305,904
Posts5,282,493
Members71,535
Page 1 of 4 1 2 3 4
What is considered Modern Engine? #5323591 01/15/20 04:01 PM
O
Onetor Offline OP
O
Serious question, that maybe subjective. *Define Modern Engine:
I'm always reading about modern engines in various contexts, mostly on BITOG.
Did modern engines begin with fuel injectors? 1990's (20th century) or 2000's (21st century) or earlier?
Opinions appreciated!
N = R* x fp x ne x fl x fi x fc x L
Re: What is considered Modern Engine? [Re: Onetor] #5323597 01/15/20 04:05 PM
SubieRubyRoo Offline
No definition given by Valvoline. I'd take it to mean one of two things: either an engine that has always required API SN or newer oil, or anything since the advent of mass-market GDI. Without official input, we'll never know for sure.
De omnibus dubitandum.
Re: What is considered Modern Engine? [Re: Onetor] #5323599 01/15/20 04:07 PM
W
wallyuwl Offline
W
According to Valvoline it is 2012+.
Re: What is considered Modern Engine? [Re: Onetor] #5323602 01/15/20 04:12 PM
B
brages Online Content
Online Content
B
I think multi-port fuel injection, OBD2, and electronic ignition are kind of the baseline for modern engines, although it's a perspective thing I'm sure.
Other modern features:
aluminum block and heads
overhead cams (sorry GM fans)
four valves per cylinder
variable valve timing
direct injection
Re: What is considered Modern Engine? [Re: Onetor] #5323610 01/15/20 04:16 PM
DriveHard Offline
I would class it by emissions...anything that meets the most up to date (stringent) emissions requirements.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: What is considered Modern Engine? [Re: Onetor] #5323612 01/15/20 04:16 PM
old1 Offline
I know it is not true, but to an old-timer like me, anything that doesn't have a carburetor, and points in the ignition is modern. LOL
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
1998 Mustang 3.8 automatic 78K miles
Re: What is considered Modern Engine? [Re: Onetor] #5323618 01/15/20 04:23 PM
Snagglefoot Offline
Modern is a word advertisers use. Slides with the decades but consumers love it.
If you want the job done right......do it yourself.
Re: What is considered Modern Engine? [Re: Onetor] #5323620 01/15/20 04:24 PM
U
UG_Passat Offline
U
Modern by what standard or timeframe?
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: What is considered Modern Engine? [Re: Onetor] #5323628 01/15/20 04:29 PM
JohnnyJohnson Online Content
Online Content
You don't need a definition to support any thing you hype!
2004 Corolla 140080
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: What is considered Modern Engine? [Re: Onetor] #5323630 01/15/20 04:31 PM
I
Imp4 Offline
I
I think there are a couple of stages here.
1st stage: electronic ignition and port fuel injection.
2nd stage: aluminum blocks/heads and overhead cams.
3rd stage: GDI/turbo combination.
Re: What is considered Modern Engine? [Re: UG_Passat] #5323631 01/15/20 04:33 PM
O
Onetor Offline OP
O
That is my point! I couldn't find one. Just wanted different perspectives and opinions.
Re: What is considered Modern Engine? [Re: Onetor] #5323649 01/15/20 04:52 PM
CT8 Offline
Marketing at its finest.
2015 F150 2.7
2018 F350 6.2
Re: What is considered Modern Engine? [Re: Onetor] #5323699 01/15/20 06:06 PM
G
GoldDot40 Offline
G
OBD II and up is "modern" in my book.
Equal Opportunity Offender
Re: What is considered Modern Engine? [Re: Onetor] #5323705 01/15/20 06:12 PM
ls1mike Offline
You do know the first OHC engine was built in or around 1902. Nothing modern about that. Just a different way of opening and closing the valves.
I would say OBDII and up. It really allowed you to get into the software/computer to troubleshoot and change settings.
Tolerances are much better now too.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: What is considered Modern Engine? [Re: Onetor] #5323712 01/15/20 06:22 PM
E
eljefino Offline
E
Overhead valve, so Oldsmobile and the Rocket V8 in 1949 I would consider modern. LOL
The SBC from 1955 had a great run and the LS motors still carry that torch.
Induction, fuel introduction, and exhaust changed a little, but not the "core engine".
Page 1 of 4 1 2 3 4
