Camry vrs Sonata
by tblt44 - 01/28/20 07:50 PM
Parasitic battery draw.
by wtd - 01/28/20 07:49 PM
AAP clearance 2020
by GMguy84 - 01/28/20 07:34 PM
2017-2019 GLA 250 4-Matic vs BMW X-1
by HangFire - 01/28/20 07:20 PM
Good news for .300blk shooters
by The_Eric - 01/28/20 06:43 PM
‘16 Lexus GS350 vs ‘16 Lexus RX350
by miden851 - 01/28/20 06:19 PM
Stone guard removal
by dawgn86 - 01/28/20 06:09 PM
Craigslist is like a petty HOA now
by eljefino - 01/28/20 05:06 PM
Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
indigo2020, Towkid, denor, Jubaxtreme, CAJ1966
70551 Registered Users
112 registered members (Avery4, BISCUT, adams355, BlueOvalFitter, Astro14, Alfred_B, 8 invisible), 3,021 guests, and 15 spiders.
Topics300,682
Posts5,181,037
Members70,551
Turbo Hydramatic 125C pan leaking...gasket material choices. #5323581 01/15/20 02:49 PM
B
BigD1 Offline OP
B
Had the old three speed transmission rebuilt just a bit over 2.5 years ago, and just recently the pan is leaking lots. The trans shop used a cork gasket on the pan.
I guess I could re-torque the pan bolts, but not sure that would help with the leak. I plan on dropping the pan, and installing a new filter and gasket. I have three choices for pan gasket material. Cork, ACDelco Professional Farpak, and ATP fibrous that seals with first heat cycle. Definitely not going with cork. No idea what Farpak is. The ATP fibrous sounds interesting, and I don't need to use a sealer with it.
ATP is reasonably priced, and the Farpak stuff costs about three times as much. Has anybody used the ATP kits with the fibrous heat cycle sealing gaskets?
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: Turbo Hydramatic 125C pan leaking...gasket material choices. [Re: BigD1] #5323708 01/15/20 05:15 PM
O
oldhp Online Content
Online Content
O
To me the best is the GM one with steel in between molded on rubber type gasket. Never leaks and reusable. Is this the ACDelco Professional Farpak?
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Turbo Hydramatic 125C pan leaking...gasket material choices. [Re: BigD1] #5323896 01/15/20 09:03 PM
clinebarger Offline
Farpak is also a fiber material with a heat sensitive glue, It's similar to what a TH125 would have had from the factory. 4L60E's used this style gasket 'til end of production in 2013......Works well if the pan hasn't bent-up by using a cork gasket.
If the ATP one is packaged flat like a Farpak.....Give it a try!
2001 Chevy Camaro L92/4L80E
Re: Turbo Hydramatic 125C pan leaking...gasket material choices. [Re: BigD1] #5323899 01/15/20 09:04 PM
A
atikovi Offline
A
[Linked Image from images-na.ssl-images-amazon.com]
If you never want leaks again.
Re: Turbo Hydramatic 125C pan leaking...gasket material choices. [Re: BigD1] #5324456 01/16/20 01:24 PM
B
BigD1 Offline OP
B
I ordered the ATP filter and gasket kit.
@clinebarger: Was not sure what Farpak was. Now I know...thanks.
@atikovi: The Ultra Grey is definitely my choice for a gasket maker. I have almost a full tube of it right now waiting for the next repair job. There is no way I would use it on a transmission pan. If just a little bit of it got in the trans valve body it could clog it up easily, so it's a no go for me.
Re: Turbo Hydramatic 125C pan leaking...gasket material choices. [Re: BigD1] #5324511 01/16/20 03:02 PM
A
atikovi Offline
A
1. The filter would prevent that.
2. You're using way too much if that is a concern.
3. Any RTV that squeezes out just stays there, it doesn't drop into the pan.
4. Most modern transmissions use it instead of a solid gasket because it's superior in preventing leaks.
Re: Turbo Hydramatic 125C pan leaking...gasket material choices. [Re: BigD1] #5324733 01/16/20 07:47 PM
R
Rhymingmechanic Offline
R
You should be fine with that. I've used a few of the gray ATP fiber gaskets with good results.
