Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
95 registered members (4WD, 55hambone, 53' Stude, 54Robert, 1foxracing, 7 invisible), 1,960 guests, and 17 spiders.
Topics300,274
Posts5,172,152
Members70,464
Most Online3,728
Jan 11th, 2020
Random thought about RV batteries #5323526 01/15/20 01:53 PM
chainblu Offline OP
Bear with me. As indicated in the thread title, this is just a random idea that I wanted to run by. I have a Travel Trailer and I'm in a few groups and about camping and "boondocking" in general. Many people report that 2 (or more) - 6 volt golf cart batteries, mounted in series (or series-parallel) is a better set-up than traditional RV batteries.
My golf cart uses 8 volt batteries. So, (hypothetically) lets say I used 2 - 8 volt batteries, which I know would give me 16 volts, BUT, once the initial charge is drawn down, my on-board converter will only bring it back to 12 (or so) volts.
My thought was: Would the bigger plates or whatever that makes the battery produce 8 volts give the battery extra capacity than a regular 6 volt battery?
Re: Random thought about RV batteries [Re: chainblu] #5323537 01/15/20 02:07 PM
old1 Offline
If I am not mistaken, what makes a battery 8 volts instead of 6 is the fact that it has 4 cells instead of 3 like a 6 volt, or 6 like a 12 volt.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
Re: Random thought about RV batteries [Re: chainblu] #5323539 01/15/20 02:10 PM
F
fsdork Offline
F
Your 8-volt batteries are likely designed to operate in a small voltage range just above 8 volts. As a comparison, the linked table shows voltage of a 12 volt battery relative to state of charge percentages. For that reason, I can't see how you could discharge your 8-volts (16 volts in series) to get them in range of your 12 volt travel trailer equipment. Not to mention the fact that the charger you presumably have built into your converter wouldn't charge the batteries properly based on the voltages it would see from them.
As for capacity of the batteries, that should be rated in amp-hours by the manufacturer, usually displayed on the sticker.
2003 Ford Explorer Limited 4.6L 4x4 - 219K km
2008 Ford CVPI 4.6L - 133K km
2011 Ford F-150 Lariat S/C 6.2L 4x4 - 90K km
Re: Random thought about RV batteries [Re: chainblu] #5323542 01/15/20 02:10 PM
F
fsdork Offline
F
Re: Random thought about RV batteries [Re: chainblu] #5323563 01/15/20 02:33 PM
M
mk378 Online Content
Online Content
M
They won't charge at all. And many of the devices in the RV will not like being hit with 16 volts (actually about 18 when fully charged). So stay with a 12 volt system, which can be done with two 6 volt in series.
If you have the space for extra batteries, two 12 volt in parallel is also an option.
The stored energy per weight or volume is about the same no matter how you divide up the cells between separate battery cases.
Re: Random thought about RV batteries [Re: fsdork] #5323586 01/15/20 02:53 PM
E
eljefino Offline
E
To jump on this, you'd be in the land of 90-95% discharged when it's within your appropriate 12 volt range. So you'd only have 5% of the batteries' capacity. And it's the part that's not good for them, at all.
Re: Random thought about RV batteries [Re: chainblu] #5323614 01/15/20 03:19 PM
chainblu Offline OP
Thank you to all that replied. Every post was helpful. My curiosity in this matter has been answered. smile
Re: Random thought about RV batteries [Re: chainblu] #5323671 01/15/20 04:31 PM
R
ragtoplvr Offline
R
The 8 volt was originally made for old 6V systems,, the regulator could be adjusted to 8, and the dim bulbs worked fine on 8. Then it was used for other functions. It was common for a time in race cars to get hotter point ingition and faster starters.
Re: Random thought about RV batteries [Re: chainblu] #5323738 01/15/20 05:54 PM
M
MasterSolenoid Online Content
Online Content
M
Maybe this may help -
Edit: Oh, I see your question is answered.
[Linked Image]
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Random thought about RV batteries [Re: chainblu] #5323922 01/15/20 09:28 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Do not use 8v batteries where 6/12v are specified. While it woukd work for a 24v nominal system, because it’s a common factor, it won’t work properly if at all for a 12v system.
Re: Random thought about RV batteries [Re: chainblu] #5325280 01/17/20 12:29 PM
L
Linctex Offline
L
Sadly....
many RV'ers do NOT realize that the "on-board charging system" NEVER gets the voltage high enough to equalize the cells in the battery....
That's why you hear about RV batteries dying after just 2 years - - they are ALWAYS slightly undercharged, at all times.
Bringing those "12 volt" batteries up to the full 14.82 volts every 3 months will dramatically increase their lifespan!!
(actually, Trojan battery data says you must reach 16.20 volts for a brief period to do an ACTUAL equalization)
