Good news for .300blk shooters
by The_Eric - 01/28/20 06:43 PM
‘16 Lexus GS350 vs ‘16 Lexus RX350
by miden851 - 01/28/20 06:19 PM
Stone guard removal
by dawgn86 - 01/28/20 06:09 PM
Craigslist is like a petty HOA now
by eljefino - 01/28/20 05:06 PM
Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
Am I killing my transmission?
by Avery4 - 01/28/20 08:52 AM
BorgWarner to buy Delphi in $3.3B deal
by wemay - 01/28/20 08:37 AM
COP's which brand
by Eric Smith - 01/28/20 07:56 AM
$150 off Bridgestone tires
by D1dad - 01/28/20 06:26 AM
Towkid, denor, Jubaxtreme, CAJ1966, Shiza
70550 Registered Users
120 registered members (2015_PSD, Astro_Guy, 2010Civic, atikovi, advocate, 11 invisible), 2,987 guests, and 18 spiders.
Topics300,678
Posts5,180,981
Members70,550
'01 Ranger 2WD Pinion Seal Replacement #5323445 01/15/20 12:33 PM
B
benjamming Offline OP
B
2001 Ford Ranger XLT 4.0L 5R55E 2WD 150k miles
I need to replace the pinion seal as it is leaking. I guess there's a small (?) chance it's something else but that is typically the issue I think. I've got the OEM pinion seal, nut, deflector (oil slinger), & new diff fluid/gasket. Will I need a new crush sleeve (collapsible spacer) or will using calipes to measure the distance from the end of the shaft to the nut suffice? The below video seemed pretty decent, but if you have any tips or other (better) videos, then I would appreciate it.
https://www.youtube.com/watch?v=scb_FcHtMZM
Thank you.
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5323533 01/15/20 02:00 PM
E
exranger06 Offline
E
Thank you.
What exactly IS the issue you have?
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5323626 01/15/20 03:27 PM
sloinker Offline
I don't know about your specific vehicle but in many cases you need a torque multiplier to get the needed force on this pinion crush washer install.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5323653 01/15/20 03:58 PM
M
mk378 Offline
M
If the input shaft has side play there is a bigger problem than just the seal. Check this before taking apart.
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5323667 01/15/20 04:26 PM
1
1978elcamino Offline
1
All you have to do is drop the drive shaft, tap off the yoke, R & R the seal, replace the yoke & drive shaft, top off fluid and you're on your way. You wont need a crush collar because the ring and pinion will not need to come out to replace the pinion seal. In order to get to the crush collar you have to remove the pinion, which is an entire tear down of the rear end, axles, center section, diff, brakes everything, NOT nescessary.
The pinion seal is leaking just replace it and keep and eye on it. No need to tear down the entire axle assembly. Your job should take you a half hour.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5323715 01/15/20 05:25 PM
cb_13 Offline
With the wheels off and brakes disassembled to prevent drag you need to check the rotational torque required to keep the differential turning by turning at the pinion nut. When reinstalling the nut tighten it until there is no play in the shaft. Then continue tightening until the rotational torque is back at the original reading.
If you over torque the pinion nut you will need a new crush sleeve.
This is the technique that the Ford workshop manual will tell you to use. Many people just tighten it up and call it good enough, probably not the best technique for long bearing life.
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: cb_13] #5323802 01/15/20 07:03 PM
M
mattd Offline
M
IIRC the target is 5 inch lbs more rotational drag upon reassembly compared to initial measurement.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5323807 01/15/20 07:05 PM
1
14Accent Offline
1
I've never gone through all that work when doing a pinion seal on a Ford rear diff. Just remove the D/S, mark the nut and pinion shaft with white out, count how many threads are visible, and zip it off. When you reinstall, you just get it close by the thread count then sure it up with your paint marks. Easy peasy.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: mk378] #5323940 01/15/20 09:48 PM
B
B
Thank you. Good point.
Yep. What is the typical torque values that can be expected? I don't have a dial torque wrench but could probably borrow one but would need to know range.
But Ford says to use a new nut which would no longer have the white paint mark. :dunno:
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5323947 01/15/20 09:56 PM
clinebarger Offline
Mark the nut to the pinion like 14accent stated.....Use Red Loctite on the pinion threads upon reassembly! Probably needs some RTV on the yoke splines as well.
2001 Chevy Camaro L92/4L80E
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5324226 01/16/20 09:19 AM
1
1
If you are replacing the pinion seal due to a leak, why is there even a discussion of removing anything but the drive shaft and the yoke? This is a Ranger with an 8.8, so nothing needs to be taken apart to replace the pinion seal. Talking about the crust collar being replaced requires complete tear down, including removing the pinion gear, axles, differential etc, which is not even close to nescessary for pinion seal replacement. This is a 30 minute job tops.
2018 F150 5.0
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: 1978elcamino] #5324289 01/16/20 10:30 AM
cb_13 Offline
Because I was discussing the proper procedure from the workshop manual. How you choose to do it is up to you. If you want to pull it apart, slap it back together and run it up to 3 ugga dugga's with an impact no one on this forum is going to turn you in to the maintenance police.
I have had to replace crush sleeves due to inexperienced techs using that exact method. So I recommend people doing it by the book, if you've done 100+ pinion seal replacements you probably know when to stop tightening it before reaching that point.
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: benjamming] #5324294 01/16/20 10:34 AM
cb_13 Offline
I believe 20 inch pounds should be about right to maintain rotation.
Re: '01 Ranger 2WD Pinion Seal Replacement [Re: 14Accent] #5328388 01/20/20 11:56 PM
A
Anduril Offline
A
This is how I did it on my XTerra, it's been fine for a year and a half since then.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
