Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
104 registered members (2002 Maxima SE, AndyB, 14Accent, A_User55555, beast3300, ABerns, 8 invisible), 2,322 guests, and 40 spiders.
Topics300,342
Posts5,173,738
Members70,486
Most Online3,825
Jan 19th, 2020
Time for High Mileage oil for very slight timing cover seepage? #5323404 01/15/20 11:59 AM
J
jayjr1105 Online Content OP
OP Online Content
J
Long story short, I thought I had some coolant seeping around the water pump. Local shop confirmed it's not coolant but a slight oil seepage above the water pump coming from the timing cover seal. Almost 70K miles on the engine. Is it pretty cut and dry to start using something with some seal swellers?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323409 01/15/20 12:03 PM
PimTac Offline
Seal swellers work on gaskets. Yours probably has a sealant bead in between.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: PimTac] #5323414 01/15/20 12:08 PM
J
OP Online Content
J
On an unmodified engine?
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323415 01/15/20 12:09 PM
B
BMWTurboDzl Offline
B
Why not replace the part instead?
435i
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: BMWTurboDzl] #5323422 01/15/20 12:14 PM
J
OP Online Content
J
Haven't gotten that far in research. Have no idea on price/labor.
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323430 01/15/20 12:21 PM
J
Jimmy_Russells Offline
J
What kind of engine? It could be silicone but also could be a big o-ring. Is the timing cover plastic or metal?
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323469 01/15/20 12:58 PM
J
OP Online Content
J
2.0L Skyactiv G. If I had to guess I'd say plastic knowing modern cars but not certain.
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323494 01/15/20 01:18 PM
M
Mad_Hatter Offline
M
If it's a rubber seal, a HiMi lube might help restore it's elasticity and size.. or not. Just depends on how badly it's worn/damaged, sometimes seals are just too far gone for a mechanic in a bottle. Run a HiMi for an oci and if it hasn't stopped leaking, you're gonna need to replace it.
Fwiw, +60k on a seal or gasket seems like a short lifespan. Is this normal for this engine? You might research it before buying an OE seal.. maybe there's higher quality seal/gasket our there?
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: Mad_Hatter] #5323495 01/15/20 01:23 PM
J
OP Online Content
J
#1 it's a very slow seep, like maybe a drop or two per OCI. #2, If it's timing cover seal, it's rather expensive and labor intensive. not like a valve cover gasket which is easy DIY and $10. #3 I agree on 70K and having leaking seals already is BS.
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323506 01/15/20 01:35 PM
A
aquariuscsm Offline
A
Anyone here ever try Liqui Moly Motor Oil Saver for oil leaks vs hm oils?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323554 01/15/20 02:24 PM
The Critic Offline
Timing Covers on modern engines are sealed using RTV. Seal swellers have no effect on RTV.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323762 01/15/20 06:22 PM
M
mpack88 Offline
M
My 2018 Ford Taurus had a timing cover leak at only 3,000 miles. I waited to fix it at about 8000 miles. On that duratec 3.5 L the whole timing cover was sealed by silicone. A himi oil would not have any effect on that. luckily for me it's under warranty, and for your info the duratec 3.5 L was developed by Mazda.
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5323813 01/15/20 07:20 PM
1
14Accent Online Content
Online Content
1
That timing cover is all sealant. See:
2.0 timing chain repair
About 2/3 of the way down you'll see the instructions for re-sealing and installing the timing cover.
Almost all of those motors I see have a little seep from that area, all the way back to the MZR 2.0/2.3 days. I wouldn't worry about it much, just degrease the area to clean it up and watch how long it takes to re-form.
I'll tell you this: re-sealing a timing cover in-chassis is NOT fun, in any FWD car. You have to be exactly exact, or it will leak.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: The Critic] #5323820 01/15/20 07:32 PM
M
Mad_Hatter Offline
M
Depends on what's in the seal conditioner. Some silicones are susceptible to swelling (increased volume) when exposed to certain chemicals. It just depends on the chemistry of the RTV. See the following link and pic...
Silicone Rubber
[Linked Image]
[Linked Image]
Re: Time for High Mileage oil for very slight timing cover seepage? [Re: jayjr1105] #5324207 01/16/20 09:02 AM
J
OP Online Content
J
Thanks guys. I will likely just clean it up once in a while and not worry about it unless it gets much worse.
