Shell selling rebranded Pennzoil in Europe?
by FordCapriDriver - 04/02/20 02:54 AM
Mitsubishi Mirage for Basic Transportation
by parimento1 - 04/02/20 12:54 AM
Amsoil EaOM103
by Lufty - 04/02/20 12:46 AM
Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
29 registered members (Blackgogo, blufeb95, bbhero, 1foxracing, Alex_K, avi1777, 4 invisible), 685 guests, and 23 spiders.
Topics303,470
Posts5,235,706
Members71,074
2014 Mini Cooper JCW recs? #5323073 01/15/20 04:06 AM
N
Nola_mike Offline OP
N
Just picked up a '14 Mini Cooper JCW convertible (so second generation). Looking for oil recs, surprised that I can't find much here.
Manual recommends 0W-40, 0W-30, 5W-40, or 5W-30, BMW Longlife-01 / BMW Longlife-01 FE
Since these LL-01 seem to be a moving target, seeing what the latest recs are. I had been using Pennzoil platinum euro 5w-40 or castrol edge 0w40/0w30 on my '01 BMW e46, which had similar specs for the oil.
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5323075 01/15/20 04:14 AM
The Critic Offline
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5323104 01/15/20 06:23 AM
N
N
As is the case when I spend too much time here, I'm going down a rabbit hole of different specs, tests, etc.
What's the TL;DR version for availability at my FLAPS or Wally world?
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5323296 01/15/20 10:54 AM
1
14Accent Offline
1
I recommend turning around and selling it before it drives you up the wall with shoddy build quality and insane repair costs.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5323357 01/15/20 11:58 AM
J
Jimmy_Russells Offline
J
If you're not a stickler for using exactly the spec in the book I'd probably go with Mobil 1 ESP (LL04). If you do want to stick with LL01 specs Mobil or Castrol 0w40 are good choices too, but I think they may have recently lost LL01 because it is not being approved anymore and the previous certification timed out. If you really want to stick to something that has LL01FE on the bottle I'd probably go with the Mini/BMW 0w30 (which is Shell/Pennzoil) which can be had for decent price online.
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5323458 01/15/20 01:49 PM
N
NYSteve Offline
N
The B48 engine you have is good for everything from LL01 - LL14FE oil. Basically anything from 0w-20 to 5w-40.
https://www.newtis.info/tisv2/a/en/...e-general-note/00-00-maintenance/1PSryV8
I have a 2016 JCW and run Castrol Edge 5w-40 because it has a cert and is still under warranty.
There is a guy on craigslist selling 6qt cases of Genuine MINI/BMW 0w-30 for $24/case as well.
Think you'll be good with anything you listed or is reco'd here.
Re: 2014 Mini Cooper JCW recs? [Re: 14Accent] #5327598 01/20/20 09:01 AM
M
MCompact Offline
M
As usual, a question about a European car brings out the BITOG "read testers". You haven't even sat in one, I'd bet.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5327599 01/20/20 09:03 AM
M
MCompact Offline
M
I run BMW TPT 0W-30, but any of the above recommended oils will work fine.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5337683 01/31/20 09:00 PM
N
N
Are there other certs I should look for aside from LL-01? others that are "long life"?
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5338070 02/01/20 11:37 AM
M
MCompact Offline
M
I'd just use an LL-01 or LL-01FE oil.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
Re: 2014 Mini Cooper JCW recs? [Re: MCompact] #5338122 02/01/20 12:32 PM
N
N
Right, that's what I was looking for, but the LL-01 that I had previously used (Castrol edge, m1, Pennzoil Platinum) are either no longer LL-01 or harder to find. I can't find a standard easy to find LL-01FE from one of the big guys. As usual probably overthinking. A "euro" 0w-30/40 like the Castrol is fine I'm sure even though it's no longer LL-01. I mean, my e46 has 230k miles using those oils, so...
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5338139 02/01/20 12:49 PM
K
KCJeep Offline
K
BMW is letting the LL-01 fade away, so oils that are certified for it are harder to find. LL-01 suitable is not. If you are not trying to satisfy a warranty, any Euro oil that meets MB 229.5 will be more than sufficient.
2018 VW Passat GT VR6 - 25k - Castrol Pro OE 5w40 - VW OEM filter
2012 KIA Sedona 106k - Valvoline Maxlife 5w30
2012 VW Tiguan 106k - Castrol 0w40
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: 2014 Mini Cooper JCW recs? [Re: Nola_mike] #5338208 02/01/20 02:12 PM
E
edyvw Offline
E
Your target should be MB229.5 as it is more stringent than LL01.
LL01FE is energy saving oil and in my case, will never find its way to any Euro car I own.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
