These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
Not on sale but theeeeeeyyyyy're here!
by jayjr1105 - 01/17/20 06:47 PM
Valvoline Daily Protection 5w30 - $13.52 at Walmart
by RonRonnster - 01/17/20 06:39 PM
Gotta love Friday
by 53' Stude - 01/17/20 06:11 PM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
92 registered members (53' Stude, 55hambone, aba4430, 2015_PSD, 2strokeNorthstar, 2010Civic, 6 invisible), 1,581 guests, and 15 spiders.
Topics300,271
Posts5,172,117
Members70,464
Most Online3,728
Jan 11th, 2020
Should I take a stab at doing my water pump? #5322926 01/14/20 09:59 PM
J
jayjr1105 Offline OP
J
Mazda 3 2.0L skyactiv. I have the pump on hand already along with gaskets, coolant, and the belt. Local guy (who I trust) quoted a rough estimate of $200-ish.
Water pump seems pretty straight forward to me, remove, replace, refill but maybe there's some gotcha's with modern engines.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5322933 01/14/20 10:03 PM
CT8 Offline
Either you have the ability or you don't. It is not something you want to fool yourself with.
2015 F150 2.7
2018 F350 6.2
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5322947 01/14/20 10:22 PM
Snagglefoot Offline
Ok, here we go. Make sure you have a good scraper. Buy some chemical gasket remover but wear goggles and rubber gloves. The FBI hates this stuff because it will remove your fingerprints ( from your fingers). Ask how I know. Do some research to see if you need to use thread sealant.
Have a pan ready underneath the car. The biggest thing is, you have to remove all of the old gasket from the block. If they used gasket sealant it might take hours. Have lots of beer on hand.
A small torque wrench is nice but not totally required. Lots of ways to deal with gaskets. I’ll let the others chime in on their favourite techniques.
I highly recommend watching a you tube video of your model of car. Also see if you can find a torque sequence and torque value. One other tip is to use a half inch ratchet, not a girly-man 3/8. You might have to give it some tough love when disassembling every thing. I recommend taking photos of everything. It’s discouraging to find a spare nut after you have it buttonedy up. And worse, it dribbles coolant because you didn’t clean the block. Good luck.
Did I mention cleaning the block?
laugh
If you want the job done right......do it yourself.
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5322967 01/14/20 10:38 PM
R
Rolla07 Offline
R
Mental note taken after reading snaggle's post lol..(pay to have it swapped out)
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5322972 01/14/20 10:42 PM
H
hatt Offline
H
If you have to ask you should probably pay the $200.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5322979 01/14/20 10:49 PM
M
mazdamonky Offline
M
I highly recommend purchasing plastic razor blades to help get the old gasket off. Gouged the pump housing on a car once with a standard razor blade and couldn't get the gasket to seal properly so i ended up having to take it all back apart to add a dab of liquid gasket. Lesson learned. Not sure how hard it would be on a skyactive motor, but my old Mazda FS is relatively straightforward. Depending on the time of the year and the weather, I would pay 200 to have someone else do it. Last time I did it, it was snowing. For 200 I would have paid someone else to suffer in single digit weather and 2 days worth of snow.
2018 mazda3 hatch 2.5 26148 miles
1985 rx7 1.1 100k miles
2002 protege 236k miles
1985 rx7 with a 5.0 swap
2020 corolla 750 miles
4 more running cars in yard not mentioned
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5322981 01/14/20 10:53 PM
N
natas Offline
N
I looked at a video on it here: https://www.youtube.com/watch?v=q54MaHhC7HA and here: https://www.youtube.com/watch?v=qI-7Drztonc
If your car is like that, you got it easy. You don't have to worry about removing the top motor mount and jacking the engine up/down because of close clearance to the side making pump removal impossible otherwise. I'd say go for it.
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5322982 01/14/20 10:54 PM
E
Exhaustgases Offline
E
And if you end up goofing something up real bad the cost could way exceed the 200 figure. Just break the wrong bolt off and the engine may possibly need to be removed.
Makes 200 sound real good. I'm not familiar with that engine but if it is like some where the timing belt drives the pump, and you get that wrong then you'd be looking
at a total engine replacement.
Re: Should I take a stab at doing my water pump? [Re: Snagglefoot] #5323063 01/15/20 02:05 AM
The Critic Offline
laugh
https://www.bobistheoilguy.com/foru...zda-2-5l-skyactiv-water-pump#Post5194360
It uses an o-ring. No scraping, no sealer.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5323065 01/15/20 02:05 AM
B
Black_Thunder Offline
B
actually that looks like a pretty simple replacement. if the water pump was driven by the timing chain it would be internal underneath the timing cover and would cost a lot more then 200 dollars to replace.
looks like there is no gasket so cleaning up the surfaces should be minimal and could done with a piece of sand paper and just make sure the groove where the o-ring goes is clean and lube the o-ring before you put the pump back on either with some coolant or a smidge of di-lectric grease.
the hardest part looks like taking off the top idler pulley mount assembly and taking off the pulley from the water pump itself.
I think its doable.
I'd buy Callahan autoparts if I could.
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5323083 01/15/20 03:50 AM
dave1251 Offline
Give it a try you will do it and do it well if you want to and have to determination.
don't use.
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5323087 01/15/20 04:25 AM
dlundblad Offline
I say do it. We’ve all got to start somewhere. 10 years ago I wouldn’t have touched it and now I do all my repairs.
Is the water pump driven from the timing belt? That’s the only thing that can be tricky.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5323091 01/15/20 04:43 AM
demarpaint Offline
Read up on it, ask questions, watch videos and go for it! That's how you learn. One suggestion, if after all that you determine you can't do the job, pay a pro.
God Bless Our Troops
Re: Should I take a stab at doing my water pump? [Re: jayjr1105] #5323095 01/15/20 04:53 AM
Char Baby Offline
Youtube is your friend.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Should I take a stab at doing my water pump? [Re: Char Baby] #5323124 01/15/20 06:16 AM
B
BMWTurboDzl Offline
B
+1
And remember....righty-tighty, lefty-loosie
435i
