best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
JDXer, Ivan30, mikespine, Typerguy, showtyme1958
71530 Registered Users
113 registered members (Atrocious, 928, 4WD, apollo18, 330indy, 2015_PSD, 9 invisible), 2,531 guests, and 64 spiders.
Topics305,897
Posts5,282,306
Members71,530
Page 1 of 3 1 2 3
Spark Plug Tips #5322738 01/14/20 07:03 PM
MolaKule Offline OP
Global Moderator
Global Moderator
With the use of new exotic metals for spark plug electrodes, these tips last much longer with little tip erosion.
The following question concerns the spark tip geometry and a bit of electrical/physics theory.
Q: Why do many, if not most, modern plugs today have what is known as the "Fine Wire" center electrode tips?
This question is NOT open to any engineering discipline or physicists.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: Spark Plug Tips [Re: MolaKule] #5322763 01/14/20 07:47 PM
L
littlehulkster Offline
L
Fine wire requires less voltage to fire, and so it lasts longer.
It also can allow for an increased plug gap to fatten up the spark, although I think the durability is the primary concern.
2015 Mazda3 I 2.0
Re: Spark Plug Tips [Re: MolaKule] #5322771 01/14/20 07:55 PM
R
Rob_Roy Offline
R
So they can use less of the precious metal. wink
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Spark Plug Tips [Re: MolaKule] #5322775 01/14/20 08:08 PM
skyactiv Online Content
Online Content
It's easier to make a spark from a thinner electrode than a thicker one. So it will make a better spark at the same voltage vs a thick electrode.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Spark Plug Tips [Re: MolaKule] #5322777 01/14/20 08:10 PM
spasm3 Online Happy
Online Happy
I don't fully understand it. But from what i understand , the smaller tip increases the density of the spark. I don't really understand the plasma part of it though. I'm thinking the tip being smaller also stays hotter/ cleaner with less area, and that necessitates the use of metals like platinum and iridium to survive for long.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Spark Plug Tips [Re: MolaKule] #5322780 01/14/20 08:15 PM
J
JayhawkRoy Offline
J
OK,here goes:
1. Fine wire allows for more efficient spark.
2. Fine wire allows for wider gap and therefore hotter spark.
Re: Spark Plug Tips [Re: MolaKule] #5322804 01/14/20 08:47 PM
Convert Offline
Fine wire also allows more fuel to ignite around the tip plus what others have stated above, something called the flame kernel.
My info is based on info from various Motorcycle mags and their interpretation may or may not match up to others interpretations but in principle is presented based on application .
Think about the size of a motorcycle engine and the power output, HPvs CI. My bike is 948 cc ( 60 ci ?) and produces 71 HP. These are standard without mods but as delivered. If a Car engine was made more HP than Cubic Inches and we have cars delivered today that meet that example, so the plug type and style were developed to meet that need.
We / You have access to Standard tip, Projected tip, U Grove , Fine wire, multiple side electros ,Capacitive discharge E3 style .
Gaps have been closed or expanded to meet the demand to basically meet the electrical demands of the combustion process.
TOMB
Convert
TOMB
2006 Volvo XC90
2013 Toyota Tacoma TRD Sport
1976 Moto Guzzi Convert
USAF 1966-1970
Re: Spark Plug Tips [Re: MolaKule] #5322823 01/14/20 09:02 PM
Surestick Offline
It's easier to get a spark from a pointed object as the electrical field is stronger at a sharp edge.
As the new materials used for the electrodes are more resistant to erosion they can be made smaller/thinner and still last.
Re: Spark Plug Tips [Re: MolaKule] #5322840 01/14/20 09:17 PM
Ded Mazai Offline
Thinner electrode tips absorb less heat. Therefore the initial flame temperature is higher, the ignition is more reliable.
BRZ | M1 HM 5W-20, FU | PZ Synchromesh.
Re: Spark Plug Tips [Re: MolaKule] #5323102 01/15/20 06:12 AM
K
Kira Online Content
Online Content
K
Faster spark initiation.
Re: Spark Plug Tips [Re: MolaKule] #5323116 01/15/20 07:03 AM
danez_yoda Offline
Three reasons
1) The fine wire is made from expensive exotic metal (Iridium, Platinum) so reducing the diameter of it saves cost
2) The fine wire geometry makes it easier to generate a spark across a given gap size. Easier on the coils.
3) Fine wire allows better room around the spark for the explosion to expand and fill the combustion chamber (small performance benefit)
Re: Spark Plug Tips [Re: MolaKule] #5323204 01/15/20 09:39 AM
DrDanger Offline
Thinner/sharper electrode has a lower voltage requirement to reliably produce a spark.
U-groove and/or larger gap make a bigger flame kernel. Bigger and uniform flame kernel
should ignite more of the charge evenly and efficiently. I think it should increase flame front speed, but I could be wrong.
Would be interested on the full info Mola thumbsup
Re: Spark Plug Tips [Re: MolaKule] #5323664 01/15/20 05:21 PM
B
barryh Offline
B
Because lightning conductors are pointed.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
Re: Spark Plug Tips [Re: MolaKule] #5323711 01/15/20 06:22 PM
SaintElmo Offline
Maybe they fire better with a more pointy tip and the rare earth elements lose less metal to maintain that pointy tip and constant gap.
Re: Spark Plug Tips [Re: MolaKule] #5323949 01/15/20 10:57 PM
MolaKule Offline OP
Global Moderator
Global Moderator
All good answers folks. thumbsup
As the diameter of the center electrode is made smaller, the electric field intensity between the electrodes is stronger.
The arc diameter being smaller results in a higher current density of electrons flowing through the gas.
The higher density of electrons produce more intense collisions (imparts more kinetic energy) to the gas molecules in the gas/air mixture resulting in a spark gap temperature of 6000 Kelvin for more efficient combustion.
The exotic (refractory) inner electrode metals resist erosion in the glow discharge phase.
In the glow discharge phase, a glow discharge period occurs when the current reaches about 300 milliAmps and the temperature drops to 3,000 degrees Kelvin. It is during this phase that most electrode material is eroded away from the center electrode. The glow discharge phase lasts longer than do the previous two phases.
In the White Papers and Technical Discussions there were these articles which have additional background information:
Quote
Physic of the Gap I and II (combined)
Today’s spark plugs operate in a very hostile environment and can continue to operate to over 100,000 miles due to advanced gap materials. Platinum, Iridium, yttrium and other refractory metals have replaced copper as the inner electrode. The ground electrode is usually composed of nickel-ferrous alloys.
An overview of ignition systems can be found at:
http://www.jetav8r.com/Vision/Ignition/CDI.html
The vehicle’s electronics supply current to the ignition coil’s primary and step up the voltage from 12 V to 30,000 volts or more on the secondary, a voltage step-up ratio of
~ 2,450.
The spark plug gap is essentially a capacitor with two plates, the center electrode and the “ground” electrode. The voltage across the gap is increased until the voltage exceeds the breakdown voltage of the gas. A current then flows which ignites the gas and a hot, plasma cylinder forms in the gap at T = 6000K (5727C, 10340F). Later in time, the plasma forms a sphere that propagates outward from the spark gap.
In dry air at Standard Atmospheric Pressure (STP), this breakdown voltage is 3,000 volts per millimeter. For a gap of 0.030 inches, the gap is equal to 1.2 mm. This results in a breakdown voltage of 3.600 volts for this gap for dry air.
But there is some added complexities here.
1) There is a law of Physics called, “Paschen’s Law” which says the breakdown voltage (we call it ‘potential’ in Physics) is a function of the distance D between the electrodes, Pressure of the gas, and Temperature T, or Vb = f(Pcycl, Dgap, Tgas). The greater the pressure and distance between the electrodes, the greater the voltage has to be between the electrodes for an arc to cross the gaps.
2) The temperature of the gas mixture also adds some complexity to the breakdown voltage required.
3) The constituency (makeup) of the gas (hydrocarbons and atmospheric gas molecules) in the cylinder also adds to the breakdown voltage requirement.
So we need at least 5 times 3,600 volts or greater than 18,000 volts.
The ignition voltage of modern systems is about 3 to 4 times that in order to insure reliable combustion in cold temperatures, and to overcome resistances in the wiring and spark plugs.
We now examine the nuances and the timing of events in the spark itself. We will not discuss the spark timing with relation to piston position, which is today determined by various sensors, such as crankshaft sensors and lookup tables in the ECU’s software.
In a typical spark discharge system, the electrical field is increased until the voltage across the electrode gap breaks down the cylinder’s gaseous mixture. The impedance of the gap decreases when a streamer reaches the opposite electrode. Ionizing streamers then give rise to a current which increases rapidly.
There are three stages to this process: The breakdown phase, the arc phase, and the glow discharge phase.
All of these phases happen within window of < 2.0 milliseconds.
In the breakdown phase, the voltage rises until current flows through the ionizing mixture, which can be as high as 200 Amps. But this high current only lasts for about 10 nanoseconds. The ionization channel is a cylinder of about 40 micrometers. The temperature in this ionization column gets to 6,000 degrees Kelvin (5727C, 10340F).
A shock wave is also created with a pressure of about 250 atmospheres (3, 625 PSI). As the shock or blast wave propagates outward, the temperature and pressure of the ionization channel falls rapidly. The pulse creates a flash of heat that helps the fuel charge reach the required light-off temperature to ignite the air-fuel mixture.
The heat provided by the plasma gives the air-fuel mixture a head start to achieving the temperature required to ignite. In addition, this pulse ionizes the gaseous air/fuel mixture, breaking down air/components like H² and O² into their atomic state H and O where they are most volatile. These highly excited elements react to the spark by igniting instantly. The result is improved throttle response.
The high-intensity pulse breaks apart the long hydrocarbon chains found in the nearby air-fuel mixture into shorter chains that react quickly. This rapid burn creates higher peak pressure
The current then drops rapidly to the arc phase. During the arc phase, the voltage drops to about 150 volts but the current is still up around 100 Amps, and the temperature of the ionization channel drops to about 3,600 degrees Kelvin. The arc increases in size due to heat conduction and mass diffusion.
A glow discharge period occurs when the current reaches about 300 milliAmps and the temperature drops to 3,000 degrees Kelvin. It is during this phase that most electrode material is eroded away from the center electrode. The glow discharge phase lasts longer than do the previous two phases.
The material eroded away during each spark is very minute, but does add up over time, which is why replacement is necessary. As material is eroded away of course, the plug gap increases.
At about 1.25 miliseconds, the current and voltage have decayed to zero.
How much energy is delivered per phase is determined by the ionization physics of the plasma channel.
When the ECU commands a current pulse to the ignition coil's primary, you want as fast a change in coil current as possible in order to create a high voltage at the coil's secondary.
You want the highest voltage available in the shortest amount of time at the SP gap to ignite the plasma. The overall rise time of the voltage on the coil's secondary is a function of the coil's leakage inductance, resistance of wiring and plug, capacitance of external circuit, gap width and cylinder pressure, and gas species. That voltage rise time is designed into the ignition system.
Too much ignition system delay wrt piston position affects combustion efficiency, which in turn affects engine performance and mpg.
When I am speaking of the SP gap rise time, I am speaking of the initial current curve showing the leading edge of the SP gap current as the voltage rises to about 35,000 volts and just before current flows. Upon ignition of the plasma, the current rises to about 200 Amps but only sustains this level for about 10 (10^-9) seconds or 10 nanoseconds.
The total amount of Energy supplied to the spark is about 80 milliJoules and is divided into 3 phases:
During the breakdown phase, an energy of 20 milliJoules is distributed as follows: Plasma energy – 94%, Heat loss to electrodes – 6%.
During the arc phase, an energy of 10 millijoules is distributed as follows: Plasma energy – 55%, Heat loss to electrodes – 45%.
During the glow phase, an energy of 50 milliJoules is distributed as follows: Plasma energy – 30%, Heat loss to electrodes – 70%.
Here is another interesting fact:
The resistance of the arc varies with time in a SP but is on the order of 0.005 ohms for the first few nanoseconds and then increases to about 1 ohm for the other two phases.
Arc Energy = I^2arc X Rarc X delta [time], so for the initial current rise of 200 Amps in 10 nanoseconds, Energy = 2.0 uJoule.
So, give thanks for this device that works so hard in such a high temperature, high pressure environment.
Page 1 of 3 1 2 3
