RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
JDXer, Ivan30, mikespine, Typerguy, showtyme1958
71530 Registered Users
102 registered members (AlienBug, Ag76, AndyB, AandPDan, apollo18, 11 invisible), 2,594 guests, and 52 spiders.
Topics305,899
Posts5,282,406
Members71,530
Page 1 of 6 1 2 6
GM 2.8 Diesel Canyon MIL: p244c and p24a0 #5322659 01/14/20 05:26 PM
dogememe Offline OP
Ambient temp is about -20f and our check engine light is on now with these two codes. Some googling shows that this is related to the dpf Regen not making sufficient progress. Is this normal due to the temps or is something actually wrong with the truck? In 1500 approx miles on our trip it's done at least two passive regens (you can hear the noise and mpg goes down) but no active regens (will display message in truck). Thanks all for your input.
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~292K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5322686 01/14/20 05:59 PM
G
GMguy84 Offline
G
I remember when those came out in 2015 they had issues. I was working at a Chevy dealer down in Burlingame and first Colorado diesel we got in BROKE DOWN during a test drive on the 101 lol
Turned out to be a bad fuel injector
And no the guy didn't buy it HA
Dave
01 Silverado 1500HD Shell RGT 5W30/XG3675
07 Suburban 1500 Mobil Super Syn 10W30/XG10060
82 Trans Am (KITT) M1 10W40HM/XG5
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5322737 01/14/20 07:02 PM
dogememe Offline OP
Ok, so after clearing the codes they came back about 20 mins later.
Went in to a Chevy dealer and they said the def is too cold so it's injecting a bunch of diesel to try to warm up the dpf.
They suggested trying to get temps up by driving in lower gear. We tried that and while our coolant temp went from about 165 to 175 the egts wouldn't increase. Would covering part of the grille help in any way? We've been averaging 165 coolant temp and to me that seems odd, my gassers usually hover at 195.
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5322751 01/14/20 07:31 PM
wwillson Offline
Administrator
Administrator
Your coolant temp and oil temp are probably way too cool, but at those ambient temps, it's hard to keep an engine at optimal operating temp. Yes, it would almost certainly help to restrict the airflow into the grill. I don't know what your grill looks like, but black duct tape works really well in a pinch. DO NOT over restrict and DO NOT directly cover the radiator. I do tape off the grill on my Durango, else the oil temp never gets above 160F, which causes the oil pump to stay in the high pressure mode. Start with about 50% of the grill taped and work from there. Cruising down the interstate at 70MPH and a outside temp of -15F I can cover all of the upper and lower grill, except a square about 8" and the water and oil temp will run about 175F.
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: wwillson] #5322782 01/14/20 08:17 PM
dogememe Offline OP
Now we have P244A and "reduced engine power"
We're going to cover the grille and clear the codes and go from there. Thank you!
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5322786 01/14/20 08:22 PM
A
atikovi Offline
A
In Cali?
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: atikovi] #5322798 01/14/20 08:43 PM
M
mattd Offline
M
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5322862 01/14/20 09:40 PM
CT8 Offline
Cold does amazing things to machinery.
2015 F150 2.7
2018 F350 6.2
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5322968 01/14/20 11:39 PM
Snagglefoot Offline
Can you get some insulation around the DEF tank, even some fibreglass pink If you can tape it on with electrical tape or duc tape. They might have small amounts at a building store. Watson Lake is -50 F tonight but it’s all starting to warm up this week. Not sure where you are but holding up at a hotel for a day or two might make a difference.
Failure is not an option. shocked2 shocked2
If you want the job done right......do it yourself.
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5323121 01/15/20 07:08 AM
wwillson Offline
Administrator
Administrator
Your charge air is also way too cold. Diesels smoke white from incomplete combustion when the intake air temp is cold, your temps are extremely cold. Partially covering your grill will also increase your charge air temp, which will give more complete combustion and decrease the fill rate of your DPF. You're fighting the effects of extreme cold and hopefully you be able to burn the soot out of the DPF before you go into limp mode. Once in limp mode, at those temperatures, you are in a corner you just can't get out of.
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5323169 01/15/20 08:52 AM
CleverUserName Online Content
Online Content
Wrapping the exhaust piping and DPF with high temp insulation would help. As well as using a fuel additive to help the fuel burn would reduce soot loading.
I also recommended that you insulate or heat the DEF tank in the other thread.
If your DPF gets plugged that’s it. End of the road as they say...
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5323228 01/15/20 09:56 AM
6
67ZL1 Offline
6
All my diesels have their winter fronts on when it hits 0°F. I can run down the highway at 60 mph in -40 and my coolant temps hang out at 192-195°F
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5323353 01/15/20 11:48 AM
dogememe Offline OP
My friend who owns this truck did a bunch of research. Checked online to see what other owners of diesel Colorado/Canyon owned were experiencing, and nobody else had trouble with cold temps. That's why I disregarded some of the advice in the other thread regarding the DEF freezing.
We also saw plenty of trucks like ours... Easily identifiable by the little Duramax Diesel badge. None of these had those grille covers or anything. And I doubt all these people are driving around with check engine lights.
After we zip tied cardboard to the grille and romped on it a little bit, and were able to keep the coolant temps about 10 degrees higher than before, we cleared the codes. It seemed to be attempting a regen at that point (EGTs about 800 and 15mpg instant fuel economy). Unfortunately about 30 miles later the check engine light came back and we have the P244C and P24A0 codes. However, the P244A code that was resulting in reduced engine power didn't come back, which was nice.
If I understand correctly, if the truck can't regen the DPF will get clogged. And the truck won't work anymore!? Sounds like it's time to take it to a dealer because this truck is under warranty and we can't have it suddenly stop driving in these temps.
We called a Chevy dealer and told them the codes and what was happening and the service guy straight up said "you should call GMC roadside assistance because it's their problem, not yours" sounds like he was right. We'll call GM when my friend wakes up.
PS: In the meantime this just looks ridiculous! I feel like my 300K mile Suburban would have handled this trip better than this fancy truck LOL.
[Linked Image from i.imgur.com]
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5323364 01/15/20 12:05 PM
Snagglefoot Offline
Don't worry. You'd fit right in if you drove through Saskatchewan. Good idea on the roadside assistance. Take a day or two off. It's only getting warmer.
Go into a Canadian Tire and see if they have a decent looking front cover. Keep us posted. Can you see if your DEF is frozen? Snag.
Re: GM 2.8 Diesel Canyon MIL: p244c and p24a0 [Re: dogememe] #5323365 01/15/20 12:07 PM
Snagglefoot Offline
This.
Page 1 of 6 1 2 6
