2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
coondog, steelbeams, Pete44, Connie7, 2020XT
70520 Registered Users
77 registered members (BAJA_05, bbhero, atikovi, bachman, Bighorn2500, 11 invisible), 1,879 guests, and 19 spiders.
Topics300,520
Posts5,177,667
Members70,520
2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles #5322717 01/14/20 05:34 PM
N
natas Offline OP
N
Previous owner changed oil every 1,000 miles with QSAD 10w40. I wasn't sure how far along miles-wise the fresh oil in the bike was when I bought it, I figured under 500 miles--as it was still clean. I went ahead and got an oil analysis on the oil for piece of mind when I changed it myself for the first time. Instead of going back with QS, I put Shell T4 Rotella 15w-40 instead. I'll do another UOA at 17K and compare to this one. So far, the Rotella seems to run just fine, but in all fairness, the QS that was in there originally didn't seem bad either. If anything, the Rotella gives slightly smoother shifting, but it could have been me since I'm a n00b rider that's learning more/getting better each time I ride.
[Linked Image]
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: natas] #5323007 01/14/20 11:49 PM
B
Bonz Offline
B
Looks like a nice report, I would say the heavier base weight Rotella has better than a 50-50 chance of feeling better for shift quality based on my experience with different bikes over the years. And "should" hold shift quality longer because it does not use as much viscosity index improvers to get to it's 40 weight compared to the 10w40 Quaker State. The less viscosity index improver, the less there is to shear.
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: natas] #5323168 01/15/20 07:51 AM
B
bubbatime Offline
B
Isnt the Moly too high for a wet sump bike? I thought you wanted under 60 or 80 PPM?
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: bubbatime] #5323223 01/15/20 08:50 AM
sunruh Offline
oh jezzzz
not in the slightest. several ive tested have been over 100. hello 1980s calling....try going into 2020 where thats
not the truth.
motorcycle oil myth buster
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: natas] #5323232 01/15/20 08:59 AM
sunruh Offline
natas (the OP)
wow for once....and yes its a rarity, the text from the stoners is worth more than a wooden nickle.
the flash of 435 certainly shows NO fuel.
the susvis of 68.6 says its still a 40wt (requires 68.28) if only barely
every thing looks good with 1 exception.
silicon of 20.
that is high for a road bike of only 1000 or 500mi or whatever it was.
its so high that i went and checked my reports...i have just 3 out of 90 that are over 20...on a dirtbike thats raced
in extremly dusty conditions.
so is this leaching from gasket sealers or really sand/dirt past the filter?
you need to look for air leaks.
and if its really from an air leak...we should be seeing more wear metals.
which maybe the lead+tin but yet alum+iron are low.
somethings very fishy about this
steve
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: sunruh] #5323325 01/15/20 10:23 AM
N
natas Offline OP
N
I guess I can get some starter fluid and start spraying and listening for changes.The filter that was on there was a HiFlo filter. When I changed the oil, I went with a Wix 51358. When I checked the air filters they seemed to be ok. Found a dead bug, and when I put them back in oil was oozing out the side where the filter slides in a little--so the filters are/were oiled up.
I'm actually a little surprised, if you think I have an air-leak somewhere. I'll keep an eye on it. I wonder if I should just wait 1k miles and compare and see if those silicon numbers remain the same or not?
Also I should note that the previous owner did state he rode "hard" on his bikes. Not sure if that would correlate to these UOA numbers. I'm not at the skill level to ride "hard". I usually keep my RPMs around 2.5-3k. Sometimes to 4K, but I haven't gone balls to the wall yet.
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: natas] #5323842 01/15/20 07:58 PM
B
Bonz Offline
B
You said you had oil oozing out, is that a K&N filter in a stock airbox?
You mention filters (plural), are you running pods? Otherwise wouldn't you just have an air box with one filter? Not familiar with that bike however.
I can't recall a time even with pod filters that oil oozes anywhere. Something may be over oiled when oil starts to ooze...?
As for moly content, Red Line runs close to 500 PPM or more in MC oils. They run a lot of zinc and high phosphorus as well as high calcium. They tout extended drain intervals and with that additive package I can sure see it.
The silicon could be from any type of sealer or gasket maker.
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: Bonz] #5323856 01/15/20 08:21 PM
N
natas Offline OP
N
It's the stock air filters. There are 2 air-boxes (or one combined), connected via each carb (2). So each carb boot goes into the airbox, and on each side (under the side cover) there is a removable air filter. The filter media resembles 1970s green shaggy carpet. According to the owners/service manual you are supposed to clean the air filters in motor oil, ring/squeeze them out and install. Since being doused in oil, when putting the filters back into their slots, as the edges of the filter slide into the slots, there is a slight "squeegee effect" as a little oil oozes out where it might rub a little.
I'm not aware of any gasket/sealers done on this bike, but I could be wrong. The mileage on the oil was prob up to 500 miles. So I'm wondering if I take it to 1k miles if the silicon would show double what was found here--if I do have a leak somewhere. I'm actually wondering if I should do a UOA at 500 miles like this one, and have a better comparison. I don't care about "wasting oil" since I can get the Rotella for around $12-13/gal. If the silicon goes down, then it must have been something residual. I dunno. Sucks..I haven't rode in about a week. And rain is on the way.
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: natas] #5323937 01/15/20 09:46 PM
B
Bonz Offline
B
LOL, I haven't been on a bike and five or six weeks here in Colorado. The ZRX 1200 is getting itchy for a ride.
Unless you're in a freaking dustbowl, even a filter housing that's not sealed shouldn't let in that much "silicon" in 500 miles in my estimation.
But thanks for explaining there are dual filters, now I can visualize the setup and how the residual oil would be along the edge.
I think you're simply throwing money in the oil analysis if you do another one at 500 more miles. It's really clear there's nothing wrong with the engine, and if everything is sealed up like it should be, it simply is what it is for that silicon reading.
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: bubbatime] #5325838 01/17/20 10:45 PM
BusyLittleShop Offline
Mileage not Moly is the observed cause of clutch slippage...
Redline MC is not only heavy on moly 300ppm but also JASO MA approved... mounting
evidence that Moly will not and has never been the culprit responsible for clutch slip... look to high mileage...
[Linked Image]
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: 2000 Kawasaki W650 10w-40 Quaker State Advanced Durability API:SN 16K Miles [Re: BusyLittleShop] #5325976 01/18/20 06:50 AM
B
Bonz Offline
B
That we can agree on BLS. cheers
On another thought along those lines, guys on the Yamaha XS1100 forum talk down on synthetic oil because some have "used it once" and the clutch started to slip. I haven't seen info showing any type of synthetic motor oil, group 3 or group 4 or whatever other types there are, as containing a different package that would do that even in motorcycle specific oils. My point being, it's the age of what now could be a 38-42 year-old clutch.
