Originally Posted by benjy
the cold oil spec is tested @ 40C thats 104 FAHRENHEIT!!!! from there everything is downhill! on machinery lubrication it showed how much THICKER an oil gets from there + it notes REAL synthetic PAO + Ester oils thicken a LOT less, so open your wallet + buy Redline or similar for faster flow that protects critical parts needing lubrication, of course other things help as well in some instances + locations.
Cold Cranking Simulator
Quote
Cold Cranking Simulator (CCS)
Please note we do not manufacture or sell testing equipment. We use the CCS to help validate our products and provide our customers with data.
What is it?
The Cold Cranking Simulator (CCS) measures the apparent viscosity of oils at temperatures from -35°C to -5°C. It is a high shear method and is designed to simulate the oil viscosity under cold starting (cranking) conditions. The test method used is ASTM D5293.
Why do we use it?
The low temperature cranking viscosity is one of the four basic viscosity measurements in SAE J300 which defines the rules around engine oil viscosity grades. It is necessary to measure the CCS value of every formulated engine oil in order to check that it is within the viscosity grade.
How does it work?
The CCS contains a temperature controlled (glycol cooled) pot test chamber. The motor controlled stator is housed within the chamber. The CCS uses a vacuum pump to inject the test sample into the test chamber, where it is cooled to the required test temperature. A motor stator with a constant current is started. The resistance of the stator in the sample at the test temperature is converted into viscosity in mPa.s.
CCS Test Limits in SAE J300:
SAE Viscosity Grade : CCS (mPa.s)
0W : 6200 @ -35ºC
5W : 6600 @ -30ºC
10W : 7000 @ -25ºC
15W : 7000@ -20ºC
20W : 9500 @ -15ºC
25W : 13000 @ -10ºC
