Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
102 registered members (3Aone, 1978elcamino, 2015_PSD, 69GTX, 2002 Maxima SE, 7 invisible), 2,629 guests, and 39 spiders.
Topics300,349
Posts5,173,864
Members70,487
Most Online3,825
Jan 19th, 2020
Honda HCF-2, 46k, 2014 Accord CVT (98k) #5322415 01/14/20 12:22 PM
V
vvolcano Offline OP
V
Had the second fluid change come up recently for my Accord's CVT. The factory fill was changed in 2017 at 51k by draining and filling, and I had it analyzed at that time. A single drain and fill changes about half of the fluid (3.9qts). There are some who advocate doing a 3x drain and fill (with some driving in-between changes) to more completely change the fluid. I was curious to see if this was really warranted, so I had this second change analyzed. It's only ever had Honda HCF-2 in it.
[Linked Image from i.imgur.com]
So there was about 4 qts of the original factory fill still in circulation in the above analysis, and with the latest drain and fill, I guess that's down to around 2 qts now. Any reason to do additional fluid changes other than having the effect of draining and *not* filling my wallet? There are only a few other UOAs of HCF-2 on the board, and I think this one has shown the most shearing. A VOA on the board showed the 100c viscosity at 7.1cSt for this fluid. A little concerned this will get even worse when the car reaches ~150k miles, but unless I'm noticing an issue driving-wise, is that even a valid concern?
Re: Honda HCF-2, 46k, 2014 Accord CVT (98k) [Re: vvolcano] #5322636 01/14/20 04:09 PM
Marco620 Offline
I would just replace every 25k and be content. I change mine every 10k with castrol transmax cvt fluid just for piece of mind and I bought like 80 qts on clearance.
15' Civic 1.8 i-vtec 302,000 mi M1 AP 0w20 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
Doberman,Heckler & Koch & SONY Aficionado
Re: Honda HCF-2, 46k, 2014 Accord CVT (98k) [Re: vvolcano] #5323077 01/15/20 03:32 AM
dave1251 Offline
Just change the fluid every 35-40K miles you are doing more fluid changes than your average Bob the consumer.
don't use.
